MP3 Integration to main system - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss MP3 Integration to main system in the Home Theater | Audio and Video forum; MP3 Integration to main system I got an email the other day which got me thinking. This email happened to be about 2 products from ...
Old 06-13-07, 01:00 PM   #1 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
I got an email the other day which got me thinking. This email happened to be about 2 products from Slim Devices, the Transporter, and the Squeezebox. I've currently got a hookup for my iPod, which I use less and less as the novelty wears off, and I always think that I'd listen to more music if I had my whole MP3 collection available without hassle. I did some looking around and the Transporter seems very cool looking, and it supposedly has great D/A converters, but does it really make a difference with compressed audio anyway? It's a pricey setup at about $1999. The Squeezebox seems much more reasonable at $299.
The Sonos system seems to be a very serious contender, and although a little expensive around $800 or so, it certainly isn't unreasonable.
Turtle Beach has apparently discontinued their Audiotron, which I used to think was a pretty cool piece of hardware.
Are there any others I'm missing? I still don't know about how all of these guys work, but what I think I would like best is a component that basically functions like an iPod, but in a full chassis with a more detailed display and more HD space. I don't mind piggybacking on my PC for networked storage, but if I could find a standalone solution it would probably be the best.
What options are you guys using?
Old 06-14-07, 08:23 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: MP3 Integration to main system
Hi Owen,
I'm just use a "normal" server and client PC to play music through my system. I have them stored in FLAC format and usually access my HTPC via "Remote Desktop" on a laptop. The FLAC format is lossless, and I go optical from my PC to my Outlaw 990. I find this setup to be invaluable; I can listen to anything I want with a few mouse clicks. Anyway, that's how I'm doing it, and I know a few guys with similar setups.
I also know a couple guys with Sonos setups, one of which used to have a Squeezebox. He upgraded to the Sonos because of its nicer user interface (i.e., a stronger remote control, really).
Both need external storage, so you'd probably have to use an existing PC. I'm not sure if they can just use NAS (Network Attached Storage) or not, of if that matters to you. I think you know how the rest of it works for the most part.
The Squeezebox has a three- or four-line display that tells you all the information it can. I've never actually used one first hand, so I don't know how easy or difficult it is to use. From what I can tell, you would have to scroll through things to get to what you want, and you could only see three or four things at a time. I'm so used to seeing many, many items at a time that I think that limitation would really bother me. Other than that, I understand that the Squeezebox is a well-liked, and inexpensive, solution to the problem at hand.
On to the Sonos. I have used this device first-hand, and it's pretty slick. The interface is obviously and directly inspired from the iPod, with its wheel and few buttons. The user can see more choices at once, and selections are "drilled down" until you get what you want. Still, if you are somewhat hyper about selecting songs and creating playlists, it's not as fast as my PC (and my friend told me that my laptop remote desktopped to my HTPC was "lagging"! Ha!).
I don't know anything about the Transporter or the Roku Soundbridge (a similar device). The Soundbridge was reviewed in a recent Stereophile, and didn't get the best marks. It's in the $200 or $300 range.
Finally, I would most likely pass on using any of the devices' DACs, and send the signal directly to my pre/pro, assuming that it's a superior converter. I wouldn't bother paying extra for good DACs in any of these devices. If there were an increased price tag for that type of thing, I would probably invest it in a device like a Benchmark DAC-1 or Channel Islands VDA2.
Anyway, those are my experiences with a few different methods at getting digital music to a stereo system.
-- Otto
Old 06-14-07, 06:27 PM   #3 (Link)
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
Mitch G is offline
I have a Squeezebox and really like it.
My set up is that I have my CD collection ripped to FLAC on the family computer (1 GHz Pentium III, I think?) in the basement. This drives the Squeezebox fine. The only time I'll experience a lag is if my son is playing Warcraft or some other CPU-intensive game. But even then the lag is generally short lived and the system continues playing fine.
I haven't seen a Sonos first hand but I do understand the interface is slick.
That said, the interface for the Squeezebox is very user friendly.
Using the remote, it's easy to scroll through albums, artists, genres, playlists and hit play. Additionally, I have a laptop in the family room and can use the web interface to control the squeezebox. (There are even skins for wireless PDAs and I think for the PSP as well that let you use these devices' web browsers to control the Squeezebox.) But, I use the remote control to control the box about 99% of the time.
Additionally, with the plugins available, I use the Squeezebox to get weather reports, stream RSS feeds, etc. using the remote.
The bottom line is I think for the money, it's a great little box.
Mitch
P.S. I suggest ripping to FLAC or some lossless format and then using something like flac2mp3 to create song sets for loading on the iPod.
Old 06-15-07, 11:21 AM   #4 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Thanks for the details guys, that's the kind of stuff I can't depend on Google for. I should be moving this year, and if I decide to go for a house, I might look into the Sonos for its integration and multi-room benefits. If I decide to go condo, then either a squeezebox, or a direct line out from my PC might satisfy me. Hmmmm, so many purchases contingent on the one big one.
Old 06-15-07, 04:43 PM   #5 (Link)
Alias: Mitch
User: #2469
Since: Sep 2006
Mitch G is offline
BTW, you can also download softsqueeze which emulates a squeezebox (and remote) on a computer and try out the remote-based user interface.
Good luck on the house hunt,
Mitch
Old 06-18-07, 06:16 AM   #6 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Mitch, that's cool, thanks! It's a pretty unique feature to be able to try out a new piece of equipment virtually.
Old 06-22-07, 02:56 PM   #7 (Link)
New Member
Alias: kevin
User: #9355
Since: Jun 2007
kdoswald is offline
I use as PC.. and just use either Windows Media Center.. which I am liking less and less.. Beginign to switch to Media Portal.. It is a free program which is a spin off from the xbox media center.. it works with the Microsoft media center remote which you can buy for $20 give or take.. You can run it on any windows virtually.. no problem with codecs etc as with hardware based media centers that alot sell. I use it for Movies and mp3's.. so works great.. Any new video format comes out I just load the codec and off i go. Can alsdo do internet radio stations etc.. OriginallyI was running it from a P3 933mhz.. some videios had problems would stagger a bit but 99% ran fine.
And its free!
Old 06-22-07, 06:29 PM   #8 (Link)
Alias: Wooch
Loc: SF Bay Area
Woochifer's Avatar
User: #3159
Since: Oct 2006
Woochifer is offline
There's also the Roku/Pinnacle Soundbridge and the Apple TV that both sell for around $300. With the addition of a new 500 GB hard drive, I've been looking into lossless audio formats and network music players. Unfortunately, the search so far has been highly disappointing.
The disadvantage though to all of these network music players is that they generally require a PC with server software running. Only the Sonos unit as far as I know is capable of directly reading a NAS drive without a PC running a media server application.
Even without this hurdle, all of these music players have some major disadvantage that gives me pause when considering the various options.
Squeezebox: (+) great reputation for audio quality, audio format support, ease-of-use, cross-platform support, supports net radio streaming; (-) requires the Slimserver application running at all times on external PC, limited support for NAS drives (Slimserver client can be configured to run on certain NAS drives), no video output or OSD (problem for those of us who keep our components inside of an audio rack)
Apple TV: (+) ease-of-use, supports video programming, can connect to any drive shared on iTunes, on-board hard drive can be sync'd with iTunes on PC/Mac, supports draft 802.11n wireless spec; (-) requires a server application running on external PC, no support for NAS drives, does not support net radio streaming including iTunes radio links, does not support some lossless formats such as FLAC
Sonos: (+) supports NAS drives, has video output, remote has OSD built in; (-) some gripes about audio quality, expensive (remote alone costs $300)
Roku Soundbridge: (+) inexpensive ($150), flexible configuration (can use third party applications such as iTunes or Windows Media Player as a software server), supports net radio streaming; (-) requires a server application running on external PC, no support for NAS drives, does not support some lossless formats, no analog audio outputs
Ideally, I'd like to see some network music player that includes an on-screen display, does not require a client application at the server end, can attach to a NAS drive, incorporates higher quality playback electronics (like the Squeezebox does), and is reasonably priced. So far, I've seen nothing on the market that incorporates these features.
Old 06-23-07, 06:18 AM   #9 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Wooch, thanks for the comprehensive comparison, that's great! I hadn't even thought of an OSD, I guess I just figured the component display would be enough. This thread is getting filed away for when purchase time comes around.
Old 06-23-07, 08:14 PM   #10 (Link)
New Member
Alias: Manxam
User: #1749
manxam is offline
One of the simplest, and often overlooked, setups is a modded XBOX with xboxmediacenter installed on it.
The xbox has a coaxial out, can be operated via remote, and is fully networkable.
I have a NAS with 4TB of movies and music setup that is being sent to my amp and television by the XBOX.
Old 07-05-07, 11:27 AM   #11 (Link)
Alias: Jared
User: #2200
Since: Aug 2006
JRace is offline
I have laptop with usb sound card and an external hard drive with all my media on it.
The laptop sends its video out to my projector, and I can watch TV, movies or even browse the net.
I have around 80gigs of music, moslty in FLAC. I rarely spin a disc these days. Iuse Foobar 2000 as my media player and I can create any playlist I need.
When I want to take my music to the shop patio or vehicle I just take my 30gig Ipod (rockboxed - to allow flac playback) and plug that into the respective stereos.
Works great!
Old 07-07-07, 01:06 AM   #12 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
What ive used for ages is a simple htpc with decent sound card running winamp. Now what I do is map a network drive to the actual computer holding the music (or just simply put all the music on the htpc). Additionally, I install a nifty plugin called WAWI, and I can build the playlist, change tracks, control volume, etc from any networked computer through a simple web interface. Ive actually used this in combination with shoutcast to access my entire mp3 collection at work over a streaming connection. The main benefit to using winamp is the massive amount of plugins that are available, and if you can hook it up to the video input, it makes for an awesome visualization for parties.
Old 07-09-07, 10:09 AM   #13 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Bob, I've always liked Winamp, and that's what I have used in the past, just with a long headphone extension cord and a splitter into my stereo. I might just stick with this for a while until my indecision settles.
Old 07-09-07, 09:14 PM   #14 (Link)
New Member
Alias: Soundoctor
Loc: Clearwater, FL
User: #9586
Since: Jun 2007
Soundoctor is offline
Here's an approach.
Inasmuch as I have a lab full of equipment to test, generally mess with, etc, what I actually listen to is I have a dual core machine with a pleasant realtek board; there are twin 500G drives, and my CD' and vinyl are simply ripped at 320k. There are simply separate folders for rock, classical, jazz, electronic and 'other' and it's organized in a heirarchy I like, since I did it!
The line out goes into an Aphex 204, then into a pair of M&K 1611P's (crossed over at 80) and a JL audio f112 or f113 sub.
Whether playing some background Chopin, or the latest nickelback at 115 dB, all I can say is you should see the looks on people's faces, and many are speechless for hours...!
Let's put it this way: after setting up sound systems for nearly 50 years, I simply like it! I can find any of my favorites in seconds, and it's enjoyable!
Barry
Old 07-11-07, 07:51 AM   #15 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Barry, that's what I like about having the PC as my music player, no matter how good an interface is on most components or portables, there can be a lot of scrolling involved that just can't match the efficiency of some good ol' point and click.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Parents main speakers--Suggestions allredp Home Audio Speakers 20 09-10-07 02:16 PM
BFD | REW for main speakers w/0 sub? jdialc REW Forum 6 03-17-07 12:58 PM
First real measurement subs, subs+main, subs+main large frockc REW Forum 13 03-17-07 11:42 AM
HD Radio to Main System Anyone? srckkmack General Discussion 2 02-14-07 10:32 PM
CableCard fight continues: Courts uphold integration ban, NCTA seeks delay waiver Wayde Home Theater, Audio and Video News 0 08-20-06 02:38 PM
Mach 5 Audio
