Hum - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Hum
Discuss Hum in the Home Theater | Audio and Video forum; Hum You know when you set up your million dollar HT and to your horror there is a hum that you ...
Old 06-27-07, 06:26 AM   #1 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
  alan monro is offline
Hum
You know when you set up your million dollar HT and to your horror there is a hum that you can not get rid off Here is the fix . Go out , leave the room and don't go back . If you have to go back this is what to do. Cut your earth wire in each plug and solder 2x4amp diodes back to back, ie, anode to cathode in//L . insert your two back to front diodes (that are wired in parallel )in line with your earth . How it works is that most HUM voltages are less than .6 volts But any voltages above .6v go to earth .SO , you still have a safe earth and the hum has goneKind regards Alan .
Old 06-27-07, 08:42 AM   #2 (Link)
Alias: brucek
User: #6
  brucek is online now
Re: Hummmmmmmmmmmmmmmmmmmmmmmmm
This is the standard galvanic isolation, but there's a problem Alan.
What happens when the safety ground is required as a result of a fault and you require the breaker to trip for your protection. Your 4 amp diodes burn up before the slow reaction breaker trips off and the protection is lost. A bit dangerous......
Old 06-27-07, 08:32 PM   #3 (Link)
Alias: Fred
Loc: Canada
User: #1415
  F1 fan is offline
Re: Hum
It is not wise to cut the safety ground.If you want to do this mod it is best done internally in the unit by leaving the safety ground wire attached to the chassis but the diodes can be placed between circuit ground and chassis.Another approach Ive seen used is to place a thermistor between circuit and chassis ground.
Old 06-27-07, 08:58 PM   #4 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Brucek . I see your point. Maybe use heavy power diodes???? alan
Old 06-27-07, 09:02 PM   #5 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Fred You are saying have the diodes in series with the thermister?? alan
Old 06-27-07, 09:18 PM   #6 (Link)
Alias: Fred
Loc: Canada
User: #1415
  F1 fan is offline
Re: Hum
alan monro wrote: View Post
No Alan just the thermistor alone.
Old 06-27-07, 09:21 PM   #7 (Link)
Alias: Fred
Loc: Canada
User: #1415
  F1 fan is offline
Bryston and PASS labs use a high current bridge rectifier for this purpose.Here is a schematic for the Bryston 3B SST.You can see the bridge rec at the top left. http://www.bryston.ca/BrystonSite05/...-1C(Oct02).pdf
Old 06-27-07, 11:09 PM   #8 (Link)
Alias: brucek
User: #6
Re: Hum
Unfortunately, there is more work to carrying out that mod than it may be worth.
Separating the AC and DC ground in a device requires that all connections to the 'outside world' be isolated. For example, all the RCA connectors must be isolated from the chassis since the RCA connectors outer case is at DC ground, you can't allow them to contact the chassis (which is AC grounded). Any manufacturers that provide the "ground lift" feature take precaution to do this extensive isolation. It ain't cheap.
Actually, once you've created the isolation you only need a small resistor between AC and DC ground to provide the ground lift. All my ST Bryston amps use the resistor technique with a selectable switch unlike the newer SST model that you've shown.
Well, I guess. They would have to be mounted to a metal heat sink to dissipate the heat. You would need to test that the circuit would trip before they overheated in a dead short situation. I would advise finding the cause of the hum as a better solution. Actually, this device uses the parallel diode technique.
Old 06-27-07, 11:39 PM   #9 (Link)
Alias: Fred
Loc: Canada
User: #1415
  F1 fan is offline
Re: Hum
brucek wrote: View Post
Good point Bruce, yes it would be impractical to do on some units as they are connected to the chassis at several points.However most of the better "Audiophile" grade equipment Im aware of do have their inputs isolated and chassis connection is done at one point so doing the mod is possible. But this should only be attempted if you are confident you know what you are doing and as a last resort.
Yes your ST's and all previous generations use a 10ohm 5watt resistor for ground lift. I believe that tighter standards put forth by the CSA and other standards agentsies will no longer approve of this method.
Old 06-28-07, 08:20 PM   #10 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Fred How would the thermistor work to remove the hum . puzzled . Alan
Old 06-28-07, 08:31 PM   #11 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Brucek . In Australia we have earth leakage detectors on our power meter board .They trip I think at 20 ma. and cut off power in milliseconds so there is no shock even if one puts ones hand in a toaster I personally haven't tested the toaster thing yet , and don't think i will . So say using 10 amp power diodes would be sufficient . ?????? Alan
Old 06-28-07, 09:09 PM   #12 (Link)
Alias: Fred
Loc: Canada
User: #1415
  F1 fan is offline
Re: Hum
Alan it does so by adding some resistance.Here is a link to a project that uses one.The schematic is on page 2 and a short description is on page 3. http://www.passdiy.com/pdf/balzenpre.pdf
Old 06-28-07, 09:27 PM   #13 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
  lcaillo is offline
Re: Hum
Why not locate the source of the ground loop and correct the grounding path that creates the problem, or insert an isolation device in the signal line that solves it if the grounds are OK.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 06-30-07, 08:34 PM   #14 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Fred . The circuit you provided would work with hum picked up from a analogue input line .But , we are talking about hum introduced to the amp due to connections from the other equipment not influenced by the amp volume control . alan
Old 06-30-07, 08:42 PM   #15 (Link)
Alias: brucek
User: #6
Re: Hum
Alan, do you have a hum in your system that you could tell us about. Perhaps we can help you get rid of it....
Old 06-30-07, 08:49 PM   #16 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Bruek . Automotive alternator diodes would be ideal for the job . I tend to think the Ebteck devise would have something similar in its guts . And to my observation over the years when a diode fails it shorts out . alan
Old 06-30-07, 09:33 PM   #17 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
Thanks Brucek . I did have hum , it wasn't influenced by the volume control (optical input) so i knew it was a earth problem . The only piece of equipment that had an active earth was my sub amp so i scientifically snapped it off with pliers . It really didn't need a earth as i built it double insulated . wooden frame and plastic pot shaft etc. Then i thought How could i connect an active earth , cure the hum problem , and do it cheaply and safe and so the Thread . alan
Old 06-30-07, 09:41 PM   #18 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Re: Hum
lcaillo wrote: View Post
Icaillo , In my case I found the source of the ground loop and fixed the problem . My only line in is from my dvd and that is optical . I disconnected it and it did not make any difference at all . alan .
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Please help with hum in IB with BFD howburger BFD Forum 23 12-04-07 01:18 PM
*Gasp* now i have a hum... ccdoggy DIY Subwoofers 3 06-05-07 05:48 PM
Need help with BFD hum... mlmore BFD Forum 35 04-27-07 05:01 PM
More Hum problems! Adz201 BFD Forum 1 04-05-07 09:19 PM
BFD and hum... htnut12 BFD Forum 8 03-08-07 12:31 PM
