Firmware 4.0 for 1st gen Toshiba A1, D1, XA1 HD DVD players - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss Firmware 4.0 for 1st gen Toshiba A1, D1, XA1 HD DVD players in the HD World | Computers | Games | Media forum; Firmware 4.0 for 1st gen Toshiba A1, D1, XA1 HD DVD players Edit: Version 4.0 firmware is available for CD-R ISO update. See this post . Go to: http://tacp.toshiba.com/tacpassets-i...-XA1-3001N.zip http://tacp.toshiba.com/tacpassets-i...D-A1-3001N.zip for a ...
Old 04-27-07, 04:19 PM   #1 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
Thumbs up Firmware 4.0 for 1st gen Toshiba A1, D1, XA1 HD DVD players
Edit: Version 4.0 firmware is available for CD-R ISO update. See this post.
Go to:
for a Toshiba America ISO download of version 3.0 firmware.
http://www.tacp.toshiba.com/resource.asp?resourceid=52
Resource for : Firmware Update Information for Owners of Toshiba HD DVD Players: Models HD-XA1, HD-A1, and HD-D1
Firmware Update Version: 3.0
Applicable Models: HD-XA1, HD-A1, and HD-D1.
Overview: As part of our commitment to provide world-class service to our customers, Toshiba is supplying this firmware update for use by purchasers of Toshiba HD DVD Player models HD-XA1, HD-A1, and HD-D1. This firmware update improves network connectivity for supporting the download of web-enabled network content associated with certain HD DVD discs, improves certain video and audio processing capabilities, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Important Note: Certain HD DVD discs may contain or have the capability of downloading studio-provided, web-enabled network content. To minimize any potential compatibility and/or connectivity issues, before viewing such content, it is recommended that you perform the firmware update process to ensure that your HD DVD player is using the latest firmware version.
How to obtain and install the firmware update:
1. If you have broadband internet service, you may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. There are instructions for configuring the Ethernet port on pages 44-45 of the owners manual. Page 57 of the owners manual describes how to download the firmware update. Here is an overview of the process:
BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
Please configure the Ethernet port. You may need to turn on DHCP and DNS. Page 45 of the owner’s manual explains how to do this.
After you have configured the Ethernet port, follow the directions on page 57 to check for a firmware update.
If a firmware update is available for your player, it will take about 20 minutes to download and install. Once the firmware update download process has finished, the player’s power will automatically switch off. You must wait until this process has finished.
DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at (800) 319-6684.
If no firmware update is available, the player will quickly exit the firmware update process.
Please refer to the owners manual for additional details.
2. If you have a PC with a CD-RW drive that is connected to the internet, you may be able to download an ISO image file of the firmware update to your PC and copy it to a blank CD-R or CD-RW disc. For more information, and to download an ISO image file of the firmware update click here.
3. If you are unable, or prefer not, to obtain the firmware update by one of the methods described above, you may contact Toshiba Customer Solutions at (800) 319-6684 and request that a firmware update disc be sent to you by mail. You can update the firmware using the firmware update disc by following the instructions provided with the disc.
Please note that if you sent Toshiba the Firmware Update Request card included with your player, you will receive an update disc by mail from Toshiba as soon as it becomes available.
Frequently Asked Questions:
Q1. What does this update do?
A1.This firmware update improves network connectivity for supporting the download of web- enabled network content associated with certain HD DVD discs, improves certain video and audio processing capabilities, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Q2. Why do I need to turn on DHCP and DNS?
A2. Turning on DHCP causes the player to automatically detect its IP address and other network information from your internet service provider’s DHCP server. Turning on DNS causes the player to automatically detect the DNS server address associated with your internet service provider.
Q3. I purchased an HD DVD disc that contains/has the capability of downloading web- enabled network content. What do I need to do to view this content?
A3. First, be sure that you have properly configured the player’s Ethernet port. If your Ethernet port is properly configured, perform the firmware update process to update the player’s firmware to the latest firmware version. Once you have updated the player with the latest firmware, follow the directions that came with the HD DVD disc or that appear in the menu of the HD DVD disc. Should you experience problems viewing such content, please contact Toshiba Customer Solutions at (800) 319-6684.
Q4. The HDMI output does not work or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does the new firmware address that issue?
A4. The firmware update addresses and improves HDMI and DVI connectivity issues. If you still experience such issues, try disconnecting and reconnecting the HDMI cable. Make sure your display input is set to HDMI (or DVI). If your display has more than one HDMI/DVI input, make sure that all connected HDMI/DVI source devices are powered on (even if not in use). If none of these solve the issue, please turn off the TV and the HD DVD player. Check all connections. Disconnect and reconnect the HDMI cable. Turn on the TV first and then turn on the HD DVD player. Should you continue to experience issues, please contact Toshiba Customer Solutions at (800) 319-6684.
Q5. During HD DVD playback I sometimes experience pixelization, block noise or audio dropouts. Sometimes playback freezes or stops. Sometimes, playback is not smooth. Does the new firmware address these issues?
A5. This firmware update addresses various playability issues. You should also check to be sure that the disc is clean and, if the disc will not operate at all, that you are inserting the disc with the right side up. In the event that playback freezes or stops, press and hold the ON/STANDBY button on the front of the player for approximately ten seconds. This will cause the player to turn off. After the player turns off, turn the player back on by pressing the ON/STANDBY button, and then press the OPEN/CLOSE button to remove the disc. Should you continue to experience issues, please contact Toshiba Customer Solutions at (800) 319- 6684. Should you continue to experience issues, please contact Toshiba Customer Solutions at (800) 319-6684.
Q6. Do I need to install prior firmware updates before installing the current firmware update?
A6. No. The current firmware update includes all of the prior firmware updates.
Last edited by bobgpsr; 09-27-08 at 01:34 PM.. Reason: mentioned vers 4.0 firmware release
Old 04-27-07, 09:15 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Re: Firmware 2.2 for 1st gen Toshiba A1, D1, XA1 HD DVD players
I updated my HD-XA1 to version 2.2 firmware using the ethernet tonight with no problems. Did not notice any changes playing Happy Feet with selection of the TrueHD lossless audio track (no problems before). I do use component video though.
I just gotta update! Can't help myself.
Old 05-19-07, 04:11 PM   #3 (Link)
Bronze Supporter
Alias: Dale
htaddikt's Avatar
Loc: Clovis, CA
User: #8963
Since: May 2007
  htaddikt is offline
Update worked great, and definitely cut load times in half. (well, from recognizing disk until start of play).
TrueHD is exceptional with a player that has 6 analog output channels. Probably the best 'disk' audio I've heard next to my Cambridge Audio 740C.. (stereo only). Limited by availability of software.
I've been very happy with my XA1. A few glitches now and then. Fewer now.
Since I still have a 720p display, no reason to jump into a 1080p machine. At least not until they get down to $200. LOL
Old 06-29-07, 01:44 PM   #4 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
I have read some reports by HD DVD disc reviewers that they got sent new firmware 2.3 on a CD (for gen 1 players) in order to review new web enabled HD DVD titles like "Blood Diamond", Bandai's "Freedom vol 1" and Warners "300".
Old 06-29-07, 02:04 PM   #5 (Link)
Loc: L.A. (Lower Bama)
Is this update available for download yet... the ISO version?
Old 06-29-07, 02:30 PM   #6 (Link)
Bronze Supporter
Alias: Dale
htaddikt's Avatar
Loc: Clovis, CA
User: #8963
Since: May 2007
  htaddikt is offline
Try www.1080x1920.net
Haven't seen anything on a 2.3
Arcam AVR350, Dali Ikon 5.1, Outlaw Audio LFM-1 EX, Anti-Mode 8033, Cambridge Audio 740C, Toshiba X-A1, Polk XM Tuner, Furman power conditioner
Old 06-30-07, 01:07 PM   #7 (Link)
Yeah... I was confused anyway... I have the XA2.
Old 07-03-07, 12:56 PM   #8 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Version 2.3 firmware for the HD-A1 and HD-XA1 (1st gen) is out. For an ISO download to burn to a CD see Toshiba Canada site: http://209.167.114.38/support/ceg/downloads/index.asp
The Toshiba America website now also does mention it for direct ethernet update.
http://www.tacp.com/tacpassets-image...vdfirmware.asp
also avail as ISO at Toshiba America site:
http://tacp.toshiba.com/tacpassets-i...ngfirmware.asp
Last edited by bobgpsr; 07-03-07 at 07:23 PM.. Reason: new 2.3 version now mentioned on Toshiba America site
Old 07-03-07, 01:55 PM   #9 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Re: Firmware 2.2 (& 2.3) for 1st gen Toshiba A1, D1, XA1 HD DVD players
One piece of info about firmware 2.3 posted elsewhere is:
The fix addresses HDMI handshake issues that some users are still experiencing and Sound dropouts.
Old 07-04-07, 01:47 PM   #10 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Re: Firmware 2.3 for 1st gen Toshiba A1, D1, XA1 HD DVD players
I burnt an ISO CD using the XA1 image from the Toshiba America site. No problems with using it to update my HD-XA1. It now shows "2.3/1.0A/2.0T" in its update menu (for current 2.3 firmware now inside the player).
Old 07-04-07, 03:33 PM   #11 (Link)
Bronze Supporter
Alias: Dale
htaddikt's Avatar
Loc: Clovis, CA
User: #8963
Since: May 2007
  htaddikt is offline
Downloading it now as we 'speak'.
Old 07-12-07, 07:21 AM   #12 (Link)
Alias: Tom
Tommy's Avatar
User: #51
  Tommy is offline
2.3 was my first full firmware update done connected straight to the internet. Previous to that I did the download of the ISO file or waited for the actual snail mailed CD. I must say it was rather easier then I expected, just ran an ethernet wire from my router to the HD player and started the update. Took about 45 minutes to complete download and installation.
Since the addition of firmware 2.1 HD-A1 or HD-XA1 there has been an added page of internet settings to the users manual. An updated digital copy of the manuals can be downloaded directly from Toshiba if any are interested.
http://www.mytoshibahddvd.com/ and click on the Support tab, manuals are then on the left hand menu
Old 07-12-07, 08:48 AM   #13 (Link)
Alias: Derek
Vader's Avatar
Loc: Colorado
User: #1439
  Vader is offline
I just downloaded the revised manual for the A1.... does anybody else see a lot of the bolded text as being kinda "jumbed"....?
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
The Overlook Theater - Not liable for injuries sustained while laughing.
Old 07-12-07, 08:52 AM   #14 (Link)
Alias: Tom
Tommy's Avatar
User: #51
  Tommy is offline
Ya I see some jumbled text also but I seen this previously too on the pdf. I have also downloaded the HD-A2 manual and noticed the text on this one seems ok so I been comparing them
Old 07-12-07, 11:59 AM   #15 (Link)
Bronze Supporter
Alias: Dale
htaddikt's Avatar
Loc: Clovis, CA
User: #8963
Since: May 2007
  htaddikt is offline
Toshiba USA finally has a website for downloads.
But I find the wireless internet connection I established with my player a lot easier, but slower.
Old 08-16-07, 03:29 PM   #16 (Link)
Alias: mister DIY
Loc: signal hill,ca
User: #6899
  Iggster1986 is offline
I haven't updated my player and probably wont ever again, 2 times have I had my player bricked when updating. First was using a direct net connection and second was with the iso.
Old 08-17-07, 09:30 AM   #17 (Link)
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
I didn't have any issues before but updated my HDA2 anyway via an ISO image burned to a CD. I've had no issues with the update.
Old 11-15-07, 10:32 PM   #18 (Link)
Tech'y Shackster
Alias: Bob
User: #25
  bobgpsr is offline
Firmware 2.4 is out for ethernet update. I am trying an update right now. 10% so far.
Edit: Update completed smoothly and the XA1 powered down by itself. A power up and going into the Update menu shows new firmware version:
2.4/1.0A/2.0T
Tried a HD DVD (HollywoodLand combo) quickly and seems that everything is still working fine. Settings survived -- I did not do an Initialize.
Old 11-19-07, 11:26 AM   #19 (Link)
Tech'y Shackster
Alias: Bob
User: #25
