| General Discussion Current DrawDiscuss Current Draw in the Home Theater | Audio and Video forum; Current Draw If I connect two 120 Volt 1000 Watt lamps in series wiring what will be the current draw. My guess ... |
| | #1 (Link) | |||
| Current Draw If I connect two 120 Volt 1000 Watt lamps in series wiring what will be the current draw. My guess is that the total draw would be 1000 Watts. (BTW in Australia we run 240 Volt power) | |||
| | #2 (Link) | |||
| Re: Current Draw If a lamp dissipates 1000 watts when 120 volts is across its terminals, then each lamp would still dissipate 1000 watts in your proposed setup. The 240 volts across the two lamps would still result in 120 volts across each lamp. brucek | |||
| | #6 (Link) | ||||
| Re: Current Draw Quote:
I don't think there's a benefit. In general, I'd probably suggest you use the 240 v version, as it's native to your electrical system -- it's just set up for it already. Are you actually talking about doing this with lamps? -- Otto | ||||
| | #7 (Link) | |||
| Re: Current Draw It is better to use the 240 V lamp. If the two lamps are not matched, one will have a higher voltage on it than the other, and it will burn out quckly. If you must do this, use two 130 V lamps so they have some voltage derating. | |||
| | #9 (Link) | |||
| Re: Current Draw Lamps with wattage less than 1000 W are often 120 V, and I think availability determines what you may find. So a light bar with 100 W bulbs will be 120 V in series. The series connection may be used to reduce the wiring weight. The bars and overhead lights are often raised, lowered and moved around by hand. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Current Gear | ACGREEN | Home Theater Equipment | 3 | 08-16-08 12:21 AM |
| My current equipment ... | salvasol | Home Theater Equipment | 4 | 05-30-08 11:55 PM |
| My current HT Setup | cburbs | Home Theater Equipment | 1 | 04-27-07 01:07 PM |
| Current theater | ACGREEN | Home Theater Gallery | 4 | 04-05-07 09:48 PM |
