Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > HiFi Audio Components
  Discuss Is there a drawback from a seperate 2 channel from a plate amp?? in the Home Theater | Audio | Video forum; Is there a drawback from a seperate 2 channel from a plate amp?? Well im getting a shiva, and was going to pick up a dayton 500 watt plate amp for it but ...
Views: 371 - Replies: 5
Old 09-02-09, 02:43 AM   #1
Alias: matt
Loc: San Antonio, / Duluth MN
User: #41448
Since: Sep 2009
  mj79 is offline
Well im getting a shiva, and was going to pick up a dayton 500 watt plate amp for it but then i see for about $50 more i can get the behringer ep2500, which is obviously huge amounts of power... Sooooo just basically wondering why more people dont go that route instead of getting a plate amp thats 500 watts and $250, over a 2400 watt amp thats $300..??
Old 09-02-09, 12:07 PM   #2
Alias: Mike
Mike P.'s Avatar
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: Is there a drawback from a seperate 2 channel from a plate amp??
The advantage of the EP2500 is the extra power as you stated, the disadvantage is it has no Hi-Pass filter to protect the sub from over excursion at the lower frequencies. Most plate amps do have a Hi-Pass filter built in. An add on HPF unit costs about $100.
Old 09-02-09, 04:14 PM   #3
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is offline
As Mike said, the hpf will be helpful if you build a ported box and use it for HT duty. If you go sealed, you can likely go either way, I think. The plate amp is easy to manage compared to a 30-45lb pro amp too.
Old 09-02-09, 09:45 PM   #4
Alias: matt
User: #41448
Since: Sep 2009
  mj79 is offline
thanks guys.. SO what is the best option, if i plan on possibly powering another sub in the future... ?? I just cant figure out how such a powerful amp is so cheap.. So basically your saying there is no subsonic filter, so there is no frequency limit on the low end?? how about low pass?? does it cut off at some point, like most other sub amps, like 500 hz -250hz, etc?
Old 09-02-09, 11:03 PM   #5
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is offline
mj79 wrote: View Post
If you're planning for a possible addition later, you could go either way, but if you need more than 2x500w, then I think you should go pro-amp. Those amps are built for different duty, so it's cheaper, but lots of folks use them for home use. The drawbacks are weight, lack of features (usually no hpf or instant turnon, and possibly fan noise. Pro amps will amplify any freq range you supply it. Plate amps have their purpose, they're lighter, can be installed in the box, and often have filters built into it. Did I mention lighter? You'll probably pay a bit more per watt for a plate amp compared to basic pro amp of similar power, especially at the higher range, say, over 500w. I needed a hpf for my ported sub along with add'l gain for the signal between the receiver and pro amp, you might or might not. A plate amp is the easiest to do without reading up on all of the connections, etc with a pro amp, as you can tell.
You're right on with the hpf- protection for vented from nasty low end sound sometimes on soundtracks, but if you go sealed, the design affords the protection. Most people seem to use the built in lpf in the receiver to the sub amp, which is typically set around 80hz, so you should have that covered...
Old 09-03-09, 09:54 PM   #6
JCD
Shack Moderator
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
I don't think there is a phase control or EQ on that Ep2500 that appears on the Dayton amp.
Also, the amp is 450watts/pr channel at 8ohms. Bridging it does juice it up, but there are pro's and con's to bridging an amp.
This is not to say I wouldn't be tempted by the ep2500 too..
« Home Theater Shack > Home Theater | Audio | Video > HiFi Audio Components »
amp??, channel, drawback, plate, seperate
Bookmark and Share
Dish Network
