| General Discussion workarounds to having equipment that don't auto turn on or have a remoteDiscuss workarounds to having equipment that don't auto turn on or have a remote in the Home Theater | Audio and Video forum; workarounds to having equipment that don't auto turn on or have a remote since i'm too lazy to turn on each behringer amp ...
i'm even too lazy to build some more of ... |
| | #4 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote i bought this relay: it's a 12v relay that switches the AC power source on and off. here's how it works: -you connect a 12v AC to DC adaptor on your receiver's switched outlet ... the other end is connected to the relay. -then you build a socket where you will plug your behringer feedback destroyer (for example) and then a plug that you will connect directly to your AC source. -when the relay senses a 12v current, it let's the AC source connected to it pass through, voila, a 12v triggered amp of BFD. waivers: employ an electrician to do this for you if have no idea what you are doing ... this can potentially be a fire hazard or it can electrocute you (we are dealing with AC voltage here) this is for 10A and below only ... i've used this myself on my Behringer A500. it would be safer if you build one set of this for EACH amp. | |||
| | #6 (Link) | ||||
| Re: workarounds to having equipment that don't auto turn on or have a remote Quote:
Receiver Switched outlet AC -> 12v adapter -> relay from the wall AC -> relay -> socket (female outlet) i had bookmarked the page I followed the instructions from, but now it's a dead link. i'll try to upload the page i saved when i get back to my work PC on nov. 5. | ||||
| | #7 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote Nice easy solution. Anything that makes life easier deserves 2 thumbs up. ![]() I am glad to see you found a solution that works for you. | |||
| | #8 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote i uploaded the page I had on my hard drive to my own webpage ... unfortunately, i didn't save the bigger pics the thumbnails link to. http://www.geocities.com/axiomdhds/power.htm | |||
| | #9 (Link) | |||
| | Re: workarounds to having equipment that don't auto turn on or have a remote I've got a situation I've got to figure out. I have my Behringer EP2500 in the rear of the room next to my DIY sub. Everything else is in the front and powers on with the remote macro. I have to manually turn the EP2500 on and off... and forget to most of the time. I suppose I could get another Panamax unit and place one of them at the EP2500 and run a long 12 volt trigger cable back there from my preamp to the Panamax. I just hate to spend a couple hundred dollars for a Panamax unit. | |||
| | #10 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote sonnie, too bad you guys have 110v which makes the ep2500 come close to the 10A limit of the relay ... otherwise you could build the 12v trigger. what about building a switch (pictured above) that's close to your listening position. | |||
| | #12 (Link) | ||||
I'm rather curious to know why you need a 12v. relay to switch the mains... I realise that most commercial power switches are only rated at 10 amps., but you can get Industrial switches that will handle 20 amps. or more, without the complications involved in using a relay.. | ||||
| | #13 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote My 12V Trigger AC Outlet blog entry. | |||
| | #14 (Link) | ||||
it's like the behringer had a 12v trigger. | ||||
| | #15 (Link) | ||||
but I lost all my favorite links when I formatted my pc sometime back. thanks for sharing. | ||||
| | #16 (Link) | |||
| Re: workarounds to having equipment that don't auto turn on or have a remote For equipment like the EP2500, I would consider mounting the relay inside the unit itself... Perhaps something like this: http://relays.tycoelectronics.com/da...s/S8990_DS.pdf. | |||
| | #17 (Link) | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Using the Auto Set-up and EQ Features in an SSP or Receiver | Sonnie | Home Theater Components | 10 | 08-03-08 07:18 PM |
| Mitsubishi 42" widescreen will not turn on | stymee | Manufacturers Service and Support | 15 | 11-29-07 04:12 PM |
| Auto Set-up/EQ Amp | Alaric | BFD Forum | 1 | 07-18-07 07:40 AM |
