Adcom Gfa 5500 Good Amp ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Discuss Adcom Gfa 5500 Good Amp ? in the Home Theater | Audio and Video forum; Adcom Gfa 5500 Good Amp ? Can I get some feedback on this amp ? I am thinking of buying a used one for a low ...
Old 03-29-08, 04:27 PM   #1 (Link)
New Member
Alias: Paul
Loc: Long Island NY
User: #18067
Since: Mar 2008
gamedog44 is offline
Can I get some feedback on this amp ? I am thinking of buying a used one for a low price (about 500.00)
Old 03-31-08, 04:08 PM   #2 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
Re: Adcom Gfa 5500 Good Amp ?
I've never heard one but used a 555(ver2) until a voltage spike (lightning) took it out. Had a lot of power.(tight bass)
What others say http://www.audioreview.com/cat/ampli...7_1583crx.aspx
Old 03-31-08, 04:47 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Adcom made good quality amps unfortunately they do not make them any more. If you can get one in good condition then go for it $500 seems a bit high for that amp (new they were $1000). The one you mention is rated at 200watts.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-31-08, 07:17 PM   #4 (Link)
New Member
Alias: Paul
Loc: Long Island NY
User: #18067
Since: Mar 2008
Thanks for the input guys's.I got out-bid on E-bay for it anyway as I stopped bidding at 500.00.I was not going to pay more then that for a used amp.I am thinking of a couple of options.A Rotel RB 1080 used there are a few on e-bay now but they seem to be bidding up over the 500 mark.I think maybe a brand new Emotiva XPA-2 could be the way to go here.I plan on using the amp for audio only.I am running a Denon 3808ci with a 5:1 set-up plus subwoofer have JBL studio L890's up-front was going to use the pre-outs on the front L/R channels for this.And also wanted to use the amp for partying on my deck with pro-monitors prehaps the JBL JRX 115's or JRX 125's.
Old 04-01-08, 07:17 AM   #5 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
gamedog44 wrote: View Post
You want to use the "new " amp only for the deck speakers or both deck and main? I thought that using the pre outs would bypass or turn off the amp on the receiver for that set of speaker outputs? (maybe someone could answer this one?)
Have you checked local shops for used/demo? (no shipping costs etc.....)
Have you thought about pro amps? I picked up a a used Qsc plx 1602 (300/ch) for $300 and put a quieter fan (panaflo ) in it for under $20. One of the cheapest would be a Nady .(never used one and it is not in the same class as a plx)
http://www.musiciansfriend.com/produ...ELAID=26040102
Old 04-16-08, 03:03 PM   #6 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
conchyjoe7 is offline
John N said: "I thought that using the pre outs would bypass or turn off the amp on the receiver for that set of speaker outputs? (maybe someone could answer this one?)".
All you have to do is use a Y splitter and go from the receiver's pre out to the 2 sets of inputs...one on the main amp/receiver, and the other on the secondary amp. Both sets of speakers will work then and you can control the second pair simply by turning the secondary amp on and off.
Cheers,
Konky.
I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns.
Old 04-16-08, 05:28 PM   #7 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
DS-21 wrote: View Post
I don't think that it (or any other separate amp) will give you any benefit in the main system over using your receiver, unless you use it solely to insert some sort of EQ in the signal path and possibly remove the passive crossover in favor of active drive. For your second stated use, the Adcom or Rotel (or anything with decent power, really) would be fine.
With out getting into the "all amps sound the same" discussion , if you were to use a better power amp (more watts and headroom ) you would notice a big difference.
I am using a cheaper Marantz receiver and Parasound amps and would not spend the money if it did not matter.
I'm not saying any cheap pro amp would sound better. (although it may at louder levels )
Old 04-17-08, 07:58 AM   #8 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
That depends entirely on actual use. If in actual listening, one does not require peaks in excess of what the headroom the "lesser" amp can provide, a "better" amp will do exactly nothing.
Nothing except maybe more controlled (tighter bass ) or smoother highs........ Most of the people on this site test the limits of their system or there would one post "we all own the same home theatre in a box"
Not everybody hears the same so to spend money beyond the capabilities of your ears is a waste.(maybe what you are getting at?)
If you think a receivers ( cheaper ) amp is the same as a good power amp , save your money.
Old 04-17-08, 10:38 AM   #9 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
Play nice guys. I have no issue with this discussion and in fact take part of it quite often, but there is no need for name calling or insults. If this topic cannot be had in a civilized manner action will be taken.
Also, this discussion seems beyond the scope of this thread. If you want to discuss amp audibility it would be wise to dedicate a thread to it. If so I would be more than willing to move the posts there.
-Andrew
Old 04-19-08, 11:17 PM   #10 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Paul,
Go for a GFA-555 or 555II. Great amps. I’ve had a pair of the latter for over ten years now, and I bought them used. You should have no problem getting one for under $400.
Old 04-20-08, 08:57 AM   #11 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
I had my 555 (II) for over ten years too . I bought mine in white because "all black boxes sound the same"
Old 04-20-08, 03:29 PM   #12 (Link)
Alias: John
Loc: mukwonago
User: #5253
Since: Jan 2007
John N is offline
I went with the 555(II) because my old speakers were inefficient Fried beta's . (all my high school budget would allow at the time).
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
Similar Threads
REVIEW: Logitech Z-5500 5.1 Speaker System MrPorterhouse Computers | Games | HTPC | Digital Devices 10 03-22-08 03:24 PM
Adcom lcaillo Manufacturer and Vendor Reference Information 0 05-30-07 08:13 PM
Adcom GFS700 receiver omegamaulers Home Theater Components 0 12-16-06 07:20 PM
Adcom 565 amp. vitod Home Theater Components 3 12-09-06 06:31 AM
Some Old & Used But Good reed.hannebaum Home Theater Equipment 3 05-21-06 12:18 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
