Go Back   Home Theater Shack > Home Theater | Audio and Video > Home Theater Systems
Register
5.1 vs 7.1 surround Newbie question
Discuss 5.1 vs 7.1 surround Newbie question in the Home Theater | Audio and Video forum; 5.1 vs 7.1 surround Newbie question My apologies, this is probably pretty basic, but I'm new to all of this. I'm looking at buying ...
Old 07-09-07, 05:42 PM   #1 (Link)
New Member
Alias: Mike
Loc: New Baden, Texas
User: #10081
Since: Jul 2007
MikeWard70 is offline
My apologies, this is probably pretty basic, but I'm new to all of this. I'm looking at buying the Onkyo HT-S990THX 7.1 Home Theater System, from the reviews I've read and for the money it seems to suit my needs. That's neither here, nor there. I was looking at the pdf I downloaded of the manual for the receiver to prepare my shopping list for cabling that I might need to buy and I see that it has inputs for the audio for 7.1 (stereo front, center, sides, rears). It said "If your DVD player has a 5.1-channel analog audio output, don’t connect anything to the AV receiver’s SURR BACK L/R jacks." As my DVD player is extremely old, I thought I might purchase a newer one in the interim until the current Blu-Ray vs. whatever format war is decided. Remember the betamax?! So I looked on the net searching for a DVD player with 7.1 audio outs on it. I didn't find any. Not on the most expensive one I found did I see any.
My question is are there any? (and I don't want to pay a whole lot for a DVD player that will be old news in another year or two!)
And if not, why is there 7.1 receivers and nothing to utilize them with?
If the only option available (at this time) is 5.1 then will any sound be output to the other two speakers at all?
Is it a waste of time mounting them?
Would I be better served to make them speakers for another room?
Is there some sort of decoder unit that goes in between the DVD player and the receiver that gives another split for the other pair of speakers?
OK, I realize that's several questions in one post, but I do appreciate any advice/help that anyone can give me.
Sincerely,
Mike W.
Old 07-09-07, 05:50 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: 5.1 vs 7.1 surround Newbie question
Hi Mike, and welcome to the Shack!
There really isn't material recorded/mastered in 7.1 (actually, there might be a thing for 6.1 in DTS, but that doesn't matter). The extra two channels are generally "derived" from the 5.1 signal when processed by the receiver. Most of us use a digital connection from DVD player to receiver. In that case, everything will be taken care of for you, as the receiver is doing all the processing.
I have never used the analog 5.1 outputs on my DVD player. The only way I would do that is if I were using a BluRay/HD-DVD player with a receiver/pre/pro that did not process the audio via HDMI.
I'm not sure why the receiver would be engineered that way necessarily, though. Actually, I'm not sure if it means ABSOLUTELY, DO NOT connect anything to the Surr Back L/R jacks (these are speaker outputs, I'm presuming), or if it meant to say that "you will not get anything out of the Surr Back L/R channels because the input you are providing is only a 5.1 set." If you were using a DVD player with 5.1 outs to the receiver and another DVD player with a digital connection (just for example) and you had 7.1 speakers, you could indeed get signals from the digitally connected DVD player, but not the 5.1 connected DVD player. In that case, I would guess that your Surr Back L/R speakers would simply be silent during 5.1 operation, and no damage would occur. If they are saying that damage would occur, then I would keep shopping, as I would not consider that a well-developed receiver.
Anyway, the bottom line is that you will end up connecting the DVD player to the receiver with a digital connection (either optical or coax) and all this talk about using the 5.1 analog outs is moot.
-- Otto
Old 07-09-07, 05:55 PM   #3 (Link)
New Member
Alias: Mike
User: #10081
Since: Jul 2007
Thanks Otto, that helps with the questions. I didn't think I'd seen any DVD's with a 7.1 option.
Old 07-09-07, 05:56 PM   #4 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Nope, all that information is "created" by your receiver. Many (most?) of us haven't moved up to 7.1. For me, 5.1 really does what I need.
Good luck, and again, welcome!
-- Otto
Old 07-09-07, 09:47 PM   #5 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Many AVRs in the mid to high end range will allow a digital S/PDIF (coax or optical Toslink) 5.1 chan DD or dts bitstream input or a HDMI 5.1 multichannel Linear PCM input to be converted to drive a 7.1 speaker set by allowing Dolby Pro Logic IIx to be applied. It recovers the back surround signals from the side surrounds by using matrix decoding. The lower end Onkyo (6xx series) and Panasonic AVRs don't allow PLIIx to be used this way but higher end Onkyo models (805, etc) do, as do most Yamaha and Denon AVRs.
Old 07-10-07, 08:41 AM   #6 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Welcome to the Shack Mike!
mech
Got questions? Start a thread.
Old 07-10-07, 08:45 AM   #7 (Link)
New Member
Alias: Mike
User: #10081
Since: Jul 2007
Thank you, I'm reading through old threads, learning a lot. I really like the courteous "atmosphere" here at the shack, everyone is really helpful without making you feel like a moron!!!
Old 07-12-07, 05:57 PM   #8 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Heheh, yeah, the way electronics moves forward, I think all of us are perpetual morons. I'm now trying to come to grips with 9.1 and room equalisation... if they build it, we will come!
(Ummm... maybe I should rephrase that?)
View our home theatre project at the Wychwood website. Comments welcome!
Old 07-22-07, 01:47 PM   #9 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Hi ya Mike, Welcome to the Shack, the friendliest HT forum on the Net. There are a lot of knowledgeable folks here and we go the extra mile to ensure a family friendly atmosphere. Glad to have you aboard.
Mark
Old 07-22-07, 06:08 PM   #10 (Link)
jvc
Exterminated!
Alias: jvc
Loc: NC
User: #10201
Since: Jul 2007
jvc is offline
Hello and welcome from NC.
Old 07-22-07, 10:28 PM   #11 (Link)
Loc: Lower Alabama
Hello Mike and welcome to the Shack...
I'm gonna move this over to the General Discussion forum.
Old 07-27-07, 02:40 AM   #12 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
alan monro is offline
Gooday Mike , and welcome. Kind regards , Alan.
Old 07-31-07, 09:27 PM   #13 (Link)
Alias: Shawn
Loc: Topeka
User: #9911
Since: Jul 2007
SierraMikeBravo is offline
Hi all,
Actually, I believe DTS ES is encoded with a 6.1 PCM signal. Yes, the receiver does add Dolby PLx II to Dobly digital and DTS signals when there is only a 5.1 stream if ou have speakers for 7.1. However, I hooked up my 7.1 system after having 5.1 for years, and I was amazed at the additional envelopment. 7.1 does make a difference!! It ws cool to A/B the two to see, and it did make a dramtic difference. It really added additional depth and wrap around effect.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Systems »
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
FS: SMART DEVICES Center-Surround 3X, Jr. Digital Surround Decoder intelonetwo Classifieds - Audio Equipment 1 04-17-08 01:19 PM
A newbie with a sound card/os question. kwils REW Forum 1 03-25-07 09:28 PM
Newbie question about 33-2050 mjhamre REW Forum 3 01-28-07 11:30 PM
Newbie question for SPL advice & 1124ps oris98 BFD Forum 4 01-24-07 02:30 AM
Newbie question connecting sound card purcellt REW Forum 2 07-17-06 07:10 AM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23</
