| HiFi Audio Components Single disc cd playersDiscuss Single disc cd players in the Home Theater | Audio and Video forum; Single disc cd players Everywhere I look I cant seem to find and good inexpensive single disc CD players anymore. Are they on the ... |
| | #1 (Link) | |||
| Single disc cd players Everywhere I look I cant seem to find and good inexpensive single disc CD players anymore. Are they on the way out or can one still find them. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #4 (Link) | ||||
| Re: Single disc cd players Quote:
My recommendation for a good CD player is use your DVD player - DACs are a fairly mature technology now so there aren't problems with lower end ones, but if you worry about it just use digital connection and let your receivers DACs take care of the job. | ||||
| | #5 (Link) | |||
| Re: Single disc cd players I would rather use a separate CD player because the A2 takes so long to boot up and is undue wear on it that I don't want. I would like to have one that has an optical out. My Yamaha 5 disc player upstairs is a great one but I want it to stay there. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #7 (Link) | |||
| Re: Single disc cd players I have an older nomad jukebox that I upgraded the HD to a 30 gig that I use but there still is something about an mp3 file that is not quite the same quality as the real thing (I have all my mp3s encoded at 60%vbr) and am not prepared to re sample all 350+ cds ![]() Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #8 (Link) | |||
| Re: Single disc cd players That I can understand. I don't like any form of lossless encoding, except on the road. My HDD is 500GB hooked up to my PS3 and I just store everything in WAV files. Before I was in the hobby everything (200+ albums) was ripped to 192kbps MP3s (not even LAME encoded :eek). I just sat down one day and ripped them while doing homework/reading and watching TV it took a while, but was well worth it. | |||
| | #10 (Link) | ||||
| | #11 (Link) | ||||
. I have listened to one and seen measurements proving it to be nothing special (as previously stated) I never said it was bad per say. I never said one was better than another - in fact if anything was implied it was that CD players are such an old technology (along with DACs) that any well made player will be the same as another at least audibly. | ||||
| | #12 (Link) | |||
| Re: Single disc cd players Well Id have to say that from a visual standpoint, not much is worse than a PlayStation in your rack, plus the lack of digital outputs and a door on the top would rule out any possibility of a ps1 entering my system. I have a PS2 in my setup, but Ive never played a DVD or CD on it. Whats wrong with a lower end DVD player? As was stated, if you use the digital out, you avoid cheap DACs and the signal to noise ratios are pretty good on all but the worst WalMart junk. That's what I'd do, but yaa know... | |||
| | #13 (Link) | |||
| Re: Single disc cd players Thanks for your replies. Certainly, they are nothing special other than providing adequate sound for dirt cheap ($10-$50). Digital output from cheap DVD players into a good DAC makes sense. If it is a decent transport one can use some of the improved relatively inexpensive DACs available to get some pretty good sound. The Diyeden Musiland is quite a unit for $300. | |||
| | #14 (Link) | ||||
| | #15 (Link) | ||||
. I prefer to use science rather than subjective opinion when it comes to decisions like these. With proper testing it can easily be proven that properly made DACs that are designed to be transparent are exactly that. Besides my suggestion was simply to buy a CD player and use it as a reader allowing the receiver's DACs to do the decoding as it were which means the CD player would have even less cause to change sound quality. I will point out that just because someone claims to hear something doesn't make it so - or are some cables really dancable? . | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Single or Pair of 'X' for HT use? | bumpnzx3 | Fi Audio | 32 | 03-14-08 03:18 PM |
| Two Velo 12's or a single 15"? | Bigdaddy999 | Home Audio Subwoofers | 19 | 09-27-07 06:38 PM |
| How would dual SVS PB-13 Ultras compare to a single JL f113? | jmcomp124 | Home Audio Subwoofers | 5 | 06-08-07 02:12 PM |
| I'm new to the forum, and have a single 15" IB... | Wes Whitmore | DIY Subwoofers - Infinite Baffle | 20 | 11-20-06 06:28 AM |
