| HiFi Audio Components 2 Channel Full Range- ReccomendationsDiscuss 2 Channel Full Range- Reccomendations in the Home Theater | Audio and Video forum; 2 Channel Full Range- Reccomendations Ok folks I realize choosing speakers is highly dependent on personal taste. I am child of the '70s so JBL ... |
Views: 410 - Replies: 12
| 2 Channel Full Range- Reccomendations Ok folks I realize choosing speakers is highly dependent on personal taste. I am child of the '70s so JBL L100's (x4) are what I was raised on and I guess that type of sound is what I prefer. Who makes honest full range (unpowered) speakers these days? I want to run a set of speakers and not be dependent on a sub. My budget is $2,000/pair. Repeat no sub.. s | ||||
| | #2 | |||||
| Re: 2 Channel Full Range- Reccomendations Quote:
| | #3 | |||||
While I was veneering my subs and mains 3 years ago I used the L890s w/o sub in a 3200 cuft room. With a 220w amp those things were very impressive. Performance Series the name sez it all | |||||
| | #4 | ||||
| Re: 2 Channel Full Range- Reccomendations The SVS MTS-01 floor standers get really good reviews and for the money ($1419) you wont find much better. They have a frequency response of 38Hz to 27kHz. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: 2 Channel Full Range- Reccomendations I'd look at a pair of Dynaudio speakers. Depends on what size of room, but you might look into a pair of used Contour 1.3 monitors. Dynaudio also makes some new models, Focus, that are getting good reviews, but I can only vouch for what I actually listened to and what I now own -- Contour 2.8 towers, Contour 1.1 monitors, and a Contour Center. | ||||
| | #6 | |||||
My2Cents | |||||
| | #7 | |||||
| Quote:
By the way, I got to hear the high end KEF Reference Series - I was like - they sound amazing !In the end, it's all about your own personal preference. | |||||
| | #8 | |||||
I wish I could hear these demo'd as I can't afford to drop a couple hundred in shipping for a trial run. I'm really considering building my own 5.0 with anarchy mids, but I'm thinking it all over as I saw some MTS-01's for $900 and wonder how good sounding they really are, plus they are rated to 38hz, when I'd really like to run my mains full range without a sub required when listening to stereo music, but maybe my expectations are unrealistic? ![]() ![]() | |||||
| | #9 | |||||
Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #10 | ||||
| Re: 2 Channel Full Range- Reccomendations Thanks Tony. Do you run your mains with your samson @220w/ch? I like my RnR music turned up to fill the whole house while I'm doing housework/chores,etc., so I was curious because I have a samson servo 550 (225-285w/ch) that I'd like to run my future mains, of course in this situation I'd call upon my samson 'big-un' pg2200 to light up the Mal-X I was looking into some used rocket mains for a bit more money, but I think they will be sold, so I'm still considering the svs along with diy builds-we'll see... | ||||
| | #11 | ||||
| Re: 2 Channel Full Range- Reccomendations I can think of many full range speakers, but two things to consider, my definition of full range may differ than others - 20Hz equals full range and also price is over $2000 for pretty much all of them. Also, the best route you can go for bang-for-the-buck is DIY. If you want great speakers and don't mind putting in a little work, then DIY is a fantastic alternative. Even if you don't have woodworking skills you can have some one make the cabinets for you and then you buy the components and install it all yourself. Pretty simple and will likely get you closer to your budget. Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #12 | ||||
| Re: 2 Channel Full Range- Reccomendations Yes, my mains are run off the Samson, For me just giving them some extra juice helped and really keeps my Onkyo 805 much cooler. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #13 | ||||
| Re: 2 Channel Full Range- Reccomendations A while back I was looking for some new speakers and I auditioned quite a few. One that stands out that did not need a sub was the Salk Song Towers. They have a beautiful sleek cabinet and if my memory serves me were around 1500.00, but sounded as good as most 2 to 2.5k sets I listened to and had a fantastic bass , tight, quick and clean. Here is Dennis Murphy’s ( a consummate crossover artist) description of the design... "The SongTower QWT is an MTM design using a mass-loaded quarter wave transmission line cabinet designed by Paul Kittinger and based on the pioneering work of Martin King. This transmission line cabinet allows the floor-standing speaker to exhibit greater bass extension than a ported design would normally allow. This design is the end result of a year-long project to develop a very affordable (under $2000) speaker that - 1) is wide range, with useful bass response to at least 40 Hz; - 2) has a small enough footprint to allow cabinet dimensions with high SAF; and, - 3) is sensitive enough to be compatible with a wide range of amplifiers. Traditional 3-ways would almost certainly fail at least one of the last two requirements. Traditional 2-way bookshelf designs would require a large woofer that might not produce the best possible performance in the upper midrange, and would also require stand-mounting (low SAF). The solution was to use two high quality 5" drivers optimally suited to Martin King's MLQW transmission line cabinet design, mated to a high quality tweeter. The Seas CA15 woofers were an obvious choice to perform bass duties, due to their appropriate electrical and mechanical parameters and extremely smooth and extended response at higher frequencies. The Hiquphon 0WII was perfectly suited for the design, since it is sensitive enough to keep up with twin CA15 woofers and provides almost ruler-flat response and extremely broad dispersion. In addition, this tweeter is rugged enough to allow a fairly low crossover frequency with room to spare. The sensitivity of the MTM is conservatively rated at 88 dB, and can play a 38 Hz tone at high enough drive levels to set off rattles from loose objects in a typical room." I also was impressed with some Vanderstien 2sige’s and almost bought them but I have a house full of little pokey fingers. They also need a lot of amp. Price is right there with your budget tho. Hope this helps | ||||
| Bookmarks |
| Tags |
| channel, full, range-, reccomendations |
| Thread Tools | |
