HDTV | Video Displays | ProcessorsDiscuss Need advice on calibrating 1080i DLP in the Home Theater | Audio | Video forum; Need advice on calibrating 1080i DLP I have a 52 inch 1080i DLP and, other than tweaking the unit's setting, the unit has never been calibrated. ... |
Views: 360 - Replies: 7
| Need advice on calibrating 1080i DLP I have a 52 inch 1080i DLP and, other than tweaking the unit's setting, the unit has never been calibrated. I have started reading about user-friendly calibration tools and discs and wondered if anyone can recommend any of the available tools. Thanks. | ||||
| | #2 | ||||
| Re: Need advice on calibrating 1080i DLP Digital video essentials or AVIA http://www.amazon.ca/Avia-Guide-To-Home-Theater/dp/630551982X are good starts. The THX calibration found on all THX certified DVDs is also a start. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Need advice on calibrating 1080i DLP Tony's right, I use the Avia disc and it is easy to understand and does a good job. | ||||
| | #4 | |||||
| Re: Need advice on calibrating 1080i DLP Quote:
RayJr Serving the Greater Los Angeles Area Denon CI Certified - Certified Audyssey Installer My Home Theater | |||||
| | #5 | ||||
| Re: Need advice on calibrating 1080i DLP I suggest you post the exact model number and be more specific about what you are trying to accomplish, as well as the rest of your system. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
| | #6 | ||||
| Re: Need advice on calibrating 1080i DLP The model is RU52SZ61D, and I would like to calibrate the TV to obtain the best color/brightness/contract/tint/..., etc. I can get out of the system. For DVD, I use the Oppo 983H DVD player. | ||||
| | #7 | ||||
| Re: Need advice on calibrating 1080i DLP SpectraCal has a number of packages available with their software, as does ChromaPure. You could also purchase a meter and use the free HCFR software if need be. I would be wary of buying a used Display 2 meter. Stick to getting a new one as you have no way of telling how well they took care of it. ![]() | ||||
