How much difference with Dolby TrueHD?? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss How much difference with Dolby TrueHD?? in the Home Theater | Audio and Video forum; How much difference with Dolby TrueHD?? Hi All, In an effort to get the best sound/picture possible I took back my Toshiba A20 and exchanged it ...
Old 09-15-07, 04:28 PM   #1 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Hi All,
In an effort to get the best sound/picture possible I took back my Toshiba A20 and exchanged it for an XA2. My rationale for this was the A20's video decoding isn't as good as the XA2's and the A20 did not have 5.1 analog outputs. This is important since my Emotiva MMC-1 doesn't have 1.3 HDMI.
My plan is to use the XA2 to decode the Dolby TrueHD and pipe it in the MMC-1's direct input.
Anyway, on to my question. Is there a big difference in sound between TrueHD and standard Dolby soundtracks? I am hoping the extra $150 will be worth it both in terms of sound and picture quality.
Thanks,
Joe
Old 09-15-07, 04:39 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: How much difference with Dolby TrueHD??
A subtle difference to me. Only during low audio level portions in Phantom of the Opera, etc IME. YMMV. But you will be using a lossless audio connection from the player to your Pre-Pro which should also give you the full benefit of other advanced audio codecs like Dolby Digital Plus (DD+) especially with the high 1509 kbps bitrates that Universal and Paramount use.
Old 09-15-07, 11:35 PM   #3 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
I honestly cannot tell the difference in quality with the current movies, but I would imagine that as the audio engineers adapt to the higher bitrates, that the sound will be more open/dynamic.
Old 09-15-07, 11:45 PM   #4 (Link)
Alias: gs
User: #159
gsmollin is offline
I found it subtle as well. I have some movies with both style soundtracks, and the TrueHD has better dynamics, and a clearer sound. But it is a small improvement. I think the resolution and color gamut improvements of the video signal are much more important. Still, it is better, and it should improve more with 7.1 soundtracks.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
TrueHD/Master HD Receivers Testpattern Home Theater Components 11 10-07-07 11:31 AM
DD+, TrueHD Downmixing questions... Vader High Definition | HD DVD | Blu-ray 16 06-10-07 03:49 PM
Is 1.3 hdmi necessary for Dolby TrueHD and DTS-HD Master Audio? jmy2469 Home Theater Components 7 06-03-07 08:32 AM
HD DVD 2.0 Firmware (Officially released); enables TrueHD 5.1 Tommy High Definition | HD DVD | Blu-ray 23 10-13-06 06:53 AM
HD DVD reviews updated with Dolby TrueHD, firmware update warning HDBeat Home Theater, Audio and Video News 0 08-29-06 08:50 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
