| HDTV | Video Displays | Processors Should I get a video processor?Discuss Should I get a video processor? in the Home Theater | Audio and Video forum; Should I get a video processor? I currently own a Rotel RSX-1550 as an AVR, Sanyo PLV-Z700 as a projector, a Samsung BDP1400 as a Bluray ... |
Views: 136 - Replies: 7
| Should I get a video processor? I currently own a Rotel RSX-1550 as an AVR, Sanyo PLV-Z700 as a projector, a Samsung BDP1400 as a Bluray player and have HD Cable TV (Videotron HD in QC). Would I gain any benefits from getting a separate video processor? Thanks in advance. | ||||
| | #2 | ||||
| Re: Should I get a video processor? For the cost of the processor, No. There would be benefits but given the price of the good Processors that use the Silicon Optix Realta chip or Raon its not really going to improve that much. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Should I get a video processor? I would tend to agree. As a owner of a DVDO edge (found it second hand for a great price) I can tell you that the improvement in PQ was not what I expected. I have noticed blacker blacks which makes the picture more 3 dimensional but thats about it. What it has done for me is more in my head than reality. It has given me the comfort of knowing that short of replacing everything in my home theater with the latest and greatest I am getting the best possible PQ out of my system. That being said the difference between processor on and processor off is negligable. If I had not got such a good deal I would not have bought it. | ||||
| | #4 | ||||
| Re: Should I get a video processor? External video processors are frequently more flawed today than the sources or the displays. In general I would not recommend one. The situations where they are most useful is with an very limited color adjustments in display, anamorphic lens, S-Video and composite video switched to a single input. Common flaws are that they will not pass 24p properly or may corrupt color calculations. Strangely, one of the best implementations are those in Onkyo or Integra products if their features meet your needs. Posted via Mobile Device | ||||
| | #5 | ||||
| Re: Should I get a video processor? Ok, no video processor for me then ![]() Another little question. Am I better off letting the Rotel do the deinterlacing/upscalling (Faroudja DCDi) or the projector itself (TopazReal HD)? | ||||
| | #6 | ||||
| Re: Should I get a video processor? The Faroudja DCDi is a fairly good upscaler so I would think that I would use it, That said try both and see what works best. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #7 | ||||
| Re: Should I get a video processor? Always look at what all options do to the image. The actual implementation is as important as the circuitry used. Even different firmware can make a difference. Posted via Mobile Device | ||||
| | #8 | ||||
| Re: Should I get a video processor? How different can deinterlacing be from different components? I just learned that the Rotel doesn't deinterlace 1080i over HDMI. My PJ does, but would it benefit from some help? | ||||
| Bookmarks |
| Tags |
| processor?, video |
| Thread Tools | |
