General Service and Technical InformationDiscuss Problem with Crown 402 amp. in the Service | Support forum; Problem with Crown 402 amp. Hi guy's, I am looking for your expert opinions on this one. I have a crown XLS 402 and the ... |
Views: 505 - Replies: 9
| Problem with Crown 402 amp. Hi guy's, I am looking for your expert opinions on this one. I have a crown XLS 402 and the other day it made a loud pop from the left channel and then was fine. I thought it was just one of those things but it happened again yesterday and today I got the pop followed by a whole lot of crackling that lasted about 2-3 minutes and is now working fine again. Could this just be the amp letting me know that the channel is not long for this world or could it be something else like a cable? It is a used amp so I don't know if it would be worth getting repaired. What say you.... ![]() | ||||
| | #2 | ||||
| Re: Problem with Crown 402 amp. Sounds like a short somewhere or a loose wire to me. Are you pushing the amp really hard? | ||||
| | #3 | ||||
| Re: Problem with Crown 402 amp. I am only running the amp at half gain. It actually doesn't matter how the level is at the time because it happens at low volume also. What confuses me is that it happens and then goes away and works fine. ![]() | ||||
| | #4 | ||||
| Re: Problem with Crown 402 amp. Play your sub at a low volume and turn the left gain knob up and down slightly. If the crackling sound starts then you have a dirty control. That happened to me on a volume control of a Pioneer receiver. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #5 | ||||
| Re: Problem with Crown 402 amp. This could also be a more serious problem, There may be a what is known as a cold solder joint and it is letting go when it gets warm causing your "pop" sound. If your handy with a solder iron it is fixable but you would need to open up the hood and have a look around. Its probably going to be easy to spot as the joint could have some signs of burning or arcing if its on a high current area. Just be aware that there will be alot of power stored up in the capacitors that could kill you if you get zapped even if the power is off and unpluged. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #6 | ||||
| Re: Problem with Crown 402 amp. I know exactly what you mean, I have an old RS that has a dirty control but what I am getting here is different. Last edited by tcarcio; 03-23-09 at 04:58 PM.. | ||||
| | #7 | |||||
| Re: Problem with Crown 402 amp. Quote:
| | #8 | ||||
| Re: Problem with Crown 402 amp. One quick question. I mentioned buying the ep2000 and my mains are rated for 600w, this amp does 750w so I know that will be fine, My question is should I spend the extra 50 bucks and get the ep4000? It does 1400w and with my mains rated for 600w would it just be a dumb idea? | ||||
| | #9 | ||||
| Re: Problem with Crown 402 amp. Sorry I missed your post. I am not really that familiar with these amps. The question would likely get more response in the proper forum for amps. Based on your info provided, however, it seems like little to invest to get a bit more headroom. That can never hurt. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #10 | ||||
| Re: Problem with Crown 402 amp. Just wanted to let you all know that it was a bad channel in the art cleanbox and not the amp so I am happy about that. ![]() | ||||
