Sub on a 2 channel amp - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Discuss Sub on a 2 channel amp in the Home Theater | Audio and Video forum; Sub on a 2 channel amp I have a Musical Fidelity A3.5 Int Amp which has L&R PreOuts on it. I know they are intended to ...
Old 02-16-07, 07:53 PM   #1 (Link)
Alias: Mark
Loc: Dallas, Tx
User: #2244
Since: Aug 2006
Marks57 is offline
I have a Musical Fidelity A3.5 Int Amp which has L&R PreOuts on it. I know they are intended to drive another amp, but couldn't I run line level into a subwoofer? I know it's not the same as on an A/V receiver that has a dedicated SW preout and that the line level signal will be the full sound spectrum instead of a SW preout that has internal crossover settings in the receiver.....but if the sub has crossover settings, wouldn't this "bleed off" everything I didn't want....say above 80-100hz?
Thanks for any input.
Mark
Old 02-16-07, 08:14 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: Sub on a 2 channel amp
Hi Mark,
That will work fine, and that's exactly how most of us ran sub/sat systems before there were 5.1/7.1 receivers. You won't have remote control of the level feeding your sub, but that's OK. If you find you have too much bass (or too little) on some program material, you might have to get up and adjust your sub's output level knob. A minor hassle.
Also, there's a remote control thing that Wayne A. Pflughaupt uses. That would come in handy if you did indeed want control over the level feeding the sub. Sorry I can't think of the name of it right now... EDIT: it's called the Chase Technologies RLC-1 remote line controller (check Google/eBay if you're interested).
So, yeah, use your sub's crossover to filter out the highs that your mains are handling and go for it.
-- Otto
Old 02-17-07, 07:55 AM   #3 (Link)
Alias: Mark
Loc: Dallas, Tx
User: #2244
Since: Aug 2006
Marks57 is offline
Thanks Otto,
I actually brought home a Sunfire 10" sub from where I work last night to test it out. It does work and it does sound good.
The question I have for all of you 2 channel guys with a sub is....where do you place your sub? I connected the sub with 2 line levels from the preout on the amp to the line level in on the sub. The cables were only long enough to place the sub to the immediate left of the audio rack. I could tell the sound was a little off, meaning my towers have such good imaging, but I could tell that the low frequencies were slightly off the center axis.
Should I use 2 subs or place the sub on a side wall firing across the room? Also, I am planning on building a custom cabinet with 3 vertical sections. I could leave the bottom center section open to the floor and put the sub in the direct center of the 2 towers (front firing of course). What do you think about that idea?
What do you do?
Thanks, Mark
Old 02-17-07, 08:06 AM   #4 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Hi Mark,
What's your crossover point? If it's low enough you shouldn't be able to place the sub's location that easily. 80 Hz is a well-accepted upper limit for this, but I like to go lower. I have my mains crossed at 40 Hz using an IB sub, and I can't tell where the bass is coming from (the IB is outside the right main).
Placement is something that you can play around with, and there are no hard and fast rules. A lot of people place the sub in the corner to take advantage of some room gain. Some stereo-only guys actually run two subs in stereo. I would consider that if I had a dedicated stereo-only room that used subs. The center position you described would also help your imaging.
I'd say that for now, just buy a long cable and play around with placement until you find something that really works for you. Play around with that output level knob as well, and the phase knob if you have one. What mains are you using?
Good luck.
-- Otto
Old 02-17-07, 08:38 AM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Since your mains are fed full range and are not crossed with a HP filter, then the manual crossover on your sub will have to be quite low to ensure the common frequencies aren't additive creating a peak. This is likely what you heard.
If the sub is crossed low (i.e. < 60hz), then its location with respect to sound-stage is irrelevant, since it won't be localizable. Place it where it integrates best with the room and the mains. Use REW and do a response check to set it up properly.
Old 03-06-07, 05:32 PM   #6 (Link)
Alias: norpus
Loc: Melbourne
norpus's Avatar
User: #3037
Since: Oct 2006
norpus is offline
brucek wrote: View Post
Agreed. Have a look at the -3dB spec of your mains, that might be a starting point for the sub crossover
If you don't use REW, then a couple of warble test tones an octave above and below might be useful for level checking?
Cheers
Norpus
Old 03-08-07, 09:11 AM   #7 (Link)
Alias: Dan
Loc: Sudbury, ON
User: #7344
Since: Mar 2007
audiobomber is offline
Marks57 wrote: View Post
Thanks Otto,
What do you do?
Thanks, Mark
What main speakers are you using? As others have said, it sounds like you're crossing the sub at too high a frequency. Like most of us when starting out, you probably also have the sub level set too high. Did you try adjusting phase? I recommend a Radio Shack SPL meter so you can see what's happening. Well worth the investment.
Old 03-08-07, 09:19 AM   #8 (Link)
Alias: Dan
Loc: Sudbury, ON
User: #7344
Since: Mar 2007
Otto wrote: View Post
Hi Mark,
What you said would be true if he were using the tape outs, but since he's using pre-outs, the sub level is controlled by the volume setting on the preamp.
Old 03-08-07, 09:38 AM   #9 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
audiobomber wrote: View Post
Well, yeah. I meant that he wouldn't have independent control of the signal going to the sub, as when using a sub out or an LFE out on a multichannel processor.
-- Otto
Old 03-08-07, 12:50 PM   #10 (Link)
Alias: Dan
Loc: Sudbury, ON
User: #7344
Since: Mar 2007
So you meant he'd have to get up to adjust the levels during the setup stage only. OK, now I get it.
Old 03-08-07, 03:01 PM   #11 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I like the use of a stereo amp + sub and I am still using stereo with my 4 x 15" IB using an active stereo crossover on the main speaker channels.
Adding a 3.1 processor for center and rear channels for films makes me a bit of an HT dinosaur.
The obvious advantage (to me at least) is higher sound quality.
Place your sub between your main speakers and don't take anything for granted.
With my SVS cylinder I used a 60Hz crossover despite my 40Hz floorstanders playing fullrange.
Try REW to see what is really happening to your frequency response at the listening position.
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
Similar Threads
Confirming HDMI 7&8 channel pass through? MACCA350 General Discussion 12 03-19-07 05:44 AM
Two channel for now jackfish Home Theater Equipment 0 02-15-07 09:34 PM
Center Channel Placement help! robnsin1 Home Audio Speakers 5 01-24-07 05:05 PM
Separate speakers for 2 channel? JCD HiFi Audio Components 18 07-11-06 06:40 PM
2-channel audio forum? Sonnie HiFi Audio Components 20 07-10-06 05:39 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
