Have we reached the Pinnacle? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss Have we reached the Pinnacle? in the Home Theater | Audio and Video forum; Have we reached the Pinnacle? What with 1080p and HDMI have we reached resolution nirvanah? Is 2160p around the corner? If there is more to ...
Old 10-07-07, 01:54 PM   #1 (Link)
Alias: Instal
Loc: Victoria BC
User: #8076
Since: Apr 2007
Instal is offline
What with 1080p and HDMI have we reached resolution nirvanah? Is 2160p around the corner? If there is more to come will we be able to tell the difference or have we given the human eye all it can handle?
Old 10-07-07, 04:10 PM   #2 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Re: Have we reached the Pinnacle?
Outside of HD-DVD and Blu-Ray we haven't even reached 1080p yet!
mech
mech
Got questions? Start a thread.
Old 10-07-07, 05:02 PM   #3 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
The next format is probably going to be a variant of 4K, which is the next generation digital film format being used for many current productions. I believe even JVC annouced a projector at CES that would be capable of reproducing the 4K format.
Old 10-07-07, 11:40 PM   #4 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
In terms of resolution, I think we're pretty good for some time, but other aspects of video quality still have plenty of room for improvement. Additionally, if the sources don't improve, none of it really matters. I still haven't seen anything touch the Mayweather Delahoya fight on HBO HD in term of picture quality, and that's sarting to get depressing. I doubt any source is close to utilizing HD to its fullest right now - even that fight was probably only 80% of what it could have been.
Old 10-08-07, 09:35 AM   #5 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Not to mention, what would the average home user do with 4k? They either build a theater 25 feet deep, or get motions sickness and neck strain from having a screen far too big for their field of vision.
1080p is not the pinnacle, but it's all ready overkill for most home theaters/livingrooms/bedrooms.
Old 10-08-07, 12:08 PM   #6 (Link)
Alias: brucek
User: #6
brucek is online now
I've heard lots of buzz about 1440p HDTV sets.
Old 10-08-07, 01:02 PM   #7 (Link)
Alias: Joe Tama
joetama's Avatar
User: #9288
Since: May 2007
joetama is offline
I would have to say that 1440p is still going to be a long way off. A lot of people haven't even accepted or have any desire to get 1080p...
Rotel/B&W/Arcam/Rega/Pioneer Elite
Old 10-13-07, 09:28 PM   #8 (Link)
Alias: Instal
Loc: Victoria BC
User: #8076
Since: Apr 2007
Instal is offline
So does that mean that you guys think that our eyes can process higher resolutions? I wonder what the limit is? Surely sooner or later any increase in resolution would not be able tp be detected by the limits of our biology.
Old 10-14-07, 12:18 AM   #9 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
Well... the typical visual acuity of a person with healthy eyes (20/20) is about 1 arc minute to discriminate 2 different points. You can do some simple trig to figure out just how far away you could be from a screen with a predefined resolution to make 2 adjacent pixels indistinguishable.
lets see... take number of horizontal pixels and divide by screen width. This will give you dpi (linear only, but we can assume square pixels and go with in^2).
Now for simplicity's sake, we can assume that the pixels are of infinitesimal size, but still visually percievable, and are evenly distributed through the measured region. We can take the dpi value and take the inverse to find the distance between each pixel.
now its a simple matter to find the number of arcminutes from a certain position...
(90-Tan^-1 (Distance from screen in Inches/(Distance between Pixels in Inches*.5)))*120
if the above equation is less than or equal to 1, then it is fair to say that the pixelation of the display/projection will be unnoticable by the viewer.
To make a simple example:
Lets assume a 1080p projection of 1.77 AR material with a 120" horizontal screen viewed @ 96"
1920/120=16 dpi=.0125 inches between dots
(90-(Tan^-1(96/.0625))*120 = 4.488 arcminutes
So it would be fair to say that the human eye could (under perfect test circumstances) resolve the difference between the dots with minimal difficulty. Now with normal source material this usually goes unnoticed due to the psychovisual characteristics of the human brain, but it should definately be noted that one could tell the difference between 1920 pixels and 4000 pixels at 96" on a 120" screen. In this case, quadrupling the resolution with same viewing characteristics would result in a "perfect" image for all intents and purposes.
Old 10-14-07, 10:50 AM   #10 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
So the answer is yes, if you sit close enough and your screen is big enough.
Old 10-14-07, 05:56 PM   #11 (Link)
Alias: Instal
Loc: Victoria BC
User: #8076
Since: Apr 2007
Instal is offline
eugovector wrote: View Post
Wow, thanks for the clarification Eugo I wa sbeginning to get a headache.
Old 10-14-07, 09:00 PM   #12 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Well, not to diminish the work that Bob did. There are plenty of people who'd rather not just take my word for it.
Old 10-18-07, 12:16 AM   #13 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
I was trying to make a point that even under fairly distant viewing conditions (8 foot), we are still very far away from achieving a "perfect" image.
Old 10-18-07, 11:28 AM   #14 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
How about this?
JCD
Old 10-18-07, 11:34 AM   #15 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Hah, with Sony's track record of crippling technology, implementing rootkits that devastate computer hardware, and propagating a pay to play standard that most of us thought went out in the 70s, it will be a cold day before I let Sony anywhere near my brain.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
