| High Definition | HD-DVD | Blu-ray Best budget Blu player with internal Audio decode?Discuss Best budget Blu player with internal Audio decode? in the HD World | Computers | Games | Media forum; Best budget Blu player with internal Audio decode? Hey all,
As my system is just fine I dont want to have to invest in HDMI upgrade as it ... |
| | #1 (Link) | |||
| Best budget Blu player with internal Audio decode? Hey all, As my system is just fine I dont want to have to invest in HDMI upgrade as it gets really expensive at the seperate Processor level. In learning about the new formats which I happily held off on till one was killed off I understand if the Blu player has internal advanced audio decode capabilities I can hook up Multi-Channel RCA and get the advanced audio I would like to incorporate along with gain in video. Being on fixed income I am in a price sensitive position so I want to know best budget options with this decode feature.................thanks as always. | |||
| | #4 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? There are currently no players on the market that will internally decode ALL of the latest codecs. You will have to wait for the sony BDP-S550 for 7.1 in all the codecs. If you are willing to use 5.1 the Panasonic DMP-BD50 will also be coming soon. I imagine both will price in at around $500. If you are willing to forgo DTS MA and use only 5.1, the Samsung BD-P1400 is your best bet and can be found for $400 or less. Personally, I would wait a while longer to upgrade. Last edited by hddummy; 04-07-08 at 05:34 AM. | |||
| | #5 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? Thanks for the reply, yup I am going to wait....I have been burned by early adoption before and my room size and preference demands 7.1................thanks again! | |||
| | #6 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? No problem. Check out this website for a good summary of each player's functionality. http://www.idoblu.co.uk/page2%20Blu-ray%20Players.html Keep in mind that there are very few movies that are actually mixed with a 7.1 soundtrack. If you are using your 7.1 direct analog inputs on your AVR, you will likely not be able to mix audio to your rear speakers with PLIIx or similar. If you want 7.1 on these movies, you will probably have to connect an SPDIF optical cable as well and use the downmixed 5.1 (DD or DTS) signal from the player to your AVR. Maybe even more importantly, many AVRs don't apply any bass management or signal processing to the discrete analog inputs. Here is a list of blu-ray movies and their soundtrack info. I'm not sure if this 100% accurate, but it's something to go by. http://mysite.verizon.net/ruvic/bluray-audio.htm Last edited by hddummy; 04-03-08 at 07:30 AM. | |||
| | #7 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? That's a good link. Keep in mind it's from the UK and there may be finite differences in some features, etc. I pointed out to the author that the LG duo players are shown with 5.1 and 7.1 analog audio outputs. But if you go to the LG website, specs and manuals confirm (as well owners on various forums) that this is not the case. Strangely, he sent me a very small photo of an LG player (back only) that looked like it had analog audio outputs. But the connectors were all to one side, on the LG in question they are close to center. Very strange. I suggested it was either a different model or non-US version... ![]() Appreciate the link to the BD disks. There is generally confusion about what tracks are present and which ones can be detected, decoded, or re-encoded for DTS bitstream. Not all are handled the same way by all players. Arcam AVR350, Dali Ikon 5.1, Velodyne DLS5000, Cambridge Audio 740C, Toshiba X-A1, Samsung BD-UP5000, Polk XM Tuner, Furman power conditioner | |||
| | #8 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? Thanks again, I know there is as of yet no true 7.1 but seeing as I run 7.1 speaker configuration and have no intention of upgrading my Processor for just HDMI (as I run video direct via HDMI to Projector) any time soon I feel buying a 7.1 is best bet to help avoid the early adoption blues. From Sony PS3 with no DTS support to other units that wont decode "this" or dont do "that" I want to try to avoid these mistakes and future regret. In the time between a new Processor with HDMI I want the most ideal unit to run 7.1 RCA, ofcourse I can run Digital Tos or Coax aswell if needed. Cheers | |||
| | #9 (Link) | ||||
| Re: Best budget Blu player with internal Audio decode? Quote:
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #10 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? Ummm Internal audio decode... But what about bass management?? Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #11 (Link) | |||
| Re: Best budget Blu player with internal Audio decode? BD player owners, Does your players who internally decode audio codecs provide bass management? Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Looking for a Blu-ray player? What U need 2 Know! | Wayde | High Definition | HD-DVD | Blu-ray | 37 | 06-10-08 06:23 PM |
| What is the best Blu-ray player available now? | Sonnie | High Definition | HD-DVD | Blu-ray | 69 | 03-16-08 09:59 PM |
| HD DVD players decode the audio -- not the AVR | bobgpsr | High Definition | HD-DVD | Blu-ray | 4 | 02-18-08 11:43 AM |
| Blu Ray Player | rlogle | High Definition | HD-DVD | Blu-ray | 25 | 01-27-08 08:16 PM |
| Budget amp. Cambridge Audio 340 or NAD C315BEE | warpdrive | HiFi Audio Components | 1 | 12-23-07 09:50 PM |
