| General Discussion HDMI Question and Other Help NeededDiscuss HDMI Question and Other Help Needed in the Home Theater | Audio and Video forum; HDMI Question and Other Help Needed After getting a new Sony Bravia for Christmas and upgrading my Directv to the HD DVD, I went to Circuit ... |
| | #1 (Link) | |||
| HDMI Question and Other Help Needed After getting a new Sony Bravia for Christmas and upgrading my Directv to the HD DVD, I went to Circuit City to purchase a new HD compatable A/V Receiver. I was told that if my receiver had 2 HDMI inputs and 1 HDMI output, I would have my 5 speaker surround system hooked up (with the speaker connections), with only the 3 HDMI cables. I could run 1 HDMI from the Satellite to the receiver, 1 HDMI from the DVD player to the receiver and 1 HDMI cable out from the receiver to the TV. Based on this simple logic, I purchased a Sony DG510. Well, it didn't work as he said. I guess one of my questions would be that the DG510 said it was HDMI pass through and was wondering if this was the problem?? Is what he said true or is the DG510 HDMI pass through the problem?? Any help will be greatly appreciated. Thanks, bunks10 | |||
| | #3 (Link) | |||
| Re: HDMI Question and Other Help Needed I'm sorry...the audio did not work until I hooked up the optical digital audio from the satellite to the receiver. Also the front speakers don't have any sound coming from them even though the receiver has front A&B lit. | |||
| | #4 (Link) | |||
| Re: HDMI Question and Other Help Needed I don't know your particular receiver but there should be a menu option that tells the receiver what signal it needs to look for it is probably only looking at the optical input and is ignoring the HDMI input. ALso do you have the option in the DVD players menu set to send audio out through HDMI? Also you shouldent have both speaker A&B selected as your only using one set of front speakers right? Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #6 (Link) | ||||
| Re: HDMI Question and Other Help Needed If I were you, I would return that Sony AVR and get a better model which will take in audio via HDMI. Yours will not. To get audio you need to use the two optical Toslink inputs or the single S/PDIF coax input -- a total of 3 digital audio inputs, but not on HDMI. Quote:
| | #7 (Link) | |||
| Re: HDMI Question and Other Help Needed I don't know how much you paid for the Sony ... but they have the Onkyo TX-SR605 online for $469.99 and that will get Audio/Video thru HDMI ... and also is a 7.1 instead of the 5.1 (Sony) ![]() ![]() You can keep the Sony (if it was a good deal) ... but you have to use an optical or coaxial cable to get the audio ... What I don't like when you connect the DVD, SAT, etc. to the receiver is that you always have to turn on the receiver if you want to watch something (even TV) ... that's why I always connect everything to the TV (audio/video) and just the audio to receiver, so I can choose if I want to use the receiver or not..![]() ![]() ... if you want to do it that way, just connect the HDMI to TV and the optical/coax to receiver ![]() ![]() | |||
| | #8 (Link) | |||
| Re: HDMI Question and Other Help Needed Thanks all so far....I will return the receiver and find a better model. I did some more testing and found the receiver will not provide any sound from the front speaker inputs, even when just trying to listen to the radio. The receiver has a problem anyway. But my last question, then is, if I have a good receiver with the HDMI inputs and outputs and I wanted the receiver to be my central component, will just the HDMI cables from component to component provide my surround sound while watching the Satellite?? thanks, bunks10 | |||
| | #9 (Link) | ||||
| Re: HDMI Question and Other Help Needed Quote:
![]() .. if you're not in a hurry, you can get good deals online (look here at the electronic store) ... it will be cheaper than most stores ![]() If you're not using HDMI to connect your component, you will need an optical/coax cable for audio and a cable for your video (component cable red, blue, green is better than others) ![]() ![]() | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Sconces needed | rick12667 | Home Theater Seating and Accessories | 9 | 04-24-08 11:41 AM |
| 25' HDMI cable needed | rick12667 | Remotes | Cables | Accessories | 4 | 12-10-07 03:46 PM |
| Help needed to pick a new sub | co56 | Home Audio Subwoofers | 3 | 11-13-07 02:23 PM |
| HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? | geekwithfamily | Home Theater, Audio and Video News | 2 | 02-27-07 11:11 AM |
| HDMi (dvd player) to reciever advice needed | gvw | System Setup and Connection | 2 | 02-18-07 10:11 AM |
