| HDTV | Video Displays | Processors Rear Projection LCD & Motion Blur?Discuss Rear Projection LCD & Motion Blur? in the Home Theater | Audio and Video forum; Rear Projection LCD & Motion Blur? I was thinking about replacing my 60" rear projection LCD (SONY 60XS955) with a wall-mounted flat panel because I am ... |
Views: 399 - Replies: 11
| Rear Projection LCD & Motion Blur? I was thinking about replacing my 60" rear projection LCD (SONY 60XS955) with a wall-mounted flat panel because I am now in a smaller room, etc. Anyway, There is all this talk and DEMO-ing of 60Hz vs. 120Hz vs. 240Hz and then response times etc... The difference is definitely noticeable at the store - mainly on scrolling text, but when I went home I didn't really notice it like I did at the store. My picture looks incredible (always has). So, I look at the spec.s on the TV (my SONY) and I don't see anything about response time or ##Hz anywhere. I also didn't see any contrast ratio numbers. Do the rear projection LCDs like ours not have a big of an issue with this? I was thinking I would be upgrading technology, but I'm not so sure anymore. Anyone know? Thanks. Dwaine | ||||
| | #2 | ||||
| Re: Rear Projection LCD & Motion Blur? By the way... I am attaching a diagram of my Family Room. I am currently sitting about 8.5' from my 60" TV. If I bought a 52" and hung it on the wall I would be about 10' from the 52" TV. My kids hate the idea of selling the TV (they like playing their PS3 games on it, as do I), but it really is almost too close... Your thoughts (on this and especially the original post)? Dwaine | ||||
| | #3 | ||||
| Re: Rear Projection LCD & Motion Blur? Hi Dwaine, Welcome to the Shack. Your Sony is capable of displaying up to 1080i at 60Hz you will not see an image if you try to display the newer 1080p 120 or 240Hz images from BluRay DVD's as the Sony will not accept them. Some people like the higher refresh rates however many have reviewed them and said that they look artificial and dont always look as good. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: Rear Projection LCD & Motion Blur? I do understand the 1080i limitation. However, I have yet to not be able to watch a BluRay on my PS3. I have heard the same thing about the higher refresh rates looking artificial. Do you know what the contrast ration is on my TV? I can't find it anywhere? Also, a customer service rep. from Crutchfield said the LCD rear projections don't have a problem with motion blur. Mainly I am just worried that if I buy the Samsung LN52B520 and bring it home, I will be disappointed. | ||||
| | #5 | ||||
| Re: Rear Projection LCD & Motion Blur? Okay, I have been searching and searching for some contrast ratio info. for my 60XS955 and finally found something. I had been searching for ##Hz info. but tonyvdb answered that one for me. I found on a forum that a guy put a calibration "thing-a-ma-jiggy" on the tv and it was around 900:1. WOW! I can only imagine how much better the LN52B530 would look. It's contrast ratio is 60,000:1 with a 6ms response time. I'm still concerned about motion blur - but only if it is going to be worse than my SONY, because I don't notice it on my SONY. Dwaine | ||||
| | #6 | ||||
| Re: Rear Projection LCD & Motion Blur? I dont think it would be any worse than what you have now so if your really serious about it then I would not be concerned about getting it. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #7 | |||||
| Re: Rear Projection LCD & Motion Blur? Quote:
A 60 Hz (or 30Hz interlaced) display will be able to display all Blu-ray's. Just can not take advantage of the video judder reduction from using an exact multiple of 23.976 fps (vertical refresh 48, 72, 96, 120, 240 etc) which film based titles use. Instead the bad old 3:2 pull up is used, as it has been used since broadcast TV first showed movies. | |||||
| | #8 | ||||
| Re: Rear Projection LCD & Motion Blur? But the SONY 60XS955's maximum resolution is 1080i, even through HDMI it wont accept anything more. To take advantage of the 120 or 240Hz refresh rates would it not have to be able to accept 1080p? Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #9 | |||||||||
A higher refresh rate and frame interpolation do not go hand in hand though. On current top model Samsungs you can independtly adjust blur reduction and judder reduction - judder reduction causes the soap opera effect, but blur reduction does just that - reduces blur. Quote:
No way. Ideally you should only be sitting 7.5' from a 60" display to fall between THX and SMPTE standards. With a 52" display you should be sitting 6.5' away. | |||||||||
| | #10 | |||||
| | #11 | |||||
| Bookmarks |
| Tags |
| blur?, motion, projection, rear |
| Thread Tools | |
