Headphones- need some help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > HiFi Audio Components
Discuss Headphones- need some help in the Home Theater | Audio and Video forum; Headphones- need some help I ordered the following DAC/amp for the office and I may use it at home some also. I ordered the ...
Old 06-12-08, 08:42 AM   #1 (Link)
Alias: Josh
Loc: St. Louis, Missouri
User: #13522
Since: Nov 2007
  bumpnzx3 is offline
I ordered the following DAC/amp for the office and I may use it at home some also. I ordered the fully upgraded version (I got in on a group buy- the fully upgraded version for a little less than the standard unit). http://www.hippohifi.com/products/bloat/bloat.html.
I wanted to keep the cost of my entire setup to no more than $300. I've spent a shade less than $200 on the DAC/amp- which leaves me with ~$100 for cans. I have it narrowed down to 4 and I need some help from there.
Grado SR80, Senn HD280, and the AKG K141S or K240S.
I listen to a broad range of music, but more folk/acoustic than anything (Ray LaMontagne, Alexi Murdoch, Donovan Frakenritter, etc..). I like crisp/bright sound, within reason. I would like to keep the sound outside of the phone down to a reasonable level- I would like to be able to turn the volume up a little, but not bother those around me at work. I am leaning towards one of the AKG cans- a good compromist between a full open and an enclosed can- not to mention good reviews.
Old 06-12-08, 08:56 AM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Headphones- need some help
AKG tends to be the choice for recording studios. I have several pair lying around from the late 80's that still sound as good as they did when new. Grado and Sennheiser both make a great product as well it comes down to your taste and what you want to hear, Have fun shopping.
Home theater:
Onkyo TXSR805, Samson Servo 4120 amp bridged @240wattsX2
Mission 765 Mains, 762i's Surrounds, AR center PSC25, SVS PB13 Ultra, A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z2 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 5 CD changer, LG DV7832NXC DVD player, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-12-08, 09:01 AM   #3 (Link)
Alias: Josh
User: #13522
Since: Nov 2007
  bumpnzx3 is offline
I was already leaning towards the AKG's- thanks for the push. One thing you may be able to help me with since I am new to headphones- how much sound escapes an open (or semi open in the case of the AKG's)? Should bothering my co-workers be a concern? I don't blast my music really loud- but I do turn up the volume on occasion. Would the sound escape more than say a standard cheapie heaphone that comes with a mp3 player or personal cd player?
Old 06-12-08, 09:07 AM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
bumpnzx3 wrote: View Post
It depends on how quiet it is on your office, The semi open design will alow more to escape than a fully closed design BUT the AKG's will let less out than a cheap pair of headphones and will sound much better at lower volumes.
Home theater:
Two Channel system:
My Webpage
Old 06-12-08, 09:30 AM   #5 (Link)
Alias: Josh
User: #13522
Since: Nov 2007
  bumpnzx3 is offline
There's always random chatter going on around me. As long as the escaping sound isn't going to be more than a standard set of cheapies- I don't really care. Thanks!!
Old 06-13-08, 08:42 AM   #6 (Link)
Alias: Josh
User: #13522
Since: Nov 2007
  bumpnzx3 is offline
had a chance to listen to some '06 model Beyerdynamic DT660's last night. has anyone had a chance to hear those in order to fill me in on the differences between those and the akg k270 or the senn hd280?
« Home Theater Shack > Home Theater | Audio and Video > HiFi Audio Components »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
