Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > HDTV | Video Displays | Processors
  Discuss Calibration with eyeOne LT and HCFR............ in the Home Theater | Audio | Video forum; Calibration with eyeOne LT and HCFR............ I purchase the EyeOne and downloaded the HCFR software so I can learn how to calibrate my pj. Replace the ...
Views: 1569 - Replies: 7
Old 02-13-09, 09:42 PM   #1
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
Replace the lamp and set the pj to factory default, the lamp had 2300 hours and the picture it was a little to dark for me so I decided to change it and see the difference and WOW!! Here is a pic of the new and old lamp side by side( left/old, right/new), you can see the old one is pretty dull.
So far its been OK but there are some things that I don't understand, here are some of the graphs........
Here you can see the 0 IRE is way off, every time I try to fix it it looks really red so I decided to live it alone, is this the right thing to do?
This one 0 IRE and 100 IRE are off, is there anything else I can do to fix it? I know my pj doesn't reproduce pure blacks so is this OK?
Here are some pics of before and after......................
Not really good pics sorry
before
after
I will post the before measurements later, just doing every thing backwardsand more pics (BETTER)
Old 02-14-09, 07:59 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Calibration with eyeOne LT and HCFR............
You might want to identify the model number that you are calibrating.
Your probe cannot be considered reliable at very low light levels, so the variance near black is not necessarily what the set is producing.
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 02-14-09, 08:13 AM   #3
Alias: Rodny
Loc: Millbrook AL
User: #158
lcaillo wrote: View Post
Sanyo PLV-z4
Thanks!
Old 02-14-09, 10:56 AM   #4
lcaillo's Avatar
User: #328
  lcaillo is offline
In general, deviation like this on the low end is the limit of your probe's range of reliable measurement. On the high end, you can try backing off on the contrast to see if that helps. Beyond that, I doubt that you can adjust the extremes without affecting the rest, which looks OK.
Old 02-14-09, 03:26 PM   #5
Alias: Rodny
Loc: Millbrook AL
User: #158
Thanks !!
I will try that this afternoon.
Old 02-14-09, 10:40 PM   #6
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
You need to figure this out so you can come down and calibrate mine.
Old 02-14-09, 11:45 PM   #7
Alias: Rodny
Loc: Millbrook AL
User: #158
Sonnie wrote: View Post
Yeah!!! I need some extra
Here some more graphs.............
before is on the right and after on the left, I started with creative cinema thats the pj factory setting....
0 IRE and 10 IRE still of but I'm just going to live it alone, the rest look pretty good.
more pics......
Name:  IMG_0127 [HDTV (720)].JPG
Name:  IMG_0130 [HDTV (720)].JPG
Name:  IMG_0131 [HDTV (720)].JPG
Name:  IMG_0132 [HDTV (720)].JPG
Old 02-16-09, 08:20 PM   #8
Alias: Rodny
Loc: Millbrook AL
User: #158
Another question
What can I do to fix the Gama a little better
Thanks!!
« Home Theater Shack > Home Theater | Audio | Video > HDTV | Video Displays | Processors »
calibration, eyeone, hcfr............
Bookmark and Share
Dish Network
