| HDTV | Video Displays | Processors panasonic pt52lcx16Discuss panasonic pt52lcx16 in the Home Theater | Audio and Video forum; panasonic pt52lcx16 the tv was working fine went into another room came back and tv was off and wont turn back on. ... |
Views: 199 - Replies: 2
| panasonic pt52lcx16 the tv was working fine went into another room came back and tv was off and wont turn back on. im thinking it could be either a fuse or the power supply. panasonic says to start at the lamp. has anyone else had this problem? of course the set is just out of warranty! | ||||
| | #2 | ||||
| Re: panasonic pt52lcx16 ive been doing some research and found issues with panasonic models blowing the lamps. could this be the issue? the set will not power on, acts like its unplugged. any advice would be appreciated. | ||||
| | #3 | ||||
| Re: panasonic pt52lcx16 Are you getting power to the ballast? Is it trying to fire the lamp? Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
