| HiFi Audio Components Tapco Juice AmpDiscuss Tapco Juice Amp in the Home Theater | Audio and Video forum; Tapco Juice Amp Does anyone have, or have opinions on, the amplifiers from Tapco? I am looking at the model 1400. The spec ... |
| | #3 (Link) | |||
| Re: Tapco Juice Amp Yes, I have the JBL Eons now but they are the unpowered ones. I also have a pair of Cerwin Vega D9's that I propose to maybe connect in parallel. Future uses for a high power amp could be driving a subwoofer setup. I am just poking along, trying to incrementally upgrade my stuff and catch the "deals" when I find them. Coming soon will be a Behringer V-Verb 2496 that I plan to announce in BFG. I mentioned the 2 ohm spec as more of a comparator. It seems that your higher quality or higher regarded amps feature 2 ohm capability without issue. Some of the lighter duty amps are not designed to run at 2 ohms. Also, where some amps may say they are great at 2 ohms, when a person does it they wimp out eventually. I don't have enough hands on experience to compare a lot of different product so I try to rely on some of my readings and the experience of others. I have shortlisted my amp desires to Crown, QSC, Behringer, or maybe the Tapco. Then I have to assess the dollars available and pull the plug when the time is right. I know I want the $450 Crown but the wallet says get the $300 Tapco. ![]() | |||
| | #4 (Link) | ||||
| Re: Tapco Juice Amp Quote:
The Tapco J-1400 is $300. Behringer EP2500 - 450 watts per channel, both channels driven into 8 Ohms at 20 Hz to 20 kHz and 0.1% THD. $350 Crown XLS 402 - 300 watts per channel, both channels driven into 8 Ohms at 20 Hz to 1 kHz and 0.5% THD. $400 I'd not hesitate to consider the Tapco, but I'd want to listen to one. A new J-2500 is $400 BuyItNow on eBay. 575 watts per channel, both channels driven into 8 Ohms at 20 Hz to 20 kHz and 0.03% THD. 750 watts per channel, both channels driven into 4 Ohms at 20 Hz to 20 kHz and 0.03% THD. 1400 watts per channel, both channels driven into 2 Ohms at 20 Hz to 20 kHz and 0.03% THD. There are also other sources for new J-2500s for $400. Based on reviews and anecdotes I'd buy the Tapco J-2500 for $400 before I'd get a Crown XLS 402 for $400 or the Behringer EP2500 for $350. Last edited by jackfish; 11-07-07 at 09:32 AM. | ||||
| | #5 (Link) | |||
| Re: Tapco Juice Amp So far I have not found a good source for a Behringer 2500 up here in Canada. One place wants $550. To get it from the US I would be paying over $50.00 for shipping, which I will do if I decide it is what I should get. As a comparator, the Tapco weighs 48.5 pounds vs. 36.6 pounds for the Behringer. You do get more of something, steel? It is available in my province for $318.00, free shipping. Whatever I do choose, I won't be able to listen to it beforehand. I live a considerable distance from sources of these items and do not travel down there very often. Certain times I do, like last year when a brand new blue Rickenbacker 620 came into the store. It was the only model and colour my daughter liked and you could wait two years before another one arrives. ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| SVS SB12-Plus & PB12-NSD review - Lyd & Bilde (English version) | L-Sound - Jan | SVSound | 4 | 12-16-07 01:41 PM |
| Adding a Power Amp to bi-amp from a Denon 3805 | Malice | Home Theater Components | 18 | 08-07-07 05:26 PM |
| News: Toshiba A2 & A20 prices reduced $100 & web enabled features | bobgpsr | High Definition | HD-DVD | Blu-ray | 0 | 06-29-07 12:36 PM |
| Calibration – Cant get a Flat response ? CM-140 & DSP1124 & REW | tapeshc | REW Forum | 8 | 04-10-07 09:52 PM |
| SVS SBS-01 & PB10-NSD review - Lyd & Bilde (English version) | L-Sound - Jan | SVSound | 0 | 03-27-07 01:26 PM |
