| HiFi Audio Components Amp for desktop/computer system?Discuss Amp for desktop/computer system? in the Home Theater | Audio and Video forum; Amp for desktop/computer system? Any suggestions for a good integrated amp that I can use to power a small set of bookshelf speakers? (Epos ... |
| | #1 (Link) | |||
| Amp for desktop/computer system? Any suggestions for a good integrated amp that I can use to power a small set of bookshelf speakers? (Epos ELS3) Will be used to replace my computer speakers I'd like something with a volume control, take as little desk space as possible and good sounding but not expensive. Multiple inputs is a plus. Preferably under $300. My contenders: NAD C315BEE Cambridge Audio 340 Emotiva BPA-1 And Teac DR-H300 DVD Receiver (can handle digital input from soundcard) I'm not sure if I want a T-amp, although they are definitely small. | |||
| | #2 (Link) | |||
| How to mix together two sources (from two computers)? I have two computers but I want to feed their outputs through one set of speakers (computer->integreted amp->speakers). Is there some kind of device that is made for this purpose? I don't want buy an expensive studio mixer to do this. Because it's going to be used with a computer, I want something that doesn't take up a lot of desk space either. Last edited by warpdrive; 12-16-07 at 11:23 AM. | |||
| | #3 (Link) | |||
| | Re: How to mix together two sources (from two computers)? I moved this to the computer area and merged your two threads together since they were very similar. I'm not sure I know of a unit that would fit in a computer or would be particularly small, but an integrated amp should do the trick. You might find an inexpensive used one on Audiogon. Maybe someone else will know of something smaller. | |||
| | #4 (Link) | |||
| Re: How to mix together two sources (from two computers)? I'm not looking for something that fits IN a computer, just something that I can use to simultaneously mix sounds (so I can hear both computer's sound without switching inputs). | |||
| | #5 (Link) | ||||
| Re: How to mix together two sources (from two computers)? Quote:
For your purposes, try this ($50): http://www.behringer.com/502/index.cfm?lang=eng If you don't like the form factor, you can get a single unit rackmount mixer, probably about $90. At this point though, you're looking for amplification and a signal switcher, so an inexpensive 2 channel AVR is starting to make sense. I know it's bigger than you want, but the flexibility could be worth it. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #6 (Link) | |||
| Re: Amp for desktop/computer system? I guess if I end up with an integrated amp, I might as well get a rack mount style mixer at the same time so it stacks up nicely in a stack on my desk. I will probably wait until Headroom comes out with their speaker stands (ETA Spring release) to raise the speaker off the desk for best sound (I don't have any shelving behind my desk ![]() I like the little hanger off the side which allows me to hang my headphones neatly B&W CM1,686, Onkyo 875, Sony 46XBR2, SVS SB12-Plus, Mirage Omni S12, Epos ELS3, Energy RC Mini, Energy C3, PS3, NHT C3, Sanyo PLVZ3 + 92" Draper Cineperm, AKG K701, Headroom Micro DAC/Amp, | |||
| | #7 (Link) | ||||
| Re: Amp for desktop/computer system? Quote:
Not much to look at, but the headphone hanger is a neat idea. I've been using the unused pegs of my 7 guitar guitar-stand (only 5 guitars in there now). Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #8 (Link) | |||
| Re: Amp for desktop/computer system? Where did I get the info on that? Headroom Corp is a company that caters to headphone audiophiles and they are a sponsor at head-fi.org where I hang out a lot. They showed a prototype of this speaker/headphone stand and will be releasing this in a few months. B&W CM1,686, Onkyo 875, Sony 46XBR2, SVS SB12-Plus, Mirage Omni S12, Epos ELS3, Energy RC Mini, Energy C3, PS3, NHT C3, Sanyo PLVZ3 + 92" Draper Cineperm, AKG K701, Headroom Micro DAC/Amp, | |||
| | #9 (Link) | |||
| Re: Amp for desktop/computer system? Ah, I scoured the Headroom site (obviously not finding anything), but didn't check out head-fi. I'll try to find the info there. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #10 (Link) | |||
| Re: Amp for desktop/computer system? here is where I got that picture. No price mentioned yet in the thread. Headroom stuff isn't usually inexpensive (looking at the prices of their bags) http://www.head-fi.org/forums/f77/sp...stands-248155/ B&W CM1,686, Onkyo 875, Sony 46XBR2, SVS SB12-Plus, Mirage Omni S12, Epos ELS3, Energy RC Mini, Energy C3, PS3, NHT C3, Sanyo PLVZ3 + 92" Draper Cineperm, AKG K701, Headroom Micro DAC/Amp, | |||
| | #12 (Link) | |||
| Re: Amp for desktop/computer system? not really. My computer is in the bedroom. I just want something "den sized" that sounds ok with casual listening (but better than your average computer speaker) so I was looking for an amp and speaker setup that lets me enjoy my music B&W CM1,686, Onkyo 875, Sony 46XBR2, SVS SB12-Plus, Mirage Omni S12, Epos ELS3, Energy RC Mini, Energy C3, PS3, NHT C3, Sanyo PLVZ3 + 92" Draper Cineperm, AKG K701, Headroom Micro DAC/Amp, | |||
| | #13 (Link) | |||
| Re: Amp for desktop/computer system? My computer isn't in the listening room. Since it's my house, I was able to connect it to my sound system from the kitchen to to listening room. All the cables( interconnection) go under the floor from the kitchen to the listening room. I can listen to it casually anywhere in my home. Last edited by daniel; 01-15-08 at 11:14 AM. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| New system: Klipsch, Paradigm, B&W, or SVS? | killerdusty | Home Audio Speakers | 22 | 12-15-07 05:33 PM |
| Mike's B&W 600 Series System | trainCatcher | Home Theater Equipment | 5 | 11-02-07 12:21 AM |
| FS: 50" Samsung 1080P DLP & DVD upconvert/receiver with 5.1 surround system LG-HTI | E-A-G-L-E-S | Classifieds - Video Displays and Projectors | 2 | 09-18-07 06:32 PM |
| Let's see your desktop... | Sonnie | Chat Box | 37 | 08-01-07 01:35 AM |
| DIY Oak Tube Amp Outshines Apple's iPod Hi-Fi Powered Speaker System | geekwithfamily | Home Theater, Audio and Video News | 0 | 10-31-06 05:20 PM |
