Advice on AVR for Blu-Ray player - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss Advice on AVR for Blu-Ray player in the HD World | Computers | Games | Media forum; Advice on AVR for Blu-Ray player Hi all, I am going to be jumping into blu-world with the upcoming Pioneer Elite BD player, and I have ...
Old 05-20-08, 12:33 PM   #1 (Link)
Alias: Derek
Loc: Colorado
Vader's Avatar
User: #1439
Vader is online now
Hi all,
I am going to be jumping into blu-world with the upcoming Pioneer Elite BD player, and I have two options for the audio. Currently, I am running a Denon AVR2105, but it only has a single set of analog inputs (currently occupied by my Onkyo HD-DVD player). So, when the new player gets here in August (fingers crossed), I have three options:
1) One of the players gets the shaft (audio speaking) and simply uses SPDIF (not really an option).
2) I get the Zektor analog switcher, which lets me keep the HD sound, but is still dependent on the BM in the respective players. This route also means I need to procure twelve more audio cables.
3) I upgrade to the Denon AVR1908, which is HDMI 1.3, and run both the Onkyo and Pioneer via HDMI. This is assuming that the Pioneer will decode all formats and send them as PCM (the Denon does not decode TrueHD or DTS MA from bitstream). As I understand it, this way I will use the BM in the Denon, and the Audessy EQ will apply to the HD sound as well.
However, in the manual for the Denon (P 11), it states that in order to use HDMI for audio/video, both the connected DVD player and monitor must be HDCP compliant. My display is currently component only, so I would only be using the HDMI for audio. Am I understanding the manual correctly, and that I cannot do this (I know the reverse works – HDMI for video and analog for audio)?
Basically, I am looking at either using an expensive band-aid to keep HD sound for both players, and then upgrading the AVR and display at the same time down the road (which will probably be better than what I can get right now), or simply upgrading the AVR and being done with it (but lacking many of the features I would likely get by waiting). Any opinions would be greatly appreciated!
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.
Hmmmmm.... SVS..... No Bass Left Behind....
Old 05-20-08, 04:55 PM   #2 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Re: Advice on AVR for Blu-Ray player
Hi Derek , long time...
I was in a similar situation and decided to go for no. 1. I think it's your best bet at this time, and you still have the opportunity to jump to option 3 later on.
I don't think you'll be missing that much with core codecs. They already sound excellent, and IMO the material itself is much more relevant than being interpreted in DTS MA or core DTS 1500 Kb/s
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 07-23-08, 06:36 PM   #3 (Link)
Alias: Derek
Loc: Colorado
Vader's Avatar
User: #1439
Vader is online now
Blaser, I haven't left the building, really!
Looks like I am going to follow your suggestion. The analogs on the Elite player are not an option, anyway. The bass management capabilities of this player are extremely limited (ie. no distance settings, no variable c/o, and no mention of what the fixed c/o is). Given the player's other attributes, I am still looking at it because down the road the analogs will be a non-issue anyway. It just irritates me that this is the third game of catch-up the blu camp has had to play: first, the PQ (or lack thereof) of the BD roll out titles; second, internet interactivity (which I couldn't care less about); and now there is no BD player out there (aside from the Denon $2k 3800) that has the BM capabilities to match those which every HD-DVD player (with analogs) has had for over two years . I am excited to get into Blu Ray, but this is just discouraging. I guess I will just have to "live" with the legacy sound formats on BD just a little while longer (which sound great, anyway)...
Peace... Vader
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray »
Similar Threads
Looking for a Blu-ray player? What U need 2 Know! Wayde High Definition | HD DVD | Blu-ray 37 06-10-08 06:23 PM
Need advice on a Blu Ray player. cruzmisl High Definition | HD DVD | Blu-ray 3 04-16-08 03:20 PM
Considering the PS3 for my Blu-ray player... Sonnie High Definition | HD DVD | Blu-ray 64 03-22-08 04:05 PM
What is the best Blu-ray player available now? Sonnie High Definition | HD DVD | Blu-ray 69 03-16-08 09:59 PM
Blu Ray Player rlogle High Definition | HD DVD | Blu-ray 25 01-27-08 08:16 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
