Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Projection Screens > Screens > General Screen Discussion
  Discuss Need help picking screen! in the Screens forum; Need help picking screen! Also, i didn't quite understand what you mean by the "mica" and the "false gain" thing. I take it you ...
Views: 1086 - Replies: 46
Old 11-07-07, 10:54 AM   #11
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Re: Need help picking screen!
Also, i didn't quite understand what you mean by the "mica" and the "false gain" thing. I take it you still recommend the True Value N8 and such?
How do you feel about the screen goo offerings and the rest of those guys?
Old 11-07-07, 11:42 AM   #12
Shack Moderator
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Dale,
Sorry for the confusion! Yes the N8's are fine. The problems start when people start to add what I like to call 'popsicle stick' paints in order to add 'pop' to a screen. I've yet to see any homemade mix achieve this. We've recently tested pearlizing medium mixed with poly and found what I'd call a pretty major color shift.
So cut and dried, if you go with an N8 from True Value or Sherwin Williams you'll be fine.
The Fashion Grey will be fine as well. I use it and it works well for me. But the addition of the Behr Clear Matte Poly caused it to stray from what we call neutral. If you don't have to put poly on it, you'll be fine. If you have to put poly on be aware that it strays up near the green territory.
And welcome to the Shack!
mech
Gain Readings
Spectro Readings - not up to date but will be soon
Old 11-07-07, 11:45 AM   #13
Shack Moderator
Alias: mech
mechman's Avatar
User: #6446
  mechman is offline
Dale,
Check back when you get the FG and if it hot spots. The only reason to add poly was for hot spots. Also, if you have to cut it to size I'd like a small sample of it if you could send it to me. I have no non-poly'd FG to get readings from.
mech
Gain Readings
Old 11-07-07, 05:57 PM   #14
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Sure thing... i'll definitely check back with you when it arrives... Lowes said it could be anywhere from a couple days to November 19th! I definitely hope it gets here before then because i'm trying to have a Sunday night football event here on the 18th.
I do have to cut a substantial piece off, as i'm going to have only about a 70" screen to start. I don't have a huge living room, and there's always the wife factor. I'll definitely up the size when i have a dedicated room or the like.
How big a size would you like?
Thanks
Old 11-07-07, 07:29 PM   #15
Shack Moderator
Alias: mech
mechman's Avatar
User: #6446
  mechman is offline
All I need is a 1"X1" square. It'll fit in an envelope and only cost a stamp!
Let me know when you get it and I'll pm you my address.
mech
Gain Readings
Old 11-07-07, 07:58 PM   #16
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Sure thing... i'll let ya know
Old 11-07-07, 09:10 PM   #17
Shack Moderator
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Exaneo wrote: View Post
Well...
Unfortunately i've already ordered the Fashion Grey... but thats what you use right? I went with this particularly because i saw your screenshots and was under the assumption thats what you were using. They looked pretty good.
Glad to hear there are no cone issues.. does applying the Behr poly make a significant difference - or i guess the question would be, do you think it would help with my 2000 lumen ax100u? Don't know if the issue was with higher lumen or lower lumen, or if it matters at all.. i just know that some people had issues where others didn't.
Well at least it seems you're happy with your fashion grey... that gives me hope knowing i probably won't be nearly as critical as you, being an entry level DIY screener.
At least i'm starting at what seems like a good place.
Honestly, you should be fine with Fashion Grey. It's not that it's 'bad', it really does perform very good, but if there is a better balanced option out there that's what we are going to test and ultimately recommend. Acceptable is perfectly fine, but I do think DIY developers strive for optimal or 'best' even though I hear a lot of 'close enough' comments. We really can do better than that, which is one thing I do strive for. The other is KISS, and keeping things easy for people to do.
One thing you will have to do is poly coat it to make it more diffusive and knock down the specularity or you'll have some hot spotting with a projector that bright. Also before making any final conclusions, test all your settings. You'll most likely find one that will pop in and look the best.
You'll even run into some of the very same issues with commercial screens, the biggest difference is the cost factor though.
Try to take a picture diary of your screen process, that's the most benificial to everyone. People always love to see a project unfold and see the steps from start to finish.
Old 11-07-07, 09:30 PM   #18
Shack Moderator
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is offline
Great, thanks.
How is the off-axis viewing with this stuff? I saw a gain chart somewhere around here and it looked like there was a pretty dramatic falloff even at 50 degrees, but i'm not sure if i was reading that right.
If i primed and painted it with a True Value N8 or something, would that give me better off axis viewing or not?
One thing to keep in mind, 50 degrees is just half the viewing cone, so if you see a half gain drop off at 50 degrees, that's a 100 degree viewing cone which is a large viewing angle.
As far as painting a sheet of FG... that is such a waste, like someone getting Do-Able and painting it! If it comes down to that maybe check and see if someone in your area wants to take it off your hands and we can get you going with a less expensive substrate or painting option. But I do think you'll be happy with FG. Worse case, and this would apply to any screen, if you feel the image is 'too bright' then check into an ND filter.
As far as ambient performance, here is an N8 with lots of sunlight, not just a room lamp...
And with the lumen output of the Panny Ax100u you don't have to worry about whites, the shots above and the ones below with lights out are with a projector rated at 1700 max lumens.
And a couple of off axis shots to show this N8 screen has a very wide viewing cone...
Old 11-07-07, 10:13 PM   #19
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
  cynical2 is offline
mechman wrote: View Post
mech
Mech, I'll send you a square of FG...I've got samples here. Wish I knew before I sent you that last package.
Need any other WA laminates?
Old 11-07-07, 10:32 PM   #20
Shack Moderator
Alias: mech
mechman's Avatar
User: #6446
  mechman is offline
What else do you have? I didn't realize you had them either I guess! I have DW and Platinum but I really need a FG that doesn't have poly on it. And maybe a Dove Grey too! Whatever you got send it along!
mech
Gain Readings
« Home Theater Shack > Home Theater | Audio | Video > Projection Screens > Screens > General Screen Discussion »
Bookmark and Share
Dish Network
