upscaling? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
upscaling?
Discuss upscaling? in the Home Theater | Audio and Video forum; upscaling? I'm not sure if I am in the right place to ask this. But what, exactly is upscaling? From what ...
Old 03-05-08, 06:45 PM   #1 (Link)
Alias: ratchet
Loc: southern indiana
scott's Avatar
User: #4737
Since: Dec 2006
scott is offline
upscaling?
I'm not sure if I am in the right place to ask this. But what, exactly is upscaling? From what I have read it means simply playing older movies on a blu-ray player? I have been out of circulation for several months and just getting back to Home Theatering. Kinda Scary.
Old 03-05-08, 06:50 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: upscaling?
Upscaling is done in many DVD players of all varieties, not just BluRay. It can also be done in an AVR, outboard processor, and is done in virtually any display. It is technically a re-sampling of the data to a higher rate, usually with filtering applied to reduce aliasing and other effects.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 03-05-08, 08:12 PM   #3 (Link)
Alias: ratchet
scott's Avatar
User: #4737
Since: Dec 2006
scott is offline
Re: upscaling?
A-ha, thanks for the info. And BTW, "Out of circulation" does not =Jail! I was in other states for Construction. (just thought I would clarify!)
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Is there a high quality 7.1 with true upscaling for under 1000.00 Scuba Diver Home Theater Components 2 10-28-07 11:40 PM
Upscaling 1080i or 1080p???? salvasol Home Theater Components 7 04-30-07 05:18 PM
Upscaling- Let the TV do it or a Scaler/High Def DVD player? wbassett Video Displays and Processors 7 03-17-07 04:21 AM
Decent cheap upscaling DVD player? (cheaper than oppo) basementjack Home Theater Components 2 12-30-06 12:34 AM
Need a Non-Macroblocking Upscaling DVD Player Quant Home Theater Components 3 06-22-06 08:17 PM
Mach 5 Audio
