| High Definition | HD DVD | Blu-ray Toshiba HD-A2 using ToslinkDiscuss Toshiba HD-A2 using Toslink in the HD World | Computers | Games | Media forum; Toshiba HD-A2 using Toslink Im thinking of getting a Hd dvd player and was wondering about the sound performance with these when using optical ... |
| | #1 (Link) | |||
| Toshiba HD-A2 using Toslink Im thinking of getting a Hd dvd player and was wondering about the sound performance with these when using optical toslink cables. Ive had my eye on the Toshiba HD-A2 since the price is comming down pretty fast but, I have heard that there may be some bass issues with some of these early models. Does anyone have experience with the sound quality of the A2 with using toslink that they would care to share. I will be comparing it with an Oppo 971. Thanks | |||
| | #2 (Link) | |||
| Re: Toshiba HD-A2 using Toslink No bass issues ever with the toslink output on the HD-A2. It re-encodes the new codecs (DD+ & TrueHD) to legacy 1509 kbps dts (the max that toslink allows per the S/PDIF spec). Very nice high bitrate, but not lossless. | |||
| | #4 (Link) | ||||
| Re: Toshiba HD-A2 using Toslink Quote:
), or occassionaly 1509 kbps dts ( ). The difference with the higher bitrates most often supplied by HD DVD or even with lossless TrueHD is subtle. I notice the improved sound most often with better imaging during quiet passages with sounds that are supposed to come from the surround channels. You have to listen carefully and be able to detect bad things like pre-echo, etc. So "noticeable" is somewhat dependent on the user. IME it can be noticed if you listen very carefully. ![]() The engineer in me is tells me that it "should be" better when the specs are better. ![]() | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Is Toslink or Coaxial best? | 11B2P | Remotes | Cables | Accessories | 36 | 05-17-07 02:12 AM |
| Toshiba | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-01-07 07:51 PM |
| FS: Toshiba HD-A2 | plincoln | Classifieds - Video Components | 0 | 04-08-07 12:34 PM |
| Just ordered a Toshiba HD-A1 | FlashJim | High Definition | HD DVD | Blu-ray | 27 | 10-25-06 12:37 PM |
| Toshiba HD-XA2!!! | jagman | High Definition | HD DVD | Blu-ray | 7 | 09-20-06 08:09 AM |
