HDTV | Video Displays | ProcessorsDiscuss 24p worth 600 bucks?? in the Home Theater | Audio | Video forum; 24p worth 600 bucks?? Any one have experience with 24p playback plasmas? I am getting a good deal on a plasma which is making ... |
Views: 888 - Replies: 8
| 24p worth 600 bucks?? Any one have experience with 24p playback plasmas? I am getting a good deal on a plasma which is making me change HT upgrade priorities (was about to build a couple subs) but should, nonetheless be totally awesome. I'm looking at 2 models: The Panasonic PZ800U and the PZ85U. One of the major differences between the two is that the 800U has 24p playback which I've heard is good but have never experienced it. The price difference between the two sets is roughly 600 bucks. Is the 24p feature worth it? I currently don't own a blu-ray player but will eventually so the feature won't benefit me in the short run but I'd like some enthusiast opinions on using 24p. I am also one who upgrades almost never so I will be using this set until it croaks. | ||||
| | #2 | ||||
| Re: 24p worth 600 bucks?? C-net didn't care for the 24p mode: http://reviews.cnet.com/flat-panel-tvs/panasonic-viera-th-50pz800u/4505-6482_7-32886472.html Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: 24p worth 600 bucks?? Certainly not worth $600 all else equal, IMO. At best you lose some judder. At worst you have to deal with some sloppy processing that the set wraps up with the 24p capability. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #5 | ||||
| Re: 24p worth 600 bucks?? I have experience with my Kuro Elite and 24 frames per second. Would I have paid $600 less for the same tv without it...probably. Is it very nice...certainly. Although the Pio's seem to work better than the Panny's in this regard. '@ 120Hz' is LCD only and they have enough motion issues to deal with to be worried about judder. | ||||
| | #6 | ||||
| Re: 24p worth 600 bucks?? I personally notice judder ALL THE TIME. It bugs me, so I would upgrade given the opportunity. If you don't notice judder then it may not be worth it for you. | ||||
| | #7 | ||||
| Re: 24p worth 600 bucks?? Do you only notice it on crawling text though? | ||||
| | #8 | ||||
| Re: 24p worth 600 bucks?? Nope just about any panning scene. Probably just because I've trained my brain to look for it....doh | ||||
| | #9 | ||||
| Re: 24p worth 600 bucks?? Well, to be fair...once you see it removed, later seeing it there is very distracting. | ||||
