| HiFi Audio Components Home Audio Amps VS Pro DJ Amps?Discuss Home Audio Amps VS Pro DJ Amps? in the Home Theater | Audio and Video forum; Home Audio Amps VS Pro DJ Amps? WmAx wrote:
I would be difficult for me to care what some one thinks they hear with an amp in ... |
| | #26 (Link) | ||||
| Re: Home Audio Amps VS Pro DJ Amps? Quote:
I've said this many times before...If you can't hear any difference; good for you: Just think of how much money you have (or can) save(d) by being able to buy a $499.99 HTIB and it sounds as good to you as anything out there. I imagine to some an IC output device also does as good a job and sounds for all intents and purposes identical to a totally discrete output stage; especially at high SPLs... I will admit that it does seem a little strange to me that the people that almost always seem to be attempting to justify and defend their purchases are ones that have bought "pro" gear or other ummm, shall we say less expensive equipment with 10 zillion watts per channel into 0.0000001 THD even though it costs $200.00 and weighs in at 12 lbs, and not the people that have bought "high(er) end" gear and are delighted with it. It does make one wonder that what with no differences, why Abbey Road Studios would see fit to use B&W 802D speakers and power them with Classe Audio amps...hmmm?! As I said in my first response...this argument will never go away. If you're happy with what you have; that's great irregardless of what you have... Whatever you have; enjoy the music and movies...I believe THAT is the point! Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. Last edited by conchyjoe7; 02-05-08 at 12:09 PM. | ||||
| | #28 (Link) | |||||
You are correct in saying it is unlikely that someone would be able to ABx or double blind test every purchase they make, but it is possible to avoid this step with credible measurements and application of various research in the field. If one understands what aspects could make an amplifier audible with a certain pair of speakers at required SPLs then it is completely feasible for someone to purchase an amplifier based on measurements alone that will be completely inaudible with any given speaker. Quote:
As far as the Classe amps paired with the B&W802Ds this is likely a packaged purchase. Simply put the B&W802Ds are some of the highest quality monopolar speakers on the market especially as it relates to studio monitoring. This is due to their extreme linearity and lack of all audible coloration. Classe happens to be owned by the same company that is owns B&W. So it is likely a deal in which the parent company 'sponsored' the studio occurred where they got a "one company" system. For more on the subjective/objective debate as it relates to amplifiers please focus your responses to this thread. This is normally an extremely easy fix if you don't mind opening up your unit. For some pro amps you can just pop in a replacement fan that has a lower noise floor. For others you can solder a resistor in the line that slows the stock fan down. This weekend barring time I will be replacing the fan in my EP2500 and plan on taking pictures for a mini tutorial. -Andrew | |||||
| | #29 (Link) | |||
| Re: Home Audio Amps VS Pro DJ Amps? There are pro amps that are convection cooled you just have to look a bit harder for them Samson has some great convection cooled amps (there servo line for example) Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #30 (Link) | |||
| | Re: Home Audio Amps VS Pro DJ Amps? Check out the Quieter fan mod for Behringer EP2500. | |||
| | #31 (Link) | ||||
| | #32 (Link) | ||||
| | #35 (Link) | ||||
I have stacked double New Large Advent loudspeakers that are each rated for, I suppose, about 65 watts RMS. However, I can tell the difference having each speaker driven by an amplifier with 200 watts per channel. Transient peaks seem to sound better with the so-called dynamic headroom available to handle them. Stacked double Large Advents driven with a Phase Linear 700 amplifier have been compared to the finest electrostatic loudspeakers available back in their day (The Absolute Sound). | ||||
| | #37 (Link) | ||||||
![]() -Chris | ||||||
| | #38 (Link) | |||
| Re: Home Audio Amps VS Pro DJ Amps? Yes, at one point down the line I will have to be upgrading to a separate amp to run these, and I will keep in mind the power thoughts. If only I could rent out a couple different amps and try em out.. = ) However for now, I have tweaked my current amp, and I am started to get quite satisfying results. 2- 58" King Sound Prince Electrostat Loudspeakers 2- Infinity Audio PS210 Powered Subs to got with Electrostats Jensen Center (soon to be replaced by: 1- Definitive Audio CLR2300 Center Channel 4- Technic SB-T100 (surrounds) 3- JL 10" Subs Kenwood VR-6070 THX Receiver --- Denon AV600 ---- Technic SU-Z900 Acer XD1170 Projecter --- 120" Screen | |||
| | #39 (Link) | |||
| Re: Home Audio Amps VS Pro DJ Amps? I am also looking to purchase enough amps to configure a 5 channel setup. So my question is which DJ/pro audio amplifier is/are considered warm. I have no experience in this market so I will need names and model #'s of like.... the best 5 that are warm ( I would like to stay under 900.00 for all 5 channels) (I realize I will probably end up with an extra channel along the line....I assume I would be buying 3ea 2 channel amps). The reason I dwell on warm is I have klipsch rf-7's and they get too loud/harsh during action sceens. I was using an emotiva lpa-1 (125w X 5)....and it was pretty bright so I sold it, and am now using just receiver power (denon 2808) and its worlds better (noticeabily warmer). I would leave it the way it is.... but with the emo I did notice the sound stage was alot bigger (it seemed like all the sound was coming from the screen, I could't really notice the speakers), Now I notice the left-right-center speakers. But because the "extra brite" (compared to the emo) is gone I preffer the denon (lesser of two evils). So I'm convinced with amps.... but I do not know which to buy, that fit my budget and warm/smooth detailed sound that I am looking for. Or am I better off just buying a used 5 channel 1095 or like ect. O....1 more question I am using an ep2500 for my subs and I had to buy a line level boost (I bought an sms-1) because I could get any volume aut of the subs.......Will I have to do that crap with the Dj amps for the 5 channel also??????? | |||
| | #40 (Link) | ||||
| | #41 (Link) | |||
| Re: Home Audio Amps VS Pro DJ Amps? pietsch288 Have you tried playing around with the Audessey built into your Denon? Those RF-7's sure can sound bright on loud passages, I've had some experience with them. IMHO, this is not going to be best solved through the purchase of an amp and it is tough to say which amps if any are going to sound warm. The RF-7's are highly efficient so whatever amp you choose you will not need to choose it for high power rating, and so for this case I'd probably rule out DJ or pro amps as they are geared for power. I would look at some small older amps from Adcom or Parasound or Rotel or Marantz or.... could go on and on. A lot of people say Rotel sounds laid back that may be one to look at. Before you spend your money though, play around with the eq and try moving your speakers if possible. Have you done any room treatments? | |||
| | #42 (Link) | |||
| Re: Home Audio Amps VS Pro DJ Amps? The older Yamaha M series from the mid 80's had a great warm sound there are two M80's on ebay right now that would do a great job. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #43 (Link) | ||||
Or is this 'warm' assessment of the common non-controlled listening comparision variety? -Chris | ||||
