| General Discussion I have ghost in my HT room...Discuss I have ghost in my HT room... in the Home Theater | Audio and Video forum; I have ghost in my HT room... Today was a fun day... made it to Movie Gallery early enough this morning to pick up a few new ... |
| | #1 (Link) | |||
| | I have ghost in my HT room... Today was a fun day... made it to Movie Gallery early enough this morning to pick up a few new releases, including War, Shoot 'em Up and Resident Evil: Extinction. A lazy day, but fun. Earlier tonight I watched War and then RE:E consecutively, which is nothing unusual for me to watch several movies back to back. About midway of RE:E all of the sudden my preamp and HD-DVD player power down. The pj was still on. I powered both back on and returned to watching my movie. Then about 3/4 way thru the movie it does it again. Then once again near the end. The only thing I can figure is my Panamax M5100-EX "Always On" outlets are losing power. Both the preamp and HD player are plugged in there and it's clear it is powering down. I thought it might be the preamp somehow sending a 12v power down signal to the Panamax, but then the HD player would not shut down because it's always on (until I power it down via the remote macro). With both of those powering down and being plugged into the "Always On" outlets... it has to be the Panamax. Thankfully it's lifetime warranted and they will replace it. | |||
| | #2 (Link) | |||
| Re: I have ghost in my HT room... Very strange. I have a theory. I also rented War yesterday, but on Blu-ray from Blockbuster. I watched the entire movie without issue. Great action and a phenomenal soundtrack, by the way. I didn't get Residnet Evil Extinction, though. Hmmmmmm, maybe it could be the evil in RE:E???? LOL. I take it that this is the first time this has happened for ya? | |||
| | #3 (Link) | |||
| Re: I have ghost in my HT room... When I got my RX-V2700 I was watching a movie (Don't recall which one) ... but suddenly the receiver turned off by itself ![]() The reason was ... ...I connected a small fan in the outlet on the back of the receiver .. I knew it was a no,no but I did it anyways ... problem is solved, I used a wall outlet ![]() | |||
| | #4 (Link) | |||
| Re: I have ghost in my HT room... Is it possible that you had several brownouts in your area? some equipment can be sensitive to drops in line voltage below 100volts causing it to shut down. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||
| | #5 (Link) | |||
| | Re: I have ghost in my HT room... Yeah... this is the first time it has happened. After the third time I did get up and walk into the house and asked my wife if anything weird had been going on with the power and she said she had not noticed anything. The 5100 has a row of LEDs on the front panel that show the voltage and I didn't notice anything irregular there, although I wasn't particularly paying that close attention to it either. Rather than send that unit back to Panamax and have to be without until I get a replacement, I think I will swap it out with my older Panamax that was in my system previously. It always worked fine. I'll use this one on the rear sub amp. Maybe with nothing being plugged in except the sub amp, it will be okay. There will be nothing plugged into the "Always On" outlets back there. | |||
| | #7 (Link) | |||
| | Re: I have ghost in my HT room... How could it not be the outlets losing power? 2 sources are plugged in and both sources get turned off. If I plug a lamp into one of the outlets, I'll have to sit there with a lamp on and watch a movie until it does it again, just to see the lamp blink. ![]() | |||
| | #8 (Link) | |||
| | Re: I have ghost in my HT room... Why not just swap it out with the older Panamax that was in your system previously? ![]() Actually it seems kinda strange that the “always on” outlets would act up. The switched ones, yeah, since they usually have a relay or something triggering them... Regards, Wayne | |||
| | #10 (Link) | |||
| Re: I have ghost in my HT room... Well if noone else is going to do the joke: when theres something strange, in you theatre room Who ya gonna call? "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| | #13 (Link) | |||
| Re: I have ghost in my HT room... "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| | #15 (Link) | |||
| Re: I have ghost in my HT room... That ghost!!!! he gets around ![]() Today for no apparent reason my main amp decided to develop a ground loop buzz to end all buzz's. It was so bad that I could here it over white and pink noise. Nothing was changed or moved when the problem occured it just started. I did manage to fix the issue, but it involved opening the amp up and making a physical conection between the mains ground and the 0V plane on the PSU. This was never part of the original build and should not have been the cure as it was definetly not the cause. "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Room-in-room and acoustics | atledreier | Home Theater Design and Construction | 5 | 12-09-07 03:50 PM |
| Calculating Room Modes - Odd Shaped Room | Bob in St. Louis | Home Theater Design and Construction | 25 | 02-20-07 12:15 PM |
