Firmware update version 4.0 for Toshiba A3, A30 & A35 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > High Definition | HD DVD | Blu-ray
Discuss Firmware update version 4.0 for Toshiba A3, A30 & A35 in the HD World | Computers | Games | Media forum; Firmware update version 4.0 for Toshiba A3, A30 & A35 Edit: Updated for ISO links and Toshiba announcement of version 4.0 firmware. See this post . ---------------------------------- Firmware 3.0 is ...
Old 10-16-07, 11:48 AM   #1 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
Exclamation Firmware update version 4.0 for Toshiba A3, A30 & A35
Edit: Updated for ISO links and Toshiba announcement of version 4.0 firmware. See this post.
Firmware 3.0 is available for update by direct ethernet connection to the internet or by download of a ISO CD-R image.
Links for a download to make a firmware update iso binary image CD-R:
http://tacp.toshiba.com/tacpassets-i...-A35-3003N.zip
http://tacp.toshiba.com/tacpassets-i...-A30-3003N.zip
http://tacp.toshiba.com/tacpassets-i...D-A3-3003N.zip
Link with an official Toshiba announcement.
Firmware Update Information for Owners of Toshiba HD DVD Players: Models HD-A30, HD-A3, HD-D3, HD-A35, HD-A2, HD-A20, and HD-XA2
Firmware Update Version: 3.0
Applicable Models: HD-A30, HD-A3, HD-D3, HD-A35, HD-A2, HD-A20, and HD-XA2.
Overview: As part of our commitment to provide world-class service to our customers, Toshiba is supplying this firmware update for use by purchasers of Toshiba HD DVD Player models listed above. This firmware update improves support for 1080p/24Hz OUTPUT and auto mode(for HD-A30 and HD-A35), improves network connectivity for supporting the download of web-enabled network content associated with certain HD DVD discs, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Important Note: Certain HD DVD discs may contain or have the capability of downloading studio-provided, web-enabled network content. To minimize any potential compatibility and/or connectivity issues, before viewing such content, it is recommended that you perform the firmware update process to ensure that your HD DVD player is using the latest firmware version.
How to obtain and install the firmware update:
1. If you have broadband internet service, you may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. Instructions for configuring the Ethernet port and downloading the firmware update can be found in the owners manual and Update Procedure sheet for your HD DVD Player. Here is an overview of the process:
BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
Please configure the Ethernet port. You may need to turn on DHCP and DNS.
After you have configured the Ethernet port, follow the directions in the owner’s manual to check for a firmware update.
If a firmware update is available for your player, it will take about 20 minutes to download and install. Once the firmware update download process has finished, the players power will automatically switch off. You must wait until this process has finished.
" DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
If no firmware update is available, the player will quickly exit the firmware update process.
Please refer to the owners manual for additional details.
2. If you have a PC with a CD-RW drive that is connected to the internet, you may be able to download an ISO image file of the firmware update to your PC and copy it to a blank CD-R or CD-RW disc. For more information, and to download an ISO image file of the firmware update, select your model below:
Choose your model: HD-A30 HD-A3 HD-A35 HD-D3 HD-A2 HD-A20 HD-XA2
HD-A30 Firmware
Part Number: HD303003
Instruction Note: INST2008-018.pdf
Download ISO: HD-A30-3003N.zip
HD-A3 Firmware
Part Number: HDA33003
Instruction Note: INST2008-016.pdf
Download ISO: HD-A3-3003N.zip
HD-A35 Firmware
Part Number: HD353003
Instruction Note: INST2008-017a.pdf
Download ISO: HD-A35-3003N.zip
HD-D3 Firmware
HD-A2 Firmware
Part Number: HDA23003
Instruction Note: INST2008-013.pdf
Download ISO: HD-A2-3003N.zip
HD-A20 Firmware
Part Number: HD203003
Instruction Note: INST2008-015.pdf
Download ISO: HD-A20-3003N.zip
HD-XA2 Firmware
Part Number: HDX23003
Instruction Note: INST2008-014.pdf
Download ISO: HD-XA2-3003N.zip
3. If you are unable, or prefer not, to obtain the firmware update by one of the methods described above, you may contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383). and request that a firmware update disc be sent to you by mail. You can update the firmware using the firmware update disc by following the instructions provided with the disc.
Please note that if you sent Toshiba the Firmware Update Request card included with your player, you will receive an update disc by mail from Toshiba as soon as it becomes available.
Frequently Asked Questions:
Q1.What does this update do?
A1. This firmware update improves network connectivity for supporting the download of web- enabled network content associated with certain HD DVD discs, improves certain video and audio processing capabilities, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Q2.Why do I need to turn on DHCP and DNS?
A2.Turning on DHCP causes the player to automatically detect its IP address and other network information from your internet service providers DHCP server. Turning on DNS causes the player to automatically detect the DNS server address associated with your internet service provider.
Q3.I purchased an HD DVD disc that contains/has the capability of downloading web- enabled network content. What do I need to do to view this content?
A3.First, be sure that you have properly configured the players Ethernet port. If your Ethernet port is properly configured, perform the firmware update process to update the players firmware to the latest firmware version. Once you have updated the player with the latest firmware, follow the directions that came with the HD DVD disc or that appear in the menu of the HD DVD disc. Should you experience problems viewing such content, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
Q4.The HDMI output does not work or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does the new firmware address that issue?
A4.The firmware update addresses and improves HDMI and DVI connectivity issues. If you still experience such issues, try disconnecting and reconnecting the HDMI cable. Make sure your display input is set to HDMI (or DVI). If your display has more than one HDMI/DVI input, make sure that all connected HDMI/DVI source devices are powered on (even if not in use). If none of these solve the issue, please turn off the TV and the HD DVD player. Check all connections. Disconnect and reconnect the HDMI cable. Turn on the TV first and then turn on the HD DVD player. Should you continue to experience issues, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
Q5.During HD DVD playback I sometimes experience pixelization, block noise or audio dropouts. Sometimes playback freezes or stops. Sometimes, playback is not smooth. Does the new firmware address these issues?
A5.This firmware update addresses various playability issues. You should also check to be sure that the disc is clean and, if the disc will not operate at all, that you are inserting the disc with the right side up. In the event that playback freezes or stops, press and hold the ON/STANDBY button on the front of the player for approximately ten seconds. This will cause the player to turn off. After the player turns off, turn the player back on by pressing the ON/STANDBY button, and then press the OPEN/CLOSE button to remove the disc. Should you continue to experience issues, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
Q6.Do I need to install prior firmware updates before installing the current firmware update?
A6.No. The current firmware update includes all of the prior firmware updates.
Last edited by bobgpsr; 09-27-08 at 12:35 PM. Reason: Updated for firmware 4.0 available
Old 10-17-07, 11:00 PM   #2 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: Firmware update for Toshiba A3, A30 & A35
Cuts boot up time by 30 seconds? What was it before?
Old 10-18-07, 07:49 AM   #3 (Link)
Tech'y Shackster
Alias: Bob
User: #25
SteveCallas wrote: View Post
I read reports of 65 sec power-up time going to 35 seconds for an A30.
Old 10-18-07, 01:49 PM   #4 (Link)
Alias: Steven
Loc: lake ozarks MO
thewire's Avatar
User: #9828
Since: Jun 2007
thewire is offline
That sounds right.
Old 11-15-07, 04:26 PM   #5 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Reports of version 1.3 firmware available for ethernet update. No docs or ISO links known yet.
Old 11-15-07, 06:39 PM   #6 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is online now
ethernet update, does that mean I have to connect using a PC network? i can't burn it on to a disk?
Old 11-15-07, 09:34 PM   #7 (Link)
Shack Objectivist
Alias: Andrew
Loc: College Station, TX
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
mike c wrote: View Post
If you don't have your HD DVD player connected to the net directly you can download the firmware here:
http://www.tacpservice.toshiba.com/C...andnotices.asp
http://www.tacp.toshiba.com/tacpasse...vdfirmware.asp
Just burn the disc as an image, not as a data file and you will be good to go.
Old 11-15-07, 09:43 PM   #8 (Link)
Tech'y Shackster
Alias: Bob
User: #25
avaserfi wrote: View Post
I just now checked the US and Canada Toshiba HD DVD sites. Do not yet see the new firmware docs or ISO posted there yet for both the A3,A30,A35 or also the A1,XA1 that is tonight available via ethernet. It may take another day or so.
Old 11-16-07, 12:27 AM   #9 (Link)
Alias: mike
mike c's Avatar
User: #147
thanks guys. downloaded the iso file even before I receiver my A35
Old 11-19-07, 02:36 PM   #10 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Re: Firmware update version 1.3 for Toshiba A3, A30 & A35
First post updated with firmware 1.3 info. Both ethernet update and CD-R ISO firmware download available.
Old 02-12-08, 11:57 AM   #11 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Re: Firmware update version 1.3 (2.0?) for Toshiba A3, A30 & A35
Looks like there is a new ISO image available as a zip file download for version 2.0 firmware
Files are named HD-Axx-2000U.zip with the "xx" being 3, 30, or 35.
Also some are able to do the direct internet (ethernet) to the player download. The normal firmware update notice release has not yet been updated for 2.0, instead it still says 1.3 .
Old 02-13-08, 09:14 AM   #12 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Re: Firmware update version 2.0 for Toshiba A3, A30 & A35
First post updated with new 2.0 release notice from Toshiba.
Reported fix to playing BBC's Die Fledermaus for users with A35.
Old 02-13-08, 06:22 PM   #13 (Link)
Alias: mike
mike c's Avatar
User: #147
does it cut load time/boot up time on the A35?
Old 02-13-08, 09:44 PM   #14 (Link)
Alias: lou
Loc: Brooklyn NY
louthewiz's Avatar
User: #16585
Since: Feb 2008
louthewiz is offline
Caution on applying new firmware!
http://www.avsforum.com/avs-vb/showthread.php?t=993417
Yamaha htr 5790 Pre/pro | Audiosource Amp 300 powering mains | Audiosource Amp 200
powering center | Onkyo m-282 Powering surrounds | Polk rt800 mains | polk Cs400 center |
Polk fx300 side surrounds| polk MKII back surrounds | Velodyne Dps-10 sub + Klipsch Ksw-10
Denon 1600 Sdi modded dvd player + iSCAN HD+ Video scaler |Oppo 980H Toshiba HD-A3 SonicView HD8000 d*sh pvr Panasonic Dmr e-80H dvd recorder
Acer PH530 720p projector Da-Lite Video Spectra screen MonoPrice cables
Old 03-07-08, 01:03 PM   #15 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Re: Firmware update version 2.0 for Toshiba D3
I'm ... I downloaded the ISO file to my computer, but I can't burn a disc ..
My laptop got frozen ... and the other started the burn process but at the end show me an error ... and gave me the option to try again; but I destroyed three disc and nothing
I'm using a CD-R disc and a CD writer ... I used a couple of disc from Office Depot and one from Verbatim (the best!!! ... according to the experts)
Please help me with suggestions ... I don't want to run a long ethernet cable (25')
Old 03-10-08, 11:43 AM   #16 (Link)
Tech'y Shackster
Alias: Bob
User: #25
First - remember that your PC or a MAC cannot read the resultant burnt disc. It is an odd file format that only the Tosiba HD DVD player can use.
Try only using 4x burn speed and do "disc-at-once". You must burn as a binary image.
The only way to find out if the resultant burnt ISO binary image CD is any good is to try it in the player.
Old 03-10-08, 01:40 PM   #17 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
bobgpsr wrote: View Post
Thank you ... I will.
Yesterday I try to update directly from internet (I hooked up a network cable from router to player, set up the connection, etc.) but it didn't work ... there was a message; I can't recall correctly, but it was something like site not found ... I hope is not that Toshiba discontinued their link for the upgrade
Old 03-10-08, 03:20 PM   #18 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Use this program, Its called IMG Burn and works great and its free. It will burn a proper ISO image onto a CD rom.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 03-10-08, 07:53 PM   #19 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
tonyvdb wrote: View Post
Thank You
Old 03-14-08, 12:56 PM   #20 (Link)
Alias: Wayde
Loc: Waterloo ON, Canada
Wayde's Avatar
User: #943
Since: Jun 2006
Wayde is offline
Don't be too anxious to get into that firmware update.
Apparently there are issues with Aliasing and the new patch.
Anyone with a patched player and a sucessful 1080p24 setup tested chapter 5 of Transformers and looked for a severe aliasing bumblebee?
Wayde
Old 04-14-08, 10:31 PM   #21 (Link)
Alias: David
Loc: Fontana, CA
