Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Considering a new CD deck
Discuss Considering a new CD deck in the Home Theater | Audio and Video forum; Considering a new CD deck I am considering a new CD deck. I have one SACD and hundreds of red book CD's, so SACD is ...
Views: 342 - Replies: 22
Old 10-03-09, 02:29 PM   #1
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
I am considering a new CD deck. I have one SACD and hundreds of red book CD's, so SACD is not an important consideration for me. That said, SACD capability would be a plus if it happened to be there; it's just not essential. The two-channel CD sound reproduction, clarity, separation, and imaging is the paramount consideration.
I plan to audition before I buy, if possible. Budget is $1500. I haven't listened to any of the following yet, but these are on my list and all are available in my area for auditioning.
Marantz SA 8003 - CD/SACD
Rega Apollo - top loader
Rotel RCD-1520
Rotel RCD-1072
Arcam CD17
The decks on my list so far are those that are available at dealers in the Dallas Texas area. Lower-priced tube decks like the Jolida JD-100A would be on my list, but they are direct sale only and can't be auditioned. Do you have any suggestions to help me fill out my audition list up to $1500?
The top-loading design seems like it would have an inherent stability advantage over tray loaders, but it may not fit well in my furniture. It depends on the dimensions with the cover open. Some top loaders have flip up doors, but I've seen at least one with a sliding door. I can't put a top-loading CD player on the very top of my furniture as that is where my TT resides.
The PrimaLuna Prologue 8 is a tube based player, more than $1k over my budget, but since there is a dealer in my area I'll audition it anyway just to see what I could do for $1k more. It would have to blow my socks off to make me consider expanding my budget that much, and if I did so, then I'd want to look at other decks in that price range too (e.g., Bryston BCD-1, Rega Saturn, Arcam CD37, used market McIntosh MCD201).
I welcome your suggestions and comments.
five
Old 10-03-09, 02:53 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Considering a new CD deck
You could save your self alot of cash by just buying an Oppo Player. For the money you wont find anything better and the playback quality is very high.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 10-03-09, 03:04 PM   #3
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
There are some that swear there are night and day differences between the inexpensive CD players and the uber-expensive variety.
There are some that will tell you a CD player is pretty much going to sound like just about any other CD deck regardless of price.
I fall in the second category. I really don't think there is all that much difference, if there is one at all, between a really expensive CD player and a more modestly priced player. When they first came out, I've heard there were some pretty obvious differences with the DAC's in the players where a more expensive model made more sense. These days, I'm not buying it. I also fully realize that there are some who will passionately disagree with me on that one.
That doesn't mean I'm going to go out and buy the cheapest player on the market -- how loud the physical/motor parts are, the reliability of the unit, the remote, etc are all items I'm going to want to review before I purchase, but I'm not thinking the output is going to be all that different between the units.
On the assumption that the more expensive units do have a superior sound, I'd argue that the difference is still going to be small and that you would need a well treated room with a good set of speakers to notice the difference.
What does that all mean? I think that I wouldn't spend more than ~$150-$200 for a dedicated CD/SACD player.
But, again, that's just me.
Old 10-03-09, 03:12 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
There is defiantly a difference between a cheap player (below $100) and a unit in the mid grade level however I do agree that the over priced CD/DVD players do not improve sound the only thing is the build quality is much better on the high priced units and the drive units are more stable. Worth the $1000 plus you spend? I doubt it.
Home theater:
Two Channel system:
My Webpage
Old 10-03-09, 04:02 PM   #5
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
Tony, are you referring to the Oppo BDP-83? I already have Blu-Ray and DVD capability, but if I can find a local dealer, I will audition it.
Old 10-03-09, 04:08 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Yes, the BDP83. I think for the money its going to be tough to beat.
Home theater:
Two Channel system:
My Webpage
Old 10-03-09, 04:37 PM   #7
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
One review of the Oppo BDP-83 Universal Blu-ray Player, from Home Theater Magazine, July 2009, leaves me with some concern.
Operation is smooth across most formats. I’ve had the chance to use the player for quite some time, and I haven’t come across a hitch with a Blu-ray title at all. However, some SACDs and CDs had a brief dropout on occasion. At press time, Oppo had just recently offered the BDP-83 for sale to the general public after extensive beta testing and its “early adoption” market trial program. Oppo is committed to timely firmware updates to address any little bugs that might pop up. Thankfully, there hasn’t been any significant issues with my unit. In fact, I’d say this is the most trouble-free player I’ve used in my system considering the breadth of titles (and formats) I play regularly.
Emphasis mine. This was really all that was said about the Oppo's CD playback capability in the entire review. I believe the reviewer was primarily interested in the deck's Blu-Ray and DVD playback capability, which I am not interested in. The sole comment about CD is not positive. There is no review of the deck's two channel playback sound at all. As that is all I am actually interested in, I've crossed this off my list.
Old 10-03-09, 05:00 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
number 5 wrote: View Post
I have a feeling that his CDs may have had a scratch or some other imperfection, The higher end players are also more sensitive to scratches, fingerprints and dust
Home theater:
Two Channel system:
My Webpage
Old 10-04-09, 11:11 AM   #9
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
That was one person's experience. I know that I haven't had a problem with mine at all for CD and SACD or DVD-Audio playback. Oppo is ALWAYS working to make things better anyway. If there ever is a problem and it gets reported, they will try to fix it.
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 10-04-09, 12:25 PM   #10
Alias: brucek
User: #6
  brucek is offline
I would presume you have a decent analog system to realize the advantage of spending the extra money on a good CD player. If you plan on simply connecting the player through digital to your system, you can get away with spending somewhat less.
If you do have a good analog system, I would recommend listening to the Bryston BCD-1 and the Arcam CD-37 to see if you want to add those extra dollars. They're both a couple grand, with the Arcam also playing SACD's, but the Bryston with the better specs.
I have an Arcam Alpha 9 myself feeding a Bryston analog system, and my opinion is that a good player is worth every cent. The specs on the Bryston player are very good, using fully discrete Class A analog outputs. It would be my choice (coupled to a good system)..
Old 10-04-09, 06:48 PM   #11
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
brucek, I am in the process of building my system, and I think it may be good enough to take advantage of a good CD player.
For two-channel, I will have B&W 804S speakers driven by a Rotel RSX-1550 integrated amp. I just bought these; installation is scheduled for later this week. For HT, I will have a B&W HTM3S center speaker, and a pair of CCM65 in-ceiling surrounds.
I have a Rega P5 TT. Since the Rotel RSX-1550 doesn't have a phono stage, I've also ordered a Jolida JD-9A phono stage that will hopefully be delivered sometime next week too.
I'll be going to audition the Rotel RCD-1520, Rega Apollo, and the PrimaLuna Prologue 8 on Wednesday. I will be calling on the Arcam dealer Thursday or Friday. The Arcam CD-37 certainly seems appealing, but it and the Bryston and the PrimaLuna are all considerably more expensive than the other decks I'll be listening too. Tough choices.
Old 10-05-09, 03:44 AM   #12
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is online now
The new Rotel CD spinner has been getting some very positive reviews in the HiFi press here in the UK, will be very interested to hear your thoughts on how it performs number 5?
Old 10-05-09, 09:36 AM   #13
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
If you can audition the Shanling CD-T100se please do. A friend's sounds very good indeed.
Old 10-05-09, 10:30 PM   #14
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
John, I'll post back on my impressions of the Rotel and others.
Jay, I would very much like to listen to a Shanling CD-T100SE, but so far I have not found a dealer near Dallas. I am very curious about it, and also the more expensive CD-T1000SE that I believe has replaced the T100SE in the lineup from Shanling. From the review articles, it seems that many people end up modding these units to get the best sound, and that adds considerably to their cost. Due to the lack of dealers, I suspect I'd have to buy one to audition it. I'm reluctant to take that sort of risk, but if I can find one to listen to, I will.
five
Old 10-06-09, 03:32 AM   #15
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
cheers number 5, look forward to your feedback
Old 10-08-09, 06:34 PM   #16
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
how did you get on with the demo number 5?
Old 10-08-09, 11:09 PM   #17
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
Hey recruit. I deferred my auditioning plans to this coming Saturday. Work has kept me more occupied than usual this week, and the distance I'd have to drive to get to one dealer would force me to drive in rush hour to get there before they close.
Stay tuned.
Old 10-09-09, 01:47 AM   #18
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
Stay tuned.
Work always seems to get in the way of pleasure
Old 11-01-09, 12:23 AM   #19
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
I did listen to both the Apollo and the Jekyll ... I mean the Hyde, sorry.
No actually I was very impressed with the Rotel CD player. But I felt the Apollo was better.
If I can manage to complete my review, I'll post it.
Old 11-01-09, 12:28 AM   #20
Alias: David
Mika75's Avatar
Loc: Victoria, Australia
User: #33426
Since: Feb 2009
  Mika75 is offline
JCD wrote: View Post
I fall in the second category. I really don't think there is all that much difference, if there is one at all, between a really expensive CD player and a more modestly priced player....
Agreed JCD, the bolded area i find to is most important.
Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624
Old 11-01-09, 12:38 AM   #21
Alias: five
Loc: Dallas
User: #41717
Since: Sep 2009
  number 5 is offline
Mika75 wrote: View Post
I believe you will be missing out on some important distinctions available among CD players,
Are impressions of sound quality a myth? Perhaps if your ears are sufficiently damaged.
Old 11-01-09, 12:55 AM   #22
Alias: David
Mika75's Avatar
User: #33426
Since: Feb 2009
  Mika75 is offline
Unless there are massive measured differences, they will sound exactly the same.
Old 11-01-09, 04:57 AM   #23
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
Glad you got to listen to the Rotel and Apollo, look forward to more in depth review if you can Number 5?
If CD players are used as transport only then differences can be minimal and dependant on the DAC's in AV/Preamp, but the quality of CD playback via anologue direct to preamp can be very different indeed through past experience...
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
deck
