"How To Check The Hours Used on Your Plasma" :
127K views 34 replies 16 participants last post by  the_rookie
#1 · (Edited by Moderator)
Used on Your Plasma
01) Panasonic Consumer Models
02) Panasonic Commercial Models
03) Panasonic VX100 Series
04) Panasonic Foreign Models
05) Fujitsu
06) Hitachi
07) HP
08) LG / Zenith
09) Pioneer
10) Samsung
Panasonic
Consumer Models
2011 Models : _X3 / S30 / ST30 / GT30 / VT30
2010 Models : _X24 / C2 / U2 / S2 / G20 / G25 / GT20 / GT25 / VT20 / VT25
  • Press and hold the {VOL -} button ON THE PLASMA TV.
  • Then press the {INFO} button on the remote control 3 times.
  • "Start Adjustment Menu" message will be displayed followed
    by the Service Menu after few seconds.
    • ADJUST {Picture Adjustment}
    • WB-ADJUST {White Balance Adjustment}
    • OPTION {Option Setting}
    • V-SUS {V-SUS Adjustment}
    • AGING
    • SRV-TOOL {Service Tool}
    {1} & {2} buttons move through options​
  • Press the {2} button once to select "SRV-TOOL".
  • Then press the {OK} button to access it.
  • Using the cursor keys, highlight the right side
    of the last item "PTCT :00.00.00.00.00" :
  • Then press and hold the {MUTE} button for 3 seconds.
  • Time and Count will be displayed in red color:
    __TIME = Hours : Minutes of operation.
    COUNT = Times the Plasma was powered on.​
  • To exit, unplug the power cable.
<<<<<<<<<< WARNING BY BRUZZI >>>>>>>>>>
The {VOL+} & {VOL-} buttons are used to change values​
while in the Service Menu. Make sure not to touch those​
buttons anytime while checking the hours used.​
2009 Models : _ PX14 / PS14 / C1 / U1 / X1 / S1 / G10 / G15 / V10 / Z1
2008 Models : _ PX80U / PZ80U / PZ85U / PZ800U / PZ850U
  • TC-P54Z1: Press and hold the {VOL -} button ON MEDIA RECEIVER.
    All Other: Press and hold the {VOL -} button ON THE PLASMA TV.
  • The Service Menu will be displayed with the following options:
    • AGING
    (On older firmware(s), hours shown must be divided by 256 for correct value)
2007 Models : _ PE77U / PX75U / PX77U / PZ77U / PZ700U / PZ750U
  • Then press the {RECALL} button on the remote control 3 times.
  • The Service Menu will be displayed with the following menus:
    • ADJUST (PICTURE ADJUSTMENT)
    • WB-ADJUST (WHITE BALANCE ADJUSTMENT)
    • OPTION (OPTION SETTING)
    • AGING
    • RM-SET (REMOTE CONTROL CODE SETTING)
    • SRV-TOOL (SERVICE TOOL)
    {1} & {2} buttons move through menus​
  • Using the cursor keys, select the right side
    of the last option "PTCT :00.00.00.00.00" :
  • Time and Count will be displayed in red color.
  • To exit, unplug the power cord.
2006 Models : _ PD60U / PX6U / PX60U / PX600U
2005 Models : _ PD50U / PX50U / PX500U
  • The Service Menu will be displayed.
  • Use the {1} or {2} buttons to select "Option".
  • Then press and hold the {MUTE} button on the remote for 3 seconds.
    TIME = Hours of Operation (Hex Numbers)
    COUNT = Times the Plasma was Powered On (Hex Numbers)
  • To exit, turn the power off.
Converting Hours in Hex to Dec Numbers:
In Windows, open CALC (calculator).
Click View, and set it to Scientific mode.
Select Hex, enter the number then click Dec.
It will convert it to a Decimal number for you.
< Tip by Jasonbanks >
Panasonic
Commercial Models
8UK / 9UK / 10UK / 11UK:
  • Press and hold the {VOL -} button ON THE PLASMA DISPLAY.
  • Then press the {STATUS} button 3 times on the remote.
    (Status button is the one above Setup button}
  • The Service Menu (CAT) will be displayed.
    (CAT = Computer Aided Test Menu)
  • Using the cursors keys on the remote, select "SD Mode".
  • And press the Action key { } to access it.
    On the MTBF (Mean Time Between Failure) parameter:
    WT = How many times the unit was powered on
    PT = The cumulative time in hours
  • To exit the SD Mode, press the {R} button.
  • To exit the CAT menu, press the {STATUS} button.
  • To completely exit the Service Menu, turn the power off.
3UY / 4UY / 5UY / 6UY / 7UY:
    (Status button is the one below Power button}
Panasonic
Premiere Models
VX100U / VX100E :
  • Then press the {RECALL} button 3 times on the remote.
  • And press the {OK} button to access it.
  • To exit the CAT menu, turn the power off.
Panasonic
European Models
PZ80 / PZ81 / PZ82 / PZ85 / PZ800
PX8 / PX80 / PX81 :
  • Then press the {0} button 3 times on the remote.
  • The Service Menu will come up.
  • The hours used will be displayed in the right lower corner.
    TIME : Hours and minutes of operation
    COUNT : Times the Plasma was powered on
  • To exit, press the {EXIT} button or turn the power off.
PV7 / PV70 / PV71 / PZ700
PX7 / PX70 / PX71 / PX72 :
Previous Models :
  • Set the channel to CH99.
  • Select the EQ 12kHz.
  • Press the {HOLD} button on the remote control.
  • The Service Menu 2 will be displayed.
  • Using the {GREEN} button on the remote,
    scroll down to the last Option Menu: "Hours".
  • To exit, press {EXIT} or turn the power off.
Fujitsu
Consumer Models
  • Press and hold the {ENTER} button on the remote
    until the Service Menu is displayed:
    • Monitor Mode A
    • Monitor Mode B
    • Extend Adjust
  • Select "Monitor Mode A" and press {ENTER} to access it.
    Hours Meter:
    To determine total hours, add RGB and video for the total hours on the plasma
    (each number represents hours on that selected input).
    Disregard total hours. That's the number of hours the Plasma is plugged in.
Hitachi
Consumer Models
HDS69 / HDT79 / HDX99 :
  • Using the remote, press the following buttons:
    {MENU}, {MENU}, {8} & {SELECT}
  • Use the {UP} or (DOWN} buttons to select "PDP"
  • The press the {SELECT} buton to access it.
  • Hours used will be shown in the "OPERATION TIME"
HP
Consumer Models
PE-4200N / PL-4200N / PL-5000N
( Rebadged Panasonic PX500 Series )
  • Press and hold the {VOL -} button ON THE PLASMA.
LG / Zenith
Consumer Models
PG20 / PG25 / PG60 :
  • Press and hold the {VOL -} button on the remote.
  • Then press and hold the {MENU} button on the TV.
  • After the password screen comes up, press
    the following code: {0} {0} {0} {0}
  • The hours used is shown after "UTT".
    Info sent by crkpot
Pioneer
Consumer Models
5020FD / 6020FD :
You cannot access the Service Menu on these models using their regular​
remote controls. But there are other ways to check the hours used:​
  1. Service Remote Control Models: GGF1589 or GGF1633
  2. Get ControlCAL and then follow these instructions:
    http://www.controlcal.com/forum/showthread.php?t=120
KRP-500M / KRP-600M
PRO-101FD / PRO-141FD
PRO-111FD / PRO-151FD :
  1. Set up the Network and use the following address:
    http://<krp ip address>/cgi/service_right.cgi
  2. Service Remote Control Models: GGF1589 or GGF1633
  3. Get ControlCAL and then follow these instructions:
  4. Get KuroReader
4280HD / 5080HD :
  • Using the remote control:
  • Turn off the TV Guide feature.
  • Turn off the power to set the TV into standby mode.
  • Press the {DISPLAY} buton once and wait 4 seconds.
  • Then press {LEFT} {UP} {LEFT} {RIGHT} {POWER} buttons
    within 5 seconds.
  • The Plasma will turn on with the "Information" page displayed.
  • Use the {DOWN} button to select "Hours Meter"
    PANEL = Hours of operation.
    ...MTB = Hours the set has been plugged in.
4270HD / 4271HD / 5070HD / 5071HD
6070HD / 6071HD / 507PU / 607PU :
    within 5 seconds.
4360HD / 5060HD :
    within 5 seconds.
Samsung
Consumer Models
2010 "C" Models :
  • While the TV is in standby mode:
  • Press the {MUTE}, {1}, {8}, {2} & {POWER} buttons.
  • The TV will turn on with the Service Menu displayed.
  • Use the {UP} or {DOWN} buttons to select "SVC"
  • Then press the {ENTER} button to access it.
  • "PANEL DISPLAY TIME" will be one of the items listed.
  • To exit, press the {RETURN} button and/or turn the power off.
B550 / B560 / B590 / B650 / B850 / B860
A450 / A550 / A650 :
  • Use the {UP} or {DOWN} buttons to select "PDP OPTION"
    NOTE: After exiting, all picture settings will be reset to
    default values. So make sure to write down custom
    adjustments before accessing the Service Menu.
  • Use the {UP} or {DOWN} buttons to select "OPTION BYTE"
Yamaha
Plasmas
PDM-1 - 50" Plasma Display
( Rebadged Panasonic PHD5 Series )
  • And press the Action key {} to access it.
#10 ·
You might have warranty coverage issues if you bought it from an unauthorized dealer, but I doubt it unless the set was previously sold, a refurb, or something else fishy. These are questions for your dealer and Pioneer, however.
#15 ·
Bruzzi,
Really dumb question, but I am now paranoid after taking out a second mortgage on my new TC-P65V10 Panny. In your instructions, you say to hold down the {VOL -} key on the plasma (along with the info key on the remote) to invoke the service menu. Lastly, you have a warning NOT to touch the {VOL +/-} keys at all (what your instructions said to do in the fist place). What am I missing?:huh::help:
#17 · (Edited)
To check the hours used on your Philips TV you have to go in the service menu. To enter service-menu type:
062596
Be careful NOT to change anything in the service-menu. Entering service menu would void the warranty, but I was glad I checked my new 37PFL9604 anyway: it already had 3400 hours on it :eek:
Of-course I had it replaced by a new one, but if I hadn't checked it...
#20 ·
I can't recall off the top of my head what the time frame is for editing a post, but I do know that they are shut off at a certain point. :scratch: You can either pm it to me or post it here and I'll edit it in for you. :T
#29 ·
Hello,
While we're at it, can anyone tell me how to check the hours viewed on the Panny ST60 series plasmas, particularly the 65". I'm getting the TV delivered today from Cleveland Plasma, I did some research and found CP to be a very reputable Authorized Panasonic dealer, but I am just skeptical by nature and would like to know the hours on this particular TV. If no one knows, could you post a link to where I might find out. Thanks a lot.
Cheers Jeff
#30 ·
Excellent post. However, it would be helpful to know what we can take away from knowing how many hours are on the plasma. For instance,
* How many serviceable hours can we expect from a plasma?
* At what point does it start going “downhill and doesn’t look good anymore?”
* If you were shopping for a used one, at what number of hours would it be a deal breaker?
#31 ·
Wayne, I did find out there were only 5 hours on my new Panny Plasma, I have another 50" plasma in the bedroom that is still going strong after 7 years, the picture I believe is as good as when it was new. The life span on the older plasmas was 60,000 hours, the new models are up to 100,000, this is on the actual panel itself, other components are not guaranteed to last, power supply is usually the first to go. Your statements above are very relevant when shopping for a new or used TV, The good thing with plasma TVs is that they seem to get better with age, just like us.:eek:lddude:
Cheers Jeff
#33 ·
Anybody have any hours listed now days?
My Panasonic is running 15,000, with around 8000 on/off operations.
A little less than I expected...alot actually...
I expected closer to 30k cuz of it stays on alot. But i recently turned on the feature to auto-shut off after like 3hrs. No-signal shut off, and No Action shut off. So if i go to bed, and forget to turn it off, it will shut off if i sleep.
