Banggood.com Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! StereoList Shop Amazon! SVSound Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Chase Home Theater: Ushering a new generation of super charged home theater equipment. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Genelec: Active Speakers and Speaker Systems SpectraCal: Specializes in the tools and training necessary to achieve images representative of the content creator’s intent for viewing environments.
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater - Video > HDTV | Video Displays | Processors
Views: 3099 - Replies: 10
Old 12-27-08, 07:59 PM   #1
muff
Since: Dec 2008
orlando, florida
  madman666333 is offline
Hitachi 53fdx01b....Reset Back To Factory Settings?
alright so my set was just fine it had a slight blue offset nothing serious, then i went in to the service mode and tried to adjust it, well now the red is way off and i cant get it to go back. its only affecting the lower half of the screen. ive tried adjusting it for quite awhile now and no luck. is there a way to reset back to factory settings? it almost looks like the red convergance ic is blown except for just the lower half. im so mad at my self. im just too much of a perfectionist, now its not watchable any more. first the red horizontal line was just slightly off then it was completly bent and now im gonna post a pic. i cant believe i did this.
[IMG][/IMG]
[IMG][/IMG]
Old 12-27-08, 09:58 PM   #2
HTS Administrator
lcaillo's Avatar
Tech Guru
Gainesville, FL, USA
My Photos
  lcaillo is offline
Re: Hitachi 53fdx01b....Reset Back To Factory Settings?
You exceeded the range of some of the controls. There is no reset to the factory settings, only a reset that clears all convergence data and you have to do complete geometry and convergence. I do not recommend that. You need to start moving the red at the edges back to the middle a little at a time until you find the parameter that is out of range.
"I attribute the little I know to my not having been ashamed to ask for information, and to my rule of conversing with all descriptions of men on those topics that form their own peculiar professions and pursuits." John Locke
Leonard Caillouet MS, CET, MST, ISF
Need electronics repair? NESDA is the organization for the most professional servicers in the USA and has a great place to start looking for a shop in your area: http://www.tvrepairpros.com/
Old 12-28-08, 11:19 AM   #3
muff
Since: Dec 2008
orlando, florida
ok ill try that. but i dont understand what happened. i only made very small adjustments and next thing you know that happened. once i fix it im never doing that again. im leaving it to the pro`s. well thanks again for your help. hopefully i wont mess it up further. ill keep posting my results.
Old 12-31-08, 07:05 PM   #4
muff
Since: Dec 2008
orlando, florida
well still no luck. ive been sick so i have not spent alot of time on this. im not sure what i did or how im going to fix it. there are adjustment points that i cannot see so im thinking thats where the problem lies. if i go down to the bottom the cursor disapears for two more clicks until it reapears up top. this makes finding the problem spot a little bit hard. how hard is it to do the geometry and convergance reset? at this point it seems easier than this.
Old 12-31-08, 08:29 PM   #5
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photos
  lcaillo is offline
Doing the reset is easy. Adjusting the geometry and convergence from scratch is a major job and not recommended if you messed it up from where you were.
Old 01-01-09, 07:04 PM   #6
muff
Since: Dec 2008
orlando, florida
alright success! thanks for not letting me do the reset. i found a different adjustment mode that made it so much easier. now the set is watchable once more. i dont think ill be doing that again unless i have the service manual. some info. you learn on these sites can help out alot or if you dont fully understand it can mess you up. thanks again lcaillo.
Old 01-02-09, 05:07 PM   #7
muff
Since: Dec 2008
orlando, florida
aaaarrrrrggggggghhhhhh! i guess i needed to save the settings and didnt, so back to square one. but i found out how to save the settings so when i get it back ill be sure to save them! this is turning out to be a big nightmare!
Old 01-02-09, 09:48 PM   #8
muff
Since: Dec 2008
orlando, florida
success once more! this time the settings were saved. what a frustrating ordeal.
Old 01-03-09, 07:43 AM   #9
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photos
  lcaillo is offline
Now you can see why I recommend that the service manual be obtained before trying to mess with the service or convergence adjustments. Each set is different, and you often don't know what you don't know. As a professional, I virtually never go on a call without having the service documatation on a set and reviewing it. Many of them are not intuitive at all, like which button does what on the Hitachis, or the fact that you have to run the auto convergence before exiting the convergence mode on some, but not others.
Old 01-03-09, 09:02 AM   #10
muff
Since: Dec 2008
orlando, florida
well there is an upside to this, the picture quality is much better. no more slight offset`s of red or blue. yeah now that i know what to expect and how tedious this is im not doing it again unless i have to. thanks again for your help.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater - Video > HDTV | Video Displays | Processors »
53fdx01b....., hitachi, stupid
Bookmark and Share
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2012, Home Theater Shack, LLC.
Search Engine Friendly URLs by vBSEO
