| HDTV | Video Displays | Processors Crayon on the screen, what to use to get it off? Discuss Crayon on the screen, what to use to get it off? in the Home Theater | Audio | Video forum; Crayon on the screen, what to use to get it off? Our soon to be 3 year old put two lines of crayon on the screen of our 53" Sony RPTV. ... |
Views: 399 - Replies: 5
| Crayon on the screen, what to use to get it off? Our soon to be 3 year old put two lines of crayon on the screen of our 53" Sony RPTV. Before I make it worse by trying to clean it off what do you think would work? the screen is made of some sort of plastic so I dont want to use something that will damage it. Thanks Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #2 | ||||
| Re: Crayon on the screen, what to use to get it off? I would try some warm water and very mild soap and a very soft cloth. If that doesn't work try some cleaner made to clean tv screens......http://www.techlore.com/article/10066/How-to-Clean-Your-TV--Computer--or-Laptop-Screen/ | ||||
| | #3 | ||||
| Re: Crayon on the screen, what to use to get it off? Soft cotton cloth, or better, microfiber. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #4 | ||||
| Re: Crayon on the screen, what to use to get it off? Your little "dust cap poker" is busy, isn't she! ![]() We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #5 | ||||
| Re: Crayon on the screen, what to use to get it off? Yup, she is a VERY busy little girl. The warm water and soap worked! Got it all off without any damage. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #6 | ||||
| Re: Crayon on the screen, what to use to get it off? I would go the opposite way from warm water. I would get some freeze spray and freeze it and see if it flakes off. ...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain. | ||||
