| General Discussion Hooking up another set of speakers in another room.Discuss Hooking up another set of speakers in another room. in the Home Theater | Audio and Video forum; Hooking up another set of speakers in another room. My father would like to add another set of speakers in another room but
his Marantz sr4300 does not have ... |
| | #1 (Link) | |||
| Hooking up another set of speakers in another room. My father would like to add another set of speakers in another room but his Marantz sr4300 does not have extra speaker jacks . I was wondering if I could use the " tape out" jacks (or some other source ) and go into the "aux in" jacks of his 35+ year old Fisher reciever? (they made things better back then ,has been in the shop once 10 years ago!) I have yet o find a better tuner than on this unit (fm only) John | |||
| | #3 (Link) | |||
| Re: Hooking up another set of speakers in another room. Thanks for the fast response !! Another question? Would it be better to have the two recievers in the same location than 40 ? feet apart ? (maybe too far of a run with the rca cable )Thanks again! John | |||
| | #4 (Link) | |||
| Re: Hooking up another set of speakers in another room. No problem either way. Having the second unit where it will be used may make controlling it more convenient, however. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #6 (Link) | ||||
| Re: Hooking up another set of speakers in another room. Quote:
Oh my, I almost hate to confess, but I remember that receiver. That was when electronics was made with loving care. Keep that puppy healthy, John, it's a classic. | ||||
| | #7 (Link) | ||||
Went to to hook up the Fisher to the Marantz and had no luck . Hooked the tape out on Marantz to the aux in on the fisher (also tried the vcr audio out ) The aux in does work . (played a cd player and audio from the cable box.What kind of set up do you guys use for running extra speakers?(on a budget) If I can't find a way to get an audio signal from the reciever , could I put put "y" conector on the main spr. pre amp outputs and hook up a multi channel amp ? Are "y's" a bad idea? | ||||
| | #8 (Link) | ||||
Regards, Wayne A. Pflughaupt | ||||
| | #9 (Link) | |||
| Re: Hooking up another set of speakers in another room. The aux in does work . It worked with a cd player and the cable box audio. The Fisher does have tape inputs but they say "tape head" . would these work ? Where these for the old real to real? Thanks, John Last edited by John N; 08-28-07 at 10:55 PM. | |||
| | #10 (Link) | |||
| Re: Hooking up another set of speakers in another room. I think that tape head was a low level input with an RIAA equalization for reel-reel tape decks. You should be using some type of auxiliary high level input on the Fisher. You do need a high level preamplifier output from the Marantz. I don't know if a tape-out would be right, since it may only be connected to tape-in. You need an output that would carry all the signals. I use Y connectors on my equipment between my preamp and my power amp and the casette recorder without a problem. Going a long distance is usually problematic with an unbalanced signal, however. Be sure to try a short connection before you go any distance. | |||
| | #11 (Link) | |||
| Re: Hooking up another set of speakers in another room. I can't understand why the vcr output on the Marantz would not work . Do the speaker wire jacks get turned off then a set of pre amp outs are used ? Could I use an external amp for the main channels(l&r) and use the reciever spr jacks for the other room? | |||
| | #12 (Link) | |||
| | Re: Hooking up another set of speakers in another room. The Fisher’s tape or Aux inputs will work. Since you’ve confirmed its Aux input does work, I’m going to assume the source you’re using at the Marantz is connected via digital audio – i.e., optical or coax. A receiver’s digital and analog audio paths are totally independent from each other. If you want to output a signal from the analog tape or VCR outs, you’ll need to add the source component’s analog connections. Regards, Wayne | |||
| | #13 (Link) | ||||
I have it hooked up with an optical cable from the dvd player and a dig coax from the digital cable box but have not been able to get a dolby digital signal from the cable box .(that may be in a new topic in the future.......) Thanks Last edited by John N; 08-28-07 at 11:54 PM. | ||||
| | #14 (Link) | ||||
![]() Now I have to look up the manual online (his is a little older ) Thanks!!! | ||||
| | #15 (Link) | ||||
![]() Regards, Wayne | ||||
| | #16 (Link) | ||||
| | #17 (Link) | ||||
John | ||||
| | #18 (Link) | ||||
| | #19 (Link) | ||||
| | #21 (Link) | |||
| Re: Hooking up another set of speakers in another room. Another solution might be something like this http://www.outdoorspeakerdepot.com/isimma4pasps.html http://www.outdoorspeakerdepot.com/4spsewvoco.html to distribute output to multiple speakers. You could leave the old Fisher in retirement. I have a Niles 6-speaker selector running off an old Realistic STA-2380 receiver and it has driven five sets of speakers without a problem. Last edited by jackfish; 08-29-07 at 01:25 PM. | |||
