| General Discussion Questions about my old Mitsu.Discuss Questions about my old Mitsu. in the Home Theater | Audio and Video forum; Questions about my old Mitsu. I have an old Mitsu WS 55807. It is 8 yrs old,but, works very good. It has 3 "S" connections ... |
| | #1 (Link) | |||
| Questions about my old Mitsu. I have an old Mitsu WS 55807. It is 8 yrs old,but, works very good. It has 3 "S" connections and (480p) (480i) (1080i) component video inputs. It does not have a HDMI connection. My question is will the Dish High Def unit work with this TV ? Will it be a noticeable?Is HDMI that much better? Thanks in advance for your help. JC | |||
| | #2 (Link) | |||
| Re: Questions about my old Mitsu. It should work with no problem. Just make sure that you set the receiver to upconvert 720p to 1080i, because your Mits will not accept 720p. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #4 (Link) | |||
| Re: Questions about my old Mitsu. Mits is Mitsubishi. What settings are you referring to? "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #5 (Link) | |||
| Re: Questions about my old Mitsu. thanks again, Under setup, AV connection,then AV receiver, there are 4 choices mits1,mits2,other, and none. Right now I have it set to other. Now under advance features there is a video display there are 2 settings 480p and 960i I have no idea where the 960i came from. I don't show that number anywhere else. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Help and Advice on a Mitsu 65" | jack01 | Manufacturers Service and Support | 4 | 07-02-07 11:23 AM |
| Mitsu convergence question... | MOBILE | Manufacturers Service and Support | 2 | 05-28-07 04:17 PM |
| Was my Mitsu damaged by accidental 720p input? | Vader | Video Displays and Processors | 0 | 09-14-06 07:51 PM |
| Mitsu 55819 shutdown | Cap'n Preshoot | Manufacturers Service and Support | 37 | 09-02-06 08:04 PM |
| Board corrosion - Mitsu VS50703 | mike-o | Manufacturers Service and Support | 1 | 09-01-06 09:55 PM |
