HD DVD players decode the audio -- not the AVR - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD-DVD | Blu-ray
Discuss HD DVD players decode the audio -- not the AVR in the HD World | Computers | Games | Media forum; HD DVD players decode the audio -- not the AVR I got asked a question via PM about how to set up an AVR for the advanced codecs used with ...
Old 04-03-07, 08:44 AM   #1 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
I got asked a question via PM about how to set up an AVR for the advanced codecs used with HD DVD such as DD+ and Dolby TrueHD. After answering I thought that the info could use repeating here with a normal post.
For HD DVD the player must decode any audio codec used on an Advanced Content HD DVD title (most all HD DVD's are authored as Advanced). The player then mixes the audio with button sounds and with PiP (HDi) commentary audio. It sends the resulting audio out the HDMI interface as multichannel linear PCM which is what an AVR will show (MPCM). Everything is working normal, you are getting the full benefit of the HD DVD audio since multichannel linear PCM is lossless. Nothing to change in your AVR. You are all ready to select and fully benefit from a Dolby TrueHD lossless audio track on a HD DVD that offers it as a choice in its menu (the HD DVD menu or the player's remote control Audio button).
The other lossless audio connection option is with the 5.1 analog outputs that the Toshiba HD-XA2 and earlier 1st gen (HD-A1, HD-D1, HD-XA1) have. This is connected with 6 RCA patch cables to your AVR/Pre-Pro's 6 channel (Multi Channel) input. Often there is a discrete button on the front of an AVR or remote control to select this direct 6 channel input (aka Multi Chan Input).
An industry common practice is to require that the AVR/Pre-Pro or the subwoofer boost the LFE analog by +10 dB to get the proper Dolby/THX LFE playback level. Movies expect the normal channels to have audio peaks at +105 dB SPL but the LFE channel to peak at +115 dB SPL. Such boost is automatically done internally in an AVR when connected by a digital S/PDIF (coax or optical Toslink) connection that uses legacy DD or dts audio codecs. But the boost is not normally done with a 5.1 analog input connection -- it requires deliberate action by the user to configure it right. Some AVR/Pre-Pro's have a special option to do the +10 dB boost needed for LFE. Another way is to do a separate 5.1 analog input calibration (most AVR's can do a different cal for S/PDIF) where you boost the subwoofer gain at the subwoofer amp by +10 dB.
Note that this extra effort to get the right +10 dB LFE boost on an 5.1 analog connection is common need/practice for SACD, DVD-Audio, HD DVD and Blu-ray players. I understand that the need for this boost is to avoid line level clipping in the player's output stage or the AVR/Pre-Pro's input stage.
Some AVR's (Denon ?) have a similar +10 dB LFE boost option for the multichannel linear PCM input via HDMI.
Any HDMI (1.0, 1.1, 1.2a, 1.3) interface can carry multichannel linear PCM. HDMI 1.3 is not required. The 1.3 version can carry the raw undecoded bitstream for DD+, Dolby TrueHD, dts-HD HR and dts-HD MA. But that feature (raw bitstream) gets disabled when the user requests PiP with commentary audio that must be mixed in inside the player.
Hope this helps a little bit. I know that it is confusing to a newcomer.
Bob
Last edited by bobgpsr; 11-08-07 at 09:10 AM. Reason: Clarified what happens with PiP commentary audio
Old 04-03-07, 10:25 AM   #2 (Link)
Loc: Lower Alabama
Re: HD DVD players decode the audio -- not the AVR
Great explanation Bob... most excellent...
Thank you!
Sonnie
Old 04-04-07, 03:15 AM   #3 (Link)
Alias: MACCA
Loc: Australia
MACCA350's Avatar
User: #149
MACCA350 is offline
bobgpsr wrote: View Post
This also applies to Blu-ray discs encoded with "Profile v1.1" or higher.
cheers
MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc....
BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc....
Old 02-18-08, 10:24 AM   #4 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Does any HD or BD player have 7.1 output audio?
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 02-18-08, 11:43 AM   #5 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
blaser wrote: View Post
Likely for linear PCM if the title author can fit it. Have not heard about any player having audio codec decode to more than 5.1 channels.
« Home Theater Shack > HD World | Computers | Games | Media > High Definition | HD-DVD | Blu-ray »
Similar Threads
Upconverting component DVD players toecheese Home Theater Components 27 03-28-07 11:09 AM
Shoppers shunning DVD hi-def players Wayne A. Pflughaupt Home Theater, Audio and Video News 15 11-29-06 07:38 AM
New HQV Equipped DVD Players From Denon Wayde Home Theater, Audio and Video News 10 07-24-06 03:23 PM
HD-DVD and Blu-ray Players Sonnie High Definition | HD-DVD | Blu-ray 7 06-08-06 11:56 AM
Retailers: HD-DVD players nearly sold out Roger Home Theater, Audio and Video News 4 05-31-06 10:43 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
