| High Definition | HD-DVD | Blu-ray DD+, TrueHD Downmixing questions...Discuss DD+, TrueHD Downmixing questions... in the HD World | Computers | Games | Media forum; DD+, TrueHD Downmixing questions... Until the bass management bug in the 1st gen Toshiba players is fixed, I am going back to bitstream via ... |
| | #1 (Link) | |||
| DD+, TrueHD Downmixing questions... Until the bass management bug in the 1st gen Toshiba players is fixed, I am going back to bitstream via optical, and letting my AVR do the BM. As I was watching Batman Begins this way, I was playing around with the sound formats, and noting the differences between each. My understanding is that Dolby Digital Plus downmixes to full bitrate (1.5mps) DTS, which is then decoded by my AVR, right? Well, my AVR says that the incoming signal is 48Kbps, so what am I missing? Also, when I switched to TrueHD to see what the downmix was, the AVR still said I was getting no more than 48Kbps. Before FW2.0, the Tosh would only send 2.0 PCM out of SPDIF for TrueHD (48, 96 or 192 Kbps). Now that we have TrueHD 5.1, does it send 5.1 PCM over SPDIF? The AVR still interpreted the downmixed TrueHD as DTS, even though it was PCM. Is this normal? Should I be downmixing a lossless track in the first place? <Jack Tripper voice> I'm so confused... <end Tripper vioce>Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #2 (Link) | |||||||
| Re: DD+, TrueHD Downmixing questions... Quote:
| | #3 (Link) | |||||||
![]() Quote:
Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||||||
| | #4 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... Can you honestly even hear a difference between 5.1 PCM and 5.1 bitstream when watching a movie in surround sound? I'm not asking that sarcastically, more so curiously. With music listening, one is focused on the music - for movies, without having listened to a 5.1 PCM track yet, I'd imagine the difference is negligible? The difference in proper bass management would be much more easily noticed. | |||
| | #5 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... I have not heard a PCM track, but the differences between a TrueHD track and a re-encoded Dolby Digital Plus one is definately significant. There are those who say that LPCM trumps TrueHD, but I'm not sure I buy that (both are lossless). The TrueHD sounds much smoother, more detailed and generally richer. After having listened to Batman Begins TrueHD track and then moving to the bitstream, I definately am gonna miss the TrueHD (but, the bitstream sounds pretty **** good in its own right) Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #6 (Link) | ||||||
As far as the re-directed bass being 10db hotter, it looks like the players BM is not appying the -15db pad, and +3 db boost that occurs when the BM is done in the AVR's processor. I cannot see how the internal decoder of the Toshiba passed Dolby and Dts liscensing without the proper cut and boost in the BM. Quote:
| | #7 (Link) | |||||
![]() Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... Last edited by Vader; 06-07-07 at 05:11 PM. | |||||
| | #8 (Link) | ||||
HDMI is protected with HDCP so multichannel linear PCM is OK on that. | ||||
| | #9 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... Kewl! Bob, that is exactly what I wanted to hear. When switching between DD+ and TrueHD over SPDIF, I thought that the TrueHD sounded a bit fuller (could just be my imagination), but I wasn't sure what the A1 was doing with the TrueHD. Thanx! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #10 (Link) | ||||
| Re: DD+, TrueHD Downmixing questions... Just wanted to note that this part is not a problem with the player, the player is performing this part correctly. The reason is because the DD and DTS standard allows for an extra 10db on the LFE channel when compared to the main 5 channels, so to do this the LFE channel needs to be boosted somewhere in the chain. What they did is actually master the LFE channel 10db lower on the disc. If you send the DD/DTS bitstream out digitally(optical/coax/HDMI) the receiver will automatically add the 10db boost on the LFE channel. The problem they had was sending it out from the play over multichannel analogue connections, they couldn't add the boost in the player because then the LFE output would be above the specified limits for analogue output/input stage(10db=3x increase in amplitude). So this is why we need to apply the 10db(15db if the player is performing Bass Management) boost at the amplifier stage Cheers ![]() Found this: Quote:
MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc.... BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc.... | ||||
| | #11 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... Never mind.... I just read your post again.... That is exactly what I am trying to learn... Thanks, MACCA350!In summary, the Tosh is failing to provide the 15dB boost before BM.... c'mon, Toshiba... give us another FW update! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #12 (Link) | ||||
In summary, the Tosh is failing to provide the 15dB cut(to the redirected bass) before BM.... c'mon, Toshiba... give us another FW update! Basically to mix the redirected bass into the LFE channel: LFE channel gets cut by 5db Redirected bass gets cut by 15db Then they are mixed together and are now 15db below the other 5 channels. At least thats how its supposed to work ![]() cheers ![]() MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc.... BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc.... | ||||
| | #13 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... MACCA350, Thanks for the correction. I think I got it, now (one of my brain cells is now in agreement with the other one). Hopefully when I am thinking straight again (I'm home with Captain Tripps - or at least that's what it feels like) I can follow this stuff a lot better... ![]() Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #14 (Link) | ||||
When talking of LFE, each format handles the LFE quite differently. Dts is recorded with the bass set at +0 on the board. It is then to be boosted(sometimes done automatically, or set manually)+10 at the decoder level. Dolby digital on the other hand uses a -10db recording level, and is automatically boosted +10 at the decoder level. Both approaches keep the analog outputs from being overloaded, and give the 10db headroom in the LFE channels. | ||||
| | #15 (Link) | |||
| Re: DD+, TrueHD Downmixing questions... Sir Terrence, What exactly is the bug in the Tosh bass management, then? It was clear that the redirected bass from the post title sequence explosion in "The Matrix: Revolutions" was extremely hot, burying the needle on the BFD and bottoming one of my subs. It was on the TrueHD track, and I was using the analog outs (which is the only path affected by the bug). Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #16 (Link) | |||||||
I can't find anything for DTS(since DTS don't really provide whitepapers) other than this: Quote:
![]() MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc.... BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc.... | |||||||
| | #17 (Link) | |||||
The process of dealing with BM and surround levels used to be a mess at the studio level, hence the confusion of how its done. Dolby had one level, Dts used another. I'm thankful for standards that are adapted industry wide to make this whole process and little easier to implement at both studio and receiver level. | |||||
