Onkyo TX905 to Denon DVD 2930 problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss Onkyo TX905 to Denon DVD 2930 problem in the Home Theater | Audio and Video forum; Onkyo TX905 to Denon DVD 2930 problem Has anyone had any trouble with the Onkyo 905?? I have a Denon 2930 DVD player and when i connected ...
Old 03-08-08, 08:07 AM   #1 (Link)
New Member
Alias: layhe
Loc: Doncaster
User: #17810
Since: Mar 2008
layhe is offline
I have a Denon 2930 DVD player and when i connected it to a new Onkyo TX905, it locks up the dvd player, i am using 1.3a Hdmi cable, despite the DVD player only outputting 1080i. The only fix is to unplug the DVD player, power cycle the DVD player, but it will do it again when i plug it back in.
This appears to be serious by the fact of the locking,....has anyone experienced this?? Has anyone got any ideas why this would be?? Am i missing some setting information?
Any help would be great, i have pulled my hair out over this!!!!
Old 03-08-08, 11:33 AM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Re: Onkyo TX905 to Denon DVD 2930 problem
Do you have a setting in the DVD players menu to output 24fps? turn it off. also set up the player to output 720p and see what happens?
Go into the Onkyo's menu and turn off the setting that controls the power on signal through HDMI (I cant off the top of my head remember what its called)
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-08-08, 12:35 PM   #3 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Welcome Laihe
I suggest to take a look at the troubleshouting on the manual ... if you can't find the answer, your best option is to contact Onkyo and Denon to get a fix
Good Luck
Old 03-10-08, 05:02 PM   #4 (Link)
New Member
Alias: layhe
Loc: Doncaster
User: #17810
Since: Mar 2008
layhe is offline
Hi Tonyvdb and Salvasol, firstly Tony, thanks for the constructive ideas, i have tried what i can and no luck though i did get the serial number wrong, it is the 2910 that i have. Thats what happens when you don't double check! Any more ideas, its ok on s-video and the amp will upscale this, it is just not the preferred connection method.....
Salvasol, i have contacted onkyo and as yet i have had no answer....
thanks
Old 03-10-08, 05:11 PM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Hmmmm, did you even try dropping the output of the Denon to 480P? Its sounding like a handshake problem between the Denon and the Onkyo. Just for interest sake did you try another HDMI cable?
Nintendo Wii
Old 03-14-08, 02:53 PM   #6 (Link)
New Member
Alias: layhe
Loc: Doncaster
User: #17810
Since: Mar 2008
layhe is offline
Yeah, tried all sorts, including the cable. I have been informed that a newer version of firmware may be the solution so have a disc coming with this firmware. I have gone out and purchased a new Toshiba HD-EP35 dvd player and that does not play sound sometimes, sometimes it doesn't play dts, sometimes it plays on PCM, all with the same dvd disc, through HDMI. Is there any known firmware problems with the ONkyo 905, i know there is with the 605 and that is related to the audio bitstream, so surely this is nearly the same???
What do you think??
Old 03-14-08, 02:55 PM   #7 (Link)
New Member
Alias: layhe
Loc: Doncaster
User: #17810
Since: Mar 2008
layhe is offline
And Onkyo got back to me informing me that they didn't have a clue!! I have since got back to them with the new unfortunate senario!!
Thanks to anyone that can help!!!!?????
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Which reciever Onkyo TX-SR875 or Denon 3808ci MatrixDweller Home Theater Components 34 06-03-08 11:08 PM
Which is better Onkyo TX-NR905 or Denon AVR-4308Ci? Luclambert Home Theater Components 21 04-02-08 08:55 PM
+/-: Denon 4308CI, Onkyo 905, or Arcam AVR350 killerdusty Home Theater Components 11 04-01-08 03:37 AM
Onkyo 805 hmdi to Mitsubishi WD65734 Problem docsavage System Setup and Connection 3 11-23-07 12:18 AM
Onkyo 805 or equivalent Denon? tonyvdb Home Theater Components 4 11-08-07 11:35 PM
Mach 5 Audio
