| General Discussion Power Consumption of AV Equipment: How much does it cost to run these things?Discuss Power Consumption of AV Equipment: How much does it cost to run these things? in the Home Theater | Audio and Video forum; Power Consumption of AV Equipment: How much does it cost to run these things? So, part of my Popcorn Hour A100 review was to compare the power consumption, and ensuing cost of operation, for ... |
| | #1 (Link) | |||
| Power Consumption of AV Equipment: How much does it cost to run these things? So, part of my Popcorn Hour A100 review was to compare the power consumption, and ensuing cost of operation, for the A100 vs a HTPC. So, I got my hands on a Kill-A-Watt and this is what I found... ----------------- (Item: Power Draw in watts) Popcorn Hour (Standby/Off): 5 Popcorn Hour (Playing 1080p off network): 6 Popcorn Hour (Playing 1080p off Hard Drive): 15 HTPC (Idle): 86 HTPC (100% CPU): 105 -------------------------- While I was at it, I measured the rest of my Home Theater... ------------------------- 51" CRT RPTV (Movie Playing): 142 DVD Player (Movie Playing): 10 AVR (Movie Playing): 60 Sub (Movie Playing): 12 BFD (ON): 4 ------------------------- So, I took my average cost-per-kilowatt (what it would cost to run a 1000 watt device for an hour), including all taxes and delivery charges, and this is what I came up with... ---------------------- My average cost over last year per kilowatt: 16.3 Cents HERE'S THE GOOD PART... Running an HTPC 24/7 versus running the Popcorn Hour 24/7 per year: $122.80 vs $7.14 To leave my BFD plugged in and on 24/7 costs me per year: $5.71 Watching a 2 hour movie on my HT system, in the dark, using the DVD player: $0.07 Watching Sweeny Todd in a Portland theater with 3 other people at 4pm on a Saturday: $40.00 ----------------------------- Hey, this is fun. I will add more items as I measure them. ----------------------------- Equipment that still use power when "Off" Subwoofer on "standby": 8 DVD "Off"/Standby: 4 Powered Speakers (Audioengine A2, no input): 3 ---------- Other items... ----------- 10' strand of Rope Lights: 72 Computer clocked at 1.2GHz Idle: 86 100% CPU: 105 Same Computer Clocked at 2.7GHz Idle: 89 100% CPU: 129 22" LCD Monitor (Light Blue Background): 36 Cable Modem: 7 Router: 4 Toaster Oven: 1190 Cost to pop a bag of Popcorn (3 minutes in 1350W microwave): 1 Cent --------------------------- To figure out your yearly cost, multiply (the wattage) x (Cents per KWH) x ( 0.0876) = Cost in Dollars --------------------------- To figure out your hourly cost, multiply (the wattage) x (Cents per KWH) x ( 0.001) = Cost in cents ----------------------------- Other Devices: 42" LCD = 120w Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #4 (Link) | ||||
| Re: Power Consumption of AV Equipment: How much does it cost to run these things? Quote:
Fixed it, should have been 12, not two. I think another way to look at all of this is, let's say you'd like to buy a new power strip with sequenced switching versus keeping your BFD, SUB, and DVD player on all the time. You could probably save $10 a year on electricity. Not a whole lot, but figure you're going to have that power strip for 5 or 10 years, and all of a sudden, you just saved $100. It's enough to make you want to go out a buy a new power strip. I like this one: http://www.tripplite.com/products/pr...productID=3500 ![]() Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #5 (Link) | |||
| Re: Power Consumption of AV Equipment: How much does it cost to run these things? 42" LCD added, not much power savings over 51" CRT RPTV. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #6 (Link) | |||
| Re: Power Consumption of AV Equipment: How much does it cost to run these things? Wow, very interesting? Much less wattage on the theater than I assumed. What that averaged over a time period of peaks and low level volumes? 2- 58" King Sound Prince Electrostat Loudspeakers 2- Infinity Audio PS210 Powered Subs to got with Electrostats Jensen Center (soon to be replaced by: 1- Definitive Audio CLR2300 Center Channel 4- Technic SB-T100 (surrounds) 3- JL 10" Subs Kenwood VR-6070 THX Receiver --- Denon AV600 ---- Technic SU-Z900 Acer XD1170 Projecter --- 120" Screen | |||
| | #7 (Link) | |||
| Re: Power Consumption of AV Equipment: How much does it cost to run these things? I put the movie on a scene with lots of sound coming out of all the speakers, set the level to normal listening, and averaged the wattage of all the equipment. The TV also fluctuated from light to dark scenes, so once again, I just averaged it. Admittedly, my setup probably isn't running as high as others. I have pretty basic equipment, and, thanks to shared walls, am running far below 85db, so your results, if you're really cooking, might be double mine. The biggest thing is to find those pieces of equipment that use energy even when they're "off". Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #8 (Link) | |||
| Re: Power Consumption of AV Equipment: How much does it cost to run these things? Yeah, i've got 2 subs that stay on standby, plus both my fronts and center are powered and probably draw some power even when off... I am curious to know how much they constantly are drawing out. 2- 58" King Sound Prince Electrostat Loudspeakers 2- Infinity Audio PS210 Powered Subs to got with Electrostats Jensen Center (soon to be replaced by: 1- Definitive Audio CLR2300 Center Channel 4- Technic SB-T100 (surrounds) 3- JL 10" Subs Kenwood VR-6070 THX Receiver --- Denon AV600 ---- Technic SU-Z900 Acer XD1170 Projecter --- 120" Screen | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| How much did your speaker system cost? | hyghwayman | Home Audio Speakers | 94 | 07-17-08 10:26 PM |
| 2007 and things to come | wbassett | Computers | Games | HTPC | Digital Devices | 1 | 12-04-07 07:56 AM |
| Quality vs Cost | brandonnash | DIY Speakers | 25 | 06-20-07 10:22 PM |
| Power consumption / conditioning | Owen Bartley | Remotes | Cables | Accessories | 7 | 05-30-07 10:08 AM |
| One of those things I should know.. | JCD | REW Forum | 1 | 05-17-06 12:08 PM |
