Connection question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Connection question
Discuss Connection question in the Home Theater | Audio and Video forum; Connection question I wish to use the speaker output from my 5.1 HT system to play to other speakers in other rooms ...
Old 07-20-07, 06:26 PM   #1 (Link)
New Member
Alias: Ondee57
User: #10329
Since: Jul 2007
ondee57 is offline
Connection question
I wish to use the speaker output from my 5.1 HT system to play to other speakers in other rooms in the house. I am just looking for routine 2.0 stereo sound in the other rooms. I have speaker wire in the walls and a distribution module in a structured media panel at a different location in the house. Each set of remote speakers has a balanced volume control. How do I do this if there is no auxillary audio output from the A/V receiver? Do I take the Front speaker outputs from the receiver and run them to the module, and then run wires back to the front speakers from the module? Or use a second distribution module right at the receiver, so I don't have such a long run of speaker wires? I have not been able to find the answer to this question in the other threads. Thanks.
Ondee57
Old 07-20-07, 11:32 PM   #2 (Link)
jvc
Exterminated!
Alias: jvc
Loc: NC
User: #10201
Since: Jul 2007
jvc is offline
Re: Connection question
You don't mention what receiver you have. Does it have a button for speakers labeled A/B? Main system usually uses the A setting. Try using the B setting for the others.
I know you said there is no auxillary output for speakers, but the B speakers connections are usually right next to the A (mains), on back of receiver, so they may not look like extras. I don't remember seeing a receiver that didn't have the B speaker connections, but of course, that doesn't mean there aren't any.
Good luck!
Old 07-21-07, 08:03 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Hi Ondee57, and welcome to the Shack. There are a couple different ways to approach this. Like jvc mentioned, it would help us if you note the make and model of receiver.
A couple questions:
  1. Are you willing to change receivers if it ends up that your current model isn't well-suited for what you want to do?
  2. Do you have any desire to be able to control the volume and/or program material that's playing in the "other" room? Another way to ask the same question -- do you care if the "other" room is playing the same movie and volume if you're watching a movie in the "5.1" room?
I think that's it for now.
-- Otto
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Is there still a connection John N Home Audio Acoustics 10 03-30-07 09:23 AM
BFD Connection Question drrick BFD Forum 9 12-27-06 08:46 AM
Another connection question - M-audio 410 & SPDIF maneuen REW Forum 8 07-18-06 09:08 AM
Basic Connection Question..... Vader System Setup and Connection 2 07-16-06 10:11 PM
Enabling Internet Connection for HT Room Tommy Computers | Games | HTPC | Digital Devices 2 06-22-06 08:40 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
