General Screen DiscussionDiscuss d65 2 degrees vs d65 10 degrees in the Screens forum; d65 2 degrees vs d65 10 degrees ok this caught my eye at the other place because someone was still touting behr silver screen and every time ... |
Views: 1021 - Replies: 8
| d65 2 degrees vs d65 10 degrees ok this caught my eye at the other place because someone was still touting behr silver screen and every time i look at that paint it looks both slightly lilac and slightly baby blue to me. it was stated over at the other venue that behr measured silver screen to be a neutral gray at 205 206 205 but the one thing that jumped out at me was that these measurements were taken at d65 10 degrees. everything i have seen thus far in the way of referencing neutral gray resulted in RGB measurements being taken at d65 2 degrees so what bearing does this variation have because the silver screen stated measurements posted here sure seem to provide an indication of what i'm seeing (weak green, stronger red, much stronger blue) | ||||
| | #2 | ||||||
| Re: d65 2 degrees vs d65 10 degrees I wiki'd it! ![]() Quote:
![]() From a chart here on white points, you can see that the difference between 2 degree and 10 degree is about .001- .002 or so. Bill will pipe in shortly and probably more in depth! ![]() mech | ||||||
| | #3 | |||||
| Re: d65 2 degrees vs d65 10 degrees Not much to add... it covers a 10degree area while the other only a 2 degree area. More is sampled so you get a bigger section. PocketSpec uses 45 degrees, but they are selling colorimeters and not full spectrophotometers. Quote:
"Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #4 | ||||
| Re: d65 2 degrees vs d65 10 degrees Calibration is typically based upon the 2 degree CIE1931 xy coord system. It may seem old, but our eyes haven't changed and short of new discoveries in the way we see or perceive this reference probably wont change much. In the CIE chart D65 is a point x.313,y.329 and it can be black all the to white as this point actually has a 3rd dimension to it. They all (should) equal x0.313,y0.329 D6500 as an iluminate is like an overcast sky, or viewing from under a shady tree. Measuring a reflective colour is hard without an accurate D6500 illuminance that creates the full spectrum of light as we see it. Our eyes are better at seeing illuminance as we have billions of rods, where the colour function we have only millions of cones, and these are arranged to see straight ahead, hence the central narrow angle of illuminance and colour accuracy. As the angle widens our colour interpretation changes as does our sensitivity to such artifacts as flicker which is a function of our 22 cycles per second eye/brain resolution. ![]() Ive just finished reading 'Intangle Minds' and now Im not sure about reality anymore in that none of this could be real. Quantum mechanics...if it doesn't scare you, you don't get it. back to work now....bad boy... Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #6 | |||||
| Re: d65 2 degrees vs d65 10 degrees Quote:
![]() Also this is why spectrophotometers are such an expensive and precise piece of equipment. They also require routine calibration testing and recertification from an authorized and certified facility. They may remain accurate well after the calibration date expires same as a car will certainly still run after the inspection expires, but unlike the car that only needs to get us from point A to point B and it doesn't matter how fast (but should as far as how safely), a spectrophotometer can't be guanteed to be within specifications once the calibration is expired. A person could use it for their own personal color space as long as they don't try to reference to other values taken from calibrated units. It could be accurate and the same, or it could be off. To emilinate questions, units are calibrated and recertified on a regular basis. Now, one thing to mention is there are and will be slight variances between two units but those variances should be very small- so small in fact nobody would contest it as a totally different color. Other variables could be the source being tested. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||||
| | #7 | |||||
![]() mech | |||||
| | #8 | |||||
![]() Good read smoke? mech | |||||
| | #9 | ||||
| Re: d65 2 degrees vs d65 10 degrees Oops mis spulled that. 'Intangled Minds' Interesting read for sure. The chap who wrote this book was part of the PSI experiments like remote viewing and so on. If one is interested in the idea of quantum mechanics and things like effects of 'influence' on the fuzzy world we are part of you will find it interesting. For some the concepts are hard to except. btw, if you read this book, my sig sentences will make sense. Yes it is true, light does differ in how and when it is received......Einstien' Spooky stuff at a distance' back to subject matter, our current reality..... Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? Last edited by <^..^>Smokey Joe; 10-08-07 at 10:22 PM.. | ||||
