Please help with CD Player ... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Discuss Please help with CD Player ... in the Home Theater | Audio and Video forum; Please help with CD Player ... I have a problem with my CD player (Sony CDP-C250Z)... when I insert a disc (1-5) it shows a message ...
Old 12-31-07, 07:48 PM   #1 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I have a problem with my CD player (Sony CDP-C250Z)... when I insert a disc (1-5) it shows a message "No disc"
I already try the reset (unplug the power cord, manual said about 30 minutes; but I left if overnight) and also in case of condensation I leave it on overnight (manual say 30 min - 1 hour) ... that didn't fix the problem
I send an email to Sony and their response didn't help (they told me to do what I did before) ...
I think that maybe is the laser that is dirty and doesn't read the discs ... I have a CD lens cleaner but i can't use it because the player doesn't recognize any disc ...
I need your advise to fix this problem ... I know the best thing is to take it for repair, but I want to try something else before doing that ... I think it will be cheap or a better option to get a new unit instead of fixing this old player ...
Old 12-31-07, 07:57 PM   #2 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Re: Please help with CD Player ...
Even ifit doesnt recognize it, it will still spin the cleaner disc, thus doing its job.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 01-02-08, 12:54 PM   #3 (Link)
Alias: doubeleive
Loc: stockton, ca. 95219
User: #12968
Since: Oct 2007
doubeleive is offline
well if you are atleast partially mechanically inclined you could #1 unplug it from the wall, #2 simply remove the top cover, look inside and see if you can access the laser head if you can #3 simply use a clean paper towel dampened with windex and dab it very carefully onto the laser head and then use the other end of the towel to dry the laser head, #4 wait a couple minutes and #5 plug it back in and while the cover is still off try to insert a disc and see if will play (it's ok to do this while the top cover is off) also be very carefull to not touch any other electrical parts while doing this (danger of electrical shock). if it works unplug it again and replace the cover. I have "salvaged" a lot of dvd & cd players this way, they often get dirty laser heads.
Old 01-02-08, 01:27 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
...Even ifit doesnt recognize it, it will still spin the cleaner disc, thus doing its job...
That's what I expected when I inserted the CD cleaner ... but it didn't work
...well if you are atleast partially mechanically inclined you could #1 unplug it from the wall, ... they often get dirty laser heads.
... I will try tonight ...and if doesn't work, it will be time to .. try something else ....
Thank you
Old 01-02-08, 02:57 PM   #5 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
conchyjoe7 is offline
Kind of a last resort, but have you tried a little compressed air? Be extremely careful because it's under high pressure, but I have known those that this worked wonders for....
Good luck,
Konky.
I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns.
Old 01-02-08, 03:10 PM   #6 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
conchyjoe7 wrote: View Post
Kind of a last resort, but have you tried a little compressed air? Be extremely careful because it's under high pressure, but I have known those that this worked wonders for....Good luck, Konky.
No, I haven't ...
I found on the internet a post from somebody who use I dryer to get rid of the condensation ... so, I used mine to blow cold air to remoe dust inside the player; but it didn't work ... I don't know if the compressed air will have more pressure than the dryer ... I will give a try
Old 01-02-08, 03:55 PM   #7 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
It may also be the alignment of the laser device and not just dust. That situation will dictate a trip to the repair depot... Let's hope for the best.
Konky.
Old 01-10-08, 02:44 PM   #8 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
...... I opened the CD player, cleaned the laser and it didn't work
I'm not sure, but I think the laser is gone ... I'm assuming that when you turn on the player, the laser will light up, Right??? ... After cleaning I plugged the player and turned on, I saw the carrousel spining and pick up the disc, spinned the disc and then drop it ....
Any idea how much can cost this repair??? ... I don't really need it, I have a CD writer that I'm using now, but in case that I want to give it away, I can tell that person was is wrong and how much it will cost to repair ...
Old 01-10-08, 03:04 PM   #9 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Take it to an electronics repair shop to get an estimate. Phone around and find out how much the estimate will cost. I had a Pioneer DVD player quit on me and when I took it in to get it repaired, I was told the the laser assembly was $400.00. The estimate cost was $25.00.
Old 01-11-08, 02:45 PM   #10 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
With all due respect, I think you've done about all you can for that patient. Give it a decent burial and move on...RIP!
Old 01-12-08, 01:06 AM   #11 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
salvasol wrote: View Post
For cd players it should be visable, but not always. Although the spectrum is just inside the visable spectrum for humans, the size and strangth of it may be too small. On the other hand DVD is just outside the visable spectrum and thus should not be seen at all.
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 01-13-08, 08:44 AM   #12 (Link)
Alias: daniel
Loc: Varennes, Québec
User: #5208
Since: Dec 2006
daniel is offline
Maybe it's time to look for another cd player. It could be wise to stay away from sony. They are good...as a marketing enterprise. There's so many good player you can find without going for a sony.
Old 01-13-08, 08:50 AM   #13 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
yourgrandma wrote: View Post
Actually, most players require focus lock before starting the spindle motor. Most likely this player is not cost effective to repair. Most likley a bad laser.
A good resource for laser info:
http://www.repairfaq.org/sam/cdfaq.htm
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 01-14-08, 01:45 PM   #14 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Thank you for all suggestions
Old 01-16-08, 07:14 PM   #15 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
You've already gotten some good advice.. but I also think it's time to retire your unit to the here-after.
JCD
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
Similar Threads
Did you get an HD player for Xmas? MatrixDweller High Definition | HD-DVD | Blu-ray 15 01-13-08 03:42 PM
Which 1080i DVD player of these three? E-A-G-L-E-S Home Theater Components 9 09-20-07 03:25 PM
dedicated cd player recommendation? enrique HiFi Audio Components 8 07-13-07 09:59 PM
Do I need a HD DVD player? SteveB High Definition | HD-DVD | Blu-ray 23 06-17-07 11:04 PM
what is the best dvd player scott Home Theater Components 6 12-14-06 10:55 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
