| General Discussion Is DTS important?Discuss Is DTS important? in the Home Theater | Audio and Video forum; Is DTS important? Welcome to the forum, and yes entering with a bang.
The first few concert DVD's I listened to sounded more ... |
| View Poll Results: Should DTS determine DVD player purchase | |||
| Yes, DTS is the one thing that really takes advantage of your sound system | | 13 | 65.00% |
| DTS is a niche product and not important | | 2 | 10.00% |
| If you're happy with the player without DTS, don't worry. | | 5 | 25.00% |
| Voters: 20. You may not vote on this poll | |||
| | #26 (Link) | |||
| Re: Is DTS important? Welcome to the forum, and yes entering with a bang. The first few concert DVD's I listened to sounded more dynamic with DTS, and as a consequence I just instinctively choose DTS over DD if the disc allows the option. I never read any posts, or read papers, comparing the two formats at the time so it was purely based on my subjective listening. I've never considered doing an AB since this time, and I've probably emerged into a DTS supporter. Like similar forum members part of the motivation is supporting the underdog, but its encouraging to see that an industry professional supports DTS also for the right technical and business reasons. | |||
| | #28 (Link) | ||||
| Re: Is DTS important? Quote:
| | #30 (Link) | |||
| Re: Is DTS important? From my first hand experiences, switching between DD and DTS will yield some differences. Most notably for WOTW, where the DTS track is way more involving in the areas of LFE as well as information being sent to the surrounds. Would I be disappointed without DTS? Probably not... DTS wont make or break a system. By my nature I favor situations where there are options, so yeah it is cool IMO to have DTS as an alternative but I definitely wouldn't lose any sleep over not having DTS. There are many DD encoded movies with awesome soundtracks...Like The Incredibles for 1. my 02. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #31 (Link) | |||
| Re: Is DTS important? Personally I prefer DTS, however I have now resorted to using my Xbox360 as my DVD player and although I use the Pioneer 814 mentioned before, the Xbox will not pass the DTS encoding to the receiver I will probably reinstate my Pioneer DVD player for the time being and just use the XB for TV distribution. | |||
| | #33 (Link) | ||||
So to recap, you prefer DTS too? I obviously don't have your proffessional knowledge on the subject, so it tends to boil down to such criteria as, which format renders mumbling/whispering better/which format makes my windows rattle more. DTS for me all the way. Or to put it another way, now, when I drop a new disc in the tray, I select the DTS soundtrack automatically. It is perhaps remiss on my part, but having done the subjective comparisons a few times some while ago, I always came to the same conclusion. Now, I prefer to watch a new film as soon as I get it and rightly or wrongly, go with what I know and select DTS. While you're about it. What discs do contain the full bitrate sound tracks and with the same master possibly? Any of the Superbit stuff for example? I buy them for their picture quality (MIB II ) but the soundtracks have always impressed.Russell | ||||
| | #34 (Link) | ||||
| Re: Is DTS important? This may be of interest, http://www.spannerworks.net/reference/10_1a.asp From the article: Quote:
cheers ![]() MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc.... BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc.... | ||||
| | #35 (Link) | ||||
War of the Worlds DD uses a DIALNORM value of -23, so it plays back at 8 dB (-31 - (-23) = -8) lower than the DTS version. So, you have to lower the DTS version by 8 dB to make a comparison of the two versions. I can hardly tell the difference between the two versions once I reset the MV control to compensate for DIALNORM. My receiver reads out the DD DIALNORM value, so the above numbers are correct! | ||||
| | #36 (Link) | |||
| Re: Is DTS important? i personaly think its more down to the mix, gladiator is a good one for this i seem to recall, the scenes in the caravan the backround noise is definately more pronounced (this is going from memory) is for being more dynamic etc, never realy noticed, though it has to be said, my jurasic park dts laser disc is still one of my reference sound discs, its superb. edd | |||
| | #37 (Link) | ||||
I found that even after compensating for the Dialog Norm offset the DTS track's bass was still higher SPL then the DD version, I had to turn the receivers sub vol down by a further 7db just to get bass about the same. This proved, to me that DTS plays with the sound a bit, they must think people prefer a hotter bass line then what the mixer intended. cheers ![]() MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc.... BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc.... | ||||
| | #38 (Link) | |||
| Re: Is DTS important? With my recent experiences regarding the loss of dynamics due to DD stereo downmixing, i'll have to change my previous opinion on this issue. DTS for people like me who are using less than 5.1 speakers is our only ticket to reaching the highest level of dynamics possible...Overall, its better to have more options to choose from, especially when your systen isn't equipped to take advantage of true DD 5.1. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #39 (Link) | |||
| Re: Is DTS important? All I can say is DTS rocks. The new formats are coming out, HD DVD and Blue Ray, and we will be getting almost 20 times the bitrate transfer rates. DTS Master should sound exactly the way the studio produced it. No loss. MMM. All we need now is the receives/pres to handle the signal. Roly | |||
| | #40 (Link) | ||||
| | #41 (Link) | |||
| Re: Is DTS important? DTS is a great thing, because it presented Dolby with a problem.. To compete Dolby needed something that at the time was superior to Pro Logic and Dolby Surround. DTS started the snowball that is the avalanche that now is 6.1/7.1 Bit for Bit to the original recordings. ~Bob | |||
| | #43 (Link) | |||
| | Re: Is DTS important? Someone else mentioned in another thread that Star Wars and LOTR both had rear information. I do not know if it's true and/or if it's one or two channels. I'm thinking there are some out there and these are a couple of them, but again, can't guarantee it. Maybe someone else can. | |||
| | #45 (Link) | ||||
Bob | ||||
| | #46 (Link) | |||
| Re: Is DTS important? Sorry to get in late on this thread but here's my two cents anyways.... I've always preferred DTS, from my original HTIB setup to my current separates system. It just seems to sound richer and better given the shortcomings of my room (two open archways, wife opposed to acoustic panels etc...) Later ... | |||
