Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Oppo BDP-83 as dedicated CD player.
Discuss Oppo BDP-83 as dedicated CD player. in the Home Theater | Audio and Video forum; Oppo BDP-83 as dedicated CD player. The only reason why I consider not getting another unit is because you cannot get the versatility of the 83 ...
Views: 997 - Replies: 27
Old 09-30-09, 08:53 PM   #26
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Re: Oppo BDP-83 as dedicated CD player.
The only reason why I consider not getting another unit is because you cannot get the versatility of the 83 if you went with another unit!
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 10-04-09, 05:25 AM   #27
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is offline
I have no hesitation in recommending the Oppo as a good CD player, the 2 channel board is excellent considering the price, and has better DAC's than on the Multichannel outputs, it is just a good all rounder, I am listening to James Taylor at present and really does sound good through my system via the Oppo...you are going to have to go quite a bit higher in price to get better performance...
Old 11-02-09, 10:53 AM   #28
Alias: doctorcilantro
Loc: tampa, fl
User: #28831
Since: Nov 2008
  doctorcilantro is offline
HionHiFi wrote: View Post
My HTPC is my primary source for music. I listen to probably 70% of my music through it. The rest of the split is something like this:
  • 25% - Cable Television
  • 5% - Oppo DV-980H DVD PLayer
The only problem I have is the HTPC is noisy as a source. I can hear its fan operating from my listening position. A no no in my system. I'm looking for a solution.
Look into an HTPC based on a mini-ITX board. Coupled with a 45w AMD cpu, you're golden.
Regarding the BDP...excellent unit. Rather than spend cash on a slot load Blu-Ray drive (my PSILE case only takes slot load), and since I needed something for SACD and ease of use for the family (when I'm using my HTPC), I picked one up. Solid unit and sounds great feeding my Peachtree Nova.
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
bdp-83, dedicated, oppo, player.
