| HiFi Audio Components adding tube amp applicable for me?Discuss adding tube amp applicable for me? in the Home Theater | Audio and Video forum; adding tube amp applicable for me? I was pondering the idea of maybe adding an eastern electric minimax amp for my setup but dont know enough ... |
| | #1 (Link) | |||
| adding tube amp applicable for me? I was pondering the idea of maybe adding an eastern electric minimax amp for my setup but dont know enough about tubes to make an inteligent decision.I have a rotel rsx1056 powering System Audio speakers(sa17500,sa720,sa505's).also have a minimax cdp which i really like alot,maybe it's the tube effect regardless love this player.so impressed that i'm actually seeking advice regarding the tube amp.I use my sytem for everything via the receiver(HT,TV,2ch and multi music,Lexicon rt10 sacd/dvda).But the minimax i understand is only 8 watts,not knowing enough about tubes i've seen or read somethings about the low wattage of tubes being as good or better than ss amps.Would i benefit anything with a tube amp or is it out of the question for me knowing what i have and my use of my system.Any recomendations,opinions and advice would be whole heartedly appreciated.thanks I wanted to add that i suggested the eastern electric but am not necessarily set on it any tube suggestion would be appreciated.All the tubes i've seen advertised have be up to about 50 watts,just dont understand the low wattage compared to ss amps Last edited by enrique; 09-29-07 at 10:03 AM. | |||
| | #2 (Link) | |||
| | Re: adding tube amp applicable for me? As with so many things in audio, there is a huge Tube v. Solid State debate. What I'm about to post is simply my current beliefs based on the readings I've done.. stick with solid state I'll assume that you know the basic issues with tubes and solid state (even order vs odd order harmonics, clipping vs rolling off, etc). Where I think tubes would be the way to go would be with very VERY effecient speakers (e.g., horns), but for your typical cone/dome speaker, I'd stick with solid state. Someone from whom I've got a lot of respect for was even more specific -- he'd only use a SET tube amp, which are only going to get up to about 5-7 watts of power for his HF duties (he's also a HUGE proponent of active crossovers). He also went on to say that he'd use a solid state amp for a less efficient speaker (e.g., efficeincy of 90db included). JCD | |||
| | #3 (Link) | |||
| | Re: adding tube amp applicable for me? To give the "other" side of the arguement, this is copied from another forum that copied it from somewhere else.. anyway, the author is OBVIOUSLY pro-tubes and some of his arguements are pretty whacky (at least to me), but he also gives some good info.. Vacuum Tubes and Transistors Compared JCD | |||
| | #4 (Link) | |||
| Re: adding tube amp applicable for me? Although tube amps "can" make the sound warmer and are generally cleaner than solid state amps the cost per watt is more than dubble what solid state amps cost. The "coolness factor" of Tube amps is high but Tube amps draw a fair bit of power even when not in use. Warm up time is also a consideration plus they run much hotter and require some sort of cooling of the room. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #5 (Link) | |||
| Re: adding tube amp applicable for me? Hello, In a near future, I am going to use bi-amplification on my Yamaha NS-1000 speakers. I want to use a Mcintosh 275 tube amp for Mid and Tweeter. I will use a Rotel "solid state" to drive the woofers. But before that, I got to finish my sub-woofer project ! Does someone use bi-amp with a match fo tube and solid state amplifiers ? | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| tube buffer? | enrique | HiFi Audio Components | 4 | 11-28-07 02:02 PM |
| Adding a Power Amp to bi-amp from a Denon 3805 | Malice | Home Theater Components | 18 | 08-07-07 05:26 PM |
| Live Pro Sound - Is REW Applicable?? | Randall R. Dibble | REW Forum | 5 | 04-29-07 08:56 PM |
| DIY Oak Tube Amp Outshines Apple's iPod Hi-Fi Powered Speaker System | geekwithfamily | Home Theater, Audio and Video News | 0 | 10-31-06 05:20 PM |
| Adding Amp | rlogle | Home Theater Components | 3 | 07-20-06 01:52 AM |
