Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Help - Advice on reconditioning Sansui AU-717
Discuss Help - Advice on reconditioning Sansui AU-717 in the Home Theater | Audio and Video forum; Help - Advice on reconditioning Sansui AU-717 This integrated amp has been a faithful companion for the past 30 years of my life. I recently took the ...
Views: 100 - Replies: 4
Old 11-06-09, 08:25 PM   #1
Alias: Q
Loc: NW Ga
User: #41549
Since: Sep 2009
  FidelitySeeker is offline
This integrated amp has been a faithful companion for the past 30 years of my life. I recently took the cover off and noticed leakage from some of the capacitors.
I have to wonder if it has gradually deteriorated (it still sounds good, but it is hard to know if it it as good as it could be), or if I may be risking a catastrophic failure.
So I would like to get it reconditioned.
Please advise re: a good source for this job, as well as what should be done to recondition it. I will get photos if that is helpful.
I can ship, but would be willing to drive a good distance to avoid the risk of damage. I live in Woodstock; north of Atlanta (not too far from Chattanooga) if anyone knows of a good shop for this job in my area. I am not looking for museum quality restoration, but cost-effective reconditioning.
Thanks in advance for your help!
Old 11-07-09, 01:18 PM   #2
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Re: Help - Advice on reconditioning Sansui AU-717
I am not particularly savvy on fixing or reconditioning electronics, but I can guarantee that there are specialty shops around that would be able to help. Also, I am not sure if you are tech-savvy yourself, but if you can solder things yourself, it may be worth a look into getting replacement caps and doing it yourself. You would save a lot more money and on top of that, you could even look into getting higher quality stuff as replacements as well!
I don't know much about capacitors or the like, but I know people always talk about Sonicap as a very good brand.
Sorry I can't provide more help personally!
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 11-07-09, 06:58 PM   #3
Alias: Q
Loc: NW Ga
User: #41549
Since: Sep 2009
Thanks Jon.
I haven't tried my hand at electronics in ages. I tried to build an SouthWesternTechnicalProducts stereo Amp in 1973 and managed to fry several transistors (no one told be about heat sinks for soldiering - I don't know how I got away with building a Heathkit portable turntable stereo before it). What can I say, I was young, dumb, and enthusiastic.
I'm sure there are probably a few places in Atlanta that could do the job well. I just need to find them, but I may end up shipping if I can't find a local shop with good references.
Old 11-08-09, 01:28 PM   #4
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
What makes you think that the capacitors are leaking? Often, units of this vintage had a glue applied that dries out and then absorbs moisture from the air, leading to corrosion. That glue is often mistaken for leakage, as is flux residue.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 11-08-09, 11:45 PM   #5
Alias: Q
Loc: NW Ga
User: #41549
Since: Sep 2009
lcaillo wrote: View Post
How about ignorance of other possibilities!!!
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
advice, au-717, reconditioning, sansui
