Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HDTV | Video Displays | Processors
A couple quick calibration questions
Discuss A couple quick calibration questions in the Home Theater | Audio and Video forum; A couple quick calibration questions Long time reader, first time poster with a couple quick questions regarding TV calibration.... First my equipment -Xbox 360 -PS3 ...
Views: 165 - Replies: 2
Old 10-20-09, 10:29 PM   #1
New Member
Alias: Colt4587
Loc: Kansas
User: #36186
Since: Apr 2009
  Colt4587 is offline
First my equipment
-Xbox 360
-PS3
-46" Samsung model number LN46a530
- Yamaha Receiver model number RX-V663
-Digital Video Essentials Blue Ray Disc
Everything is hooked up via HDMI through the receiver. I just found out that my reciever has been clipping BTW and WTW, which as I understand it, means I need to set my PS3 to limited, and my 360 to "standard." Now, as far as calibrating goes, if I unplug my ps3 from my reciever and plug it directly into my tv, I can view the BTB information.
My question is, can I have my PS3 plugged directly into my TV calibrate for black with the BTB (changing the settings to full), and then plug it back into my reciever and change all the settings back to limited, will that result in a properly calibrated image?
Also as I understand it, YPrPb is for Video and games are in RGB....now since i'm using a blu ray disk it is in YPrPb...will that result in a properly calibrated image for RGB when playing games as well?
And last but not least....When using the reverse grey ramps scale in DVE, when setting contrast I can never get the white to clip, even when set to 100. Is there another way to calibrate contrast level? Or is there a setting in either the TV or the PS3 that I can change temporarily to get it to work?
Thanks alot to anyone that can help, even if you can only answer part of my questions, it will make me alot less confused! Thanks!
Old 10-22-09, 11:36 AM   #2
Shack Moderator
Alias: Greg
Loc: NY
User: #13758
Since: Nov 2007
  glaufman is offline
Re: A couple quick calibration questions
Colt4587 wrote: View Post
Welcome! I think I can help with a little of this...
First my equipment
-Xbox 360
-PS3
On some models, Yamaha has issued firmware updates, and some have reported theirs no longer clip, I don't see one for yours, but that doesn't mean an update doesn't exist... I would start by asking the question of Yamaha...
I think this is generally recommended for PS3 BD playback regadless, along with Superwhite "ON", not sure about 360...
Probably not. If you wanted to plug/unplug without changing settings, that might get you even closer, but I wouldn't rely on it. You already know the 663 is messing with the video signal... BTB info is useful for calibrating (and for maintaining the integrity of the video) but not, strictly speaking, necessary for calibrating. For instance, if the background on the pluge pattern in DVE-BD is known to be black, you could start with brightness turned up, then turn it down 1 click at a time until you find a click that doesn't make the background darker. Then go 1 (maybe 2) clicks back up from there and you're real close.
Some sets don't let you pump contrast high enough to clip white. This is actually a good thing. There are generally 3 criteria for setting white:
1: No clipping
2: No observable color-shift
3: No eye-strain
I may have the priority order here messed up, but basically, if your display fails any of the 3 tests, turn the contrast down until it passes all 3. If it passes all 3 at the max value, then that's where you leave it. Note that passing 3 will depend on your viewing environment, as well as how you feel that day. Note that #2 if done by eye, HAS to be done with the steps or ramps patterns, as your eye needs a reference to compare against, in this case, grays just below white...
Hope this helps.
Old 10-22-09, 03:06 PM   #3
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
First my equipment
-Xbox 360
-PS3
As noted above, there may be some firmware chages for the Yamaha that might affect this. I would talk to Yamaha about it.
Regardless, I prefer to connect everything directly to the set and calibrate directly. This allows you to avoid unknown tinkering with the signal in the AVR and to calibrate inputs individually for sources.
LCD sets often do not clip whites nor show significant color shifts in the whites. With LCDs you can often run the contrast pretty high without these issues. Setting it is usually more a matter of geting the gamma or gray scale that you want, as contrast controls often interact with these parameters. Generally, I focus on getting the best black possible, then getting the transition to black that I want, and let whites end up where they end up, as long as they don't clip.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
« Home Theater Shack > Home Theater | Audio and Video > HDTV | Video Displays | Processors »
btb, calibration, settings, wtw
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
